Normalization Script - remove UPDATE in ALLOW header in INVITE
fei he
Level 2
Level 2
I tried to remove UPDATE in ALLOW header in OUTBOUND INVITE (CM to carriage) after went through developer guide but could not really get it works after add below in my existing script. CM traces shows it did not remove UPDATE at all, any wrong with my script?
M = {}
function M.outbound_INVITE(msg)
msg:removeHeaderValue("Allow", "UPDATE")
end
local function getDisplayName (i_header)
local position_of_uri=string.find(i_header, "<")
if position_of_uri <= 2
then
display_name=nil
else
-- save display name which arrives in quotes
local display_name_tmp = string.sub(i_header,1, (position_of_uri - 1))
-- now remove the quotes
display_name_tmp = string.gsub(display_name_tmp,'"','')
-- now remove the space
display_name = string.gsub(display_name_tmp,' ','')
end
return display_name
end
local function splitURI(i_uri)
local position_of_semi = string.find(i_uri, ";")
local position_of_sip = string.find(i_uri, "sip")
if position_of_semi then
i_uri_id = string.sub(i_uri, position_of_sip, (position_of_semi -1 ))
r_uri_user = string.sub(i_uri, (position_of_semi + 1 ))
else
-- no user
i_uri_id = string.sub(i_uri, position_of_sip)
r_uri_user=nil
end
i_uri_id = string.gsub(i_uri_id,"sip:","")
local position_of_ampersand = string.find(i_uri_id, "@")
local r_uri_host=string.sub(i_uri_id,1,(position_of_ampersand-1))
local r_uri_domain=string.sub(i_uri_id,(position_of_ampersand+1))
local port_position = string.find(r_uri_domain, ":", 2)
if port_position then
r_uri_domain_port = string.sub(r_uri_domain,(port_position+1))
r_uri_domain = string.sub(r_uri_domain,1,(port_position-1))
else
-- no port
r_uri_domain_port = nil
end
return r_uri_host, r_uri_domain, r_uri_domain_port, r_uri_user
end
local function add_plus_to_string(uri_user)
-- check whether string begins with "+"
-- if it does, do nothing
-- if it does not, add plus
local firstchar=string.sub(uri_user, 1, 1)
local foundplus=string.match(firstchar, "+")
if foundplus then
newuri = uri_user
else
newuri='+' .. uri_user
end
return newuri, foundplus
end
local function remove_plus_from_string(uri_user)
-- if it does not, do nothing
-- if it does, remove plus
if foundplus then
newuri = string.sub(uri_user, 2)
else
newuri= uri_user
end
return newuri
end
local function add_plus_to_from(msg)
local From_header = msg:getHeader("From")
local From_uri = msg:getUri("From")
local From_tag = msg:getHeaderValueParameter("From", "tag")
From_uri_host, From_uri_domain, From_uri_domain_port, From_uri_user=splitURI(From_uri)
displayname=getDisplayName(From_header)
From_uri_host, foundplus=add_plus_to_string(From_uri_host)
if foundplus then
else
local context = msg:getContext()
if context
then
context["foundplusonfrom"]="+"
end
end
-- Create new Header
if displayname == nil then
-- new_from_header = '"' .. From_uri_host .. '" <sip:' .. From_uri_host .. '@' .. From_uri_domain
new_from_header = '<sip:' .. From_uri_host .. '@' .. From_uri_domain
else
new_from_header = '"' .. displayname .. '" <sip:' .. From_uri_host .. '@' .. From_uri_domain
end
if From_uri_domain_port then
new_from_header = new_from_header .. ':' .. From_uri_domain_port
end
if From_uri_user then
new_from_header = new_from_header .. ';' .. From_uri_user
end
new_from_header = new_from_header .. '>'
if From_tag then
new_from_header = new_from_header .. ';tag=' .. From_tag
end
msg:modifyHeader("From", new_from_header)
end
local function add_plus_to_paid(msg)
local Pai_header = msg:getHeader("P-Asserted-Identity")
local Pai_uri = msg:getUri("P-Asserted-Identity")
Pai_uri_host, Pai_uri_domain, Pai_uri_domain_port, Pai_uri_user=splitURI(Pai_uri)
displayname=getDisplayName(Pai_header)
Pai_uri_host, foundplus=add_plus_to_string(Pai_uri_host)
new_pai_header = '<sip:' .. Pai_uri_host .. '@' .. Pai_uri_domain
else
new_pai_header = '"' .. displayname .. '" <sip:' .. Pai_uri_host .. '@' .. Pai_uri_domain
end
if Pai_uri_domain_port then
new_pai_header = new_pai_header .. ':' .. Pai_uri_domain_port
end
if Pai_uri_user then
new_pai_header = new_pai_header .. ';' .. Pai_uri_user
end
new_pai_header = new_pai_header .. '>'
msg:modifyHeader("P-Asserted-Identity", new_pai_header)
end
local function add_plus_to_diversion(msg)
local Diversion_header = msg:getHeader("Diversion")
local position_of_sip = string.find(Diversion_header, "sip:")
if position_of_sip
then
first_chunk = string.sub(Diversion_header, 1, (position_of_sip + 3))
second_chunk = string.sub(Diversion_header, (position_of_sip +4))
firstchar = string.sub(second_chunk, 1, 1)
if foundplus then
else
Diversion_header = first_chunk .. "+" .. second_chunk
msg:modifyHeader("Diversion", Diversion_header)
end
end
end
local function add_plus_to_rpid(msg)
local Rpid_header = msg:getHeader("Remote-Party-ID")
local position_of_sip = string.find(Rpid_header, "sip:")
if position_of_sip
then
first_chunk = string.sub(Rpid_header, 1, (position_of_sip + 3))
