Number sign, hash, or pound sign - Usage for it before a DN
jssalgado
Please, I would appreciate if anyone has that information for the # before a DN or any other expresion before the DN as prefix.  I am not talking of Route pattern but DN´s.
Thanks so much for your help.
luis_cordova
Hi @jssalgado ,
Could you give an example of your query?
Jaime Valencia
The octothorpe (#) character generally identifies the end of the dialing sequence.
Ensure the # character is the last character in the pattern.
The route pattern 901181910555# routes or blocks an international number that is dialed from within the National Numbering Plan. The # character after the last 5 identifies this digit as the last digit in the sequence.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/9_1_1/ccmsys/CUCM_BK_C5565591_00_cucm-system-guide-91/CUCM_BK_C5565591_00_cucm-system-guide-91_chapter_010000.html
java
if this helps, please rate
Thanks Jaime: Yes, this symbol is used in route patterns, but I was wondering the meaning of it when used in DNs
Thanks again.
