02-27-2019 12:56 AM
Dears
i have configure the core switch as NTP server for my ip phones. It take the time just fine but i notice that the time in the core switch is not accurate so now i need to change the time in the core (NTP server) so once i change the time in the Core should i reset all the ip phones in the CUCM to get the correct time or it will get the time without any reset?
appreciate any support.
Amrani
02-27-2019 05:45 AM
No need to reset any phones, once the time is corrected and CUCM adjusts it's time based on it so will the phones. It may take a while though depending on how off the time was, so be patient.
02-27-2019 06:02 AM
thanks alot for reply
i want to make sure that there will be no impact because it is in operation.