second_chunk = string.sub(Rpid_header, (position_of_sip +4))
if foundplus then
else
Rpid_header = first_chunk .. "+" .. second_chunk
msg:modifyHeader("Remote-Party-ID", Rpid_header)
end
end
end
local function remove_plus_from_from(msg)
if context
then
local foundplus = context["foundplusonfrom"]
if foundplus then
From_uri_host=remove_plus_from_string(From_uri_host)
else
end
end
end
if From_tag then
end
end
end
end
local function handle_outbound_message(msg)
-- need to check outbound from, PAID, diversion and RPID headers for username beginning in "+"
-- if "+" is found do nothing
-- if "+" is not found, add "+" to the username and create tag to record that this header has been modified
-- save From
if From_header
then
end
if Pai_header
then
end
if Diversion_header
then
end
if Rpid_header
then
end
end
local function handle_inbound_message(msg)
-- for header (from, PAID, diversion, RPID) check tag to find whether it was modified in the outbound INVITE
-- if it was not modified do nothing
-- if it was modified, then remove then check for "+" on the
-- save From
if From_header
then
end
end
-- Request messages <direction>_<method>
-- M.inbound_INVITE = handle_inbound_invite
-- M.inbound_18X_INVITE = handle_inbound_18x
-- M.inbound_ACK = handle_inbound_ack
-- M.inbound_UPDATE = handle_inbound_message
-- M.inbound_200_INVITE = handle_inbound_message
-- M.outbound_200_INVITE = add_term_ioi
-- M.outbound_INVITE = handle_outbound_invite
M.outbound_INVITE = handle_outbound_message
-- M.outbound_18X_INVITE = handle_outbound_18x
-- M.outbound_ANY_INVITE = handle_outbound_any_invite
-- M.inbound_ANY_INVITE = handle_inbound_any_invite
M.inbound_ANY_INVITE = handle_inbound_message
-- M.outbound_ACK = handle_outbound_ack
M.outbound_ACK = handle_outbound_message
-- M.inbound_UPDATE = retrieveSNRContext
-- Response messages <direction>_<response-code>_<method>
-- M.inbound_200_INVITE = retrieveSNRContext
-- M.outbound_ANY_INVITE = retrieveSNRBackwardContext
-- M.outbound_CANCEL = retrieveSNRForwardContext
M.outbound_CANCEL = handle_outbound_message
-- M.outbound_UPDATE = handle_outbound_update
-- M.outbound_BYE = retrieveSNRForwardContext
M.outbound_BYE = handle_outbound_message
M.inbound_BYE = handle_inbound_message
M = {}
then
display_name=nil
else
end
return display_name
end
else
-- no user
r_uri_user=nil
end
else
-- no port
end
end
if foundplus then
newuri = uri_user
else
end
end
if foundplus then
else
newuri= uri_user
end
return newuri
end
if foundplus then
else
if context
then
end
end
else
end
end
end
if From_tag then
end
end
else
end
end
end
end
if position_of_sip
then
if foundplus then
else
end
end
end
if position_of_sip
then
if foundplus then
else
end
end
end
if context
then
if foundplus then
else
new_from_header = '"' .. displayname ..'" <sip:' .. From_uri_host .. '@' .. From_uri_domain
end
end
end
if From_tag then
end
end
end
end
-- save From
if From_header
then
end
if Pai_header
then
end
if Diversion_header
then
end
if Rpid_header
then
end
end
-- save From
if From_header
then
end
end
M.outbound_UPDATE = handle_outbound_message
M.inbound_100_ANY = handle_inbound_message
return M
fei he
Level 2
Level 2
And CM traces output:
//Pre Normalized Message//
INVITE sip:+61XXXXXXXXX@x.x.x.x:5060 SIP/2.0
Via: SIP/2.0/TCP x.x.x.x:5060;branch=z9hG4bK1ee735fcb88ea
From: < sip:+61XXXXXXXXX@x.x.x.x> ;tag=246599~e4f81d89-c8d9-4cdb-8808-27ab08bbd6ae-69271786
To: < sip:+61XXXXXXXXX@y.y.y.y>
Date: Mon, 28 Aug 2017 07:00:29 GMT
Call-ID: 921daa00-9a31bf8d-1edb2-601a8c0@x.x.x.x
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 7200
User-Agent: Cisco-CUCM10.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
//Post Normalized Message: //
INVITE sip:+61XXXXXXXXX@y.y.y.y:5060 SIP/2.0
Min-SE: 7200
Anthony Holloway
Is there some reason your script is so long?  I can't really follow it, and I'm pretty sure it could either be a lot smaller to achieve what you want, or you can just post the relevant section.
Also, if you're doing it to the carrier, you might want to do it on the CUBE.  It would be as easy as this:
voice class sip-profiles 1
 request INVITE sip-header Allow-Header modify ", UPDATE" ""
 request INVITE sip-header Allow-Header modify "UPDATE, " ""
 request INVITE sip-header Allow-Header modify "UPDATE" "INVITE"
Then apply that profile to your dial-peer(s) facing the ITSP:
voice-class sip profiles 1
Anthony
The script was provided by Cisco intially after they build the solution for us and we have been used that script since. I am not a script guy hence does not understand why the script is so long.
As i mentioned, I have tried to add that function into current script but seems it does not remove UPDATE in ALLOW but when I only run this section the UPDATE is removed as desire. I reckon the script itself somehow is messed up but i cannot tell. Neither Cisco is supporting SIP Norm script.
Anyway, in our solution, we are using CUBE-SP instead of CUBE hence could not use what you suggest.
