Odd QoS DSCP marking behaviour on 3945 Router
Ella Bella
I have a simple QoS config, that matches RTP and SIP traffic and marks the packets with DSCP values. The weird thing is - it takes exactly 4 minutes after the call is initiated before the packets start getting marked! What on earth could be causing this? Ive never seen this behaviour before.
Heres my QoS config:
class-map match-any CM-classify-rtp
match protocol rtp
match ip precedence critical
class-map match-any CM-classify-signalling
match protocol sip
match ip precedence flash
policy-map PM-classify-in
class CM-classify-rtp
  set ip dscp ef
class CM-classify-signalling
  set ip dscp af31
interface gigabitethernet 0/0.2
encapsulation dot1q 2
ip address 10.131.2.4
ip nbar protocol-discovery ipv4
service-policy input PM-classify-in
On Gig0/0 interface apply the command ' load-interval 60' and see if it makes a difference.
Hello, I applied the load-interval 60 command and there is no change to the behaviour. Thanks for the suggestion!
