Normalization Script
shane.orr
Level 8
Level 8
I have vitually the same problem as posted below.
https://supportforums.cisco.com/message/3797939#3797939
After talking to TAC, the 3rd Party PBX is sending the SIP Contact Header and forcing Call Manager 8.6 to reject the call with a "SIP/2.0 400 Bad Request - 'Malformed/Missing Contact field'"
In my case calls all inbound calls are failing when marked as anonymous/private
PSTN <PRI> Nortel CS1k <SIP> Avaya Session Manager <SIP> Call Manager 8.6
I do not have CUBE, simply SIP Trunk directly from AvayaSM to UCM.
So I was wondering if anyone has any Normalization script advice.  I've been referring to the URL below but not much luck.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/sip_tn/9_0_1/sip_t_n.html
Current Incoming Private SIP Contact Header:
e.g.
Contact: <sip:anonymous.invalid;[email protected]:5060;maddr=1.1.1.1;transport=udp;user=phone>
Wanting to replace “anonymous.invalid;phone-context=+1” with “00000”:
e.g.
Contact: <sip:[email protected]:5060;maddr=1.1.1.1;transport=udp;user=phone>
...or any other advice welcome.
Thanks in advance!
shane.orr
Level 8
Level 8
For anyone intersted I fixed my problem with the following script.  The script is two-fold;
1. Lights Nortel MWI by replacing the word "voicemail" from the SIP "From" message to an arbitrary "1000" numerical value because Nortel will only recognize a number in the MWI SIP Notify outbound.
2. Modifies the SIP "Contact" message replacing the word "anonymous.invalid" to an arbitrary "12345" numerical value for Call Manager to accept private calls inbound.
Nortel = {}
Nortel.allowHeaders = {"History-Info"}
local contact_number = scriptParameters.getValue("contact-number")
local mwi_number = scriptParameters.getValue("mwi-number")
if not contact_number
then
    contact_number = "12345"
end
if not mwi_number
then
    mwi_number = "1000"
end
function Nortel.inbound_INVITE(msg)
    local from = msg:getHeader("Contact")
    if from
    then
        from = from:gsub("anonymous.invalid", contact_number)
        msg:modifyHeader("Contact", from)
    end
end
function Nortel.outbound_ANY(msg)
    msg:removeHeaderValue("Allow", "OPTIONS")
    end
function Nortel.outbound_ANY_ANY(msg)
    end
function Nortel.outbound_NOTIFY(msg)
    local from = msg:getHeader("From")
    if from
    then
        from = from:gsub("voicemail", mwi_number)
        msg:modifyHeader("From", from)
        msg:addHeaderUriParameter("From", "user", "phone")
    end
end
return Nortel
shane.orr
Level 8
Level 8
Nortel = {}
then
end
if not mwi_number
then
    mwi_number = "1000"
end
    if from
    then
    end
end
    end
    end
    if from
    then
    end
end
return Nortel
One thing I've noticed about great postings, is that often they go unnoticed. Let's hope that is not the case here.
Thanks Paolo!
