Hello Team, I have HQ and BR1 cluster.. they are able to register into respective forwarders.. but in RTMT I am not able to see any learning pattern.. Command used in router is as follows: service-routing xmcp listen ipv4 port 5050 client usern...
Can someone help me understand the call path when we test a call manager subscriber failover, and there is an external incoming call to the site where the Call Manager Subscriber is down? We have a Multisite Deployment with Distributed Call Processin...
Hi, I've been messing with CFA for a few days now and getting nowhere fast. Speaking with the ITSP I can confirm they do not allow P-Asserted methods but they DO allow Diversion modifications to the SIP header. They are telling me that the issue is...
How do you disable the call-waiting tone heard in the earpiece for SIP phones? using 7841 phones CME10.5. I would like a visual indicator, but not an audio in the earpiece. SCCP phones use the "no call-waiting beep". Is there a SIP equivalent?
I was able to set up AnyConnect VPN for phones using certificates but for added security I would like to use Certificates + Username, password. I can't find anywhere where it is documented how to make the phone ask for a user name and password. I di...
Cisco 3905 phone is hung intermittently, cannot be dialed and dial out any number. I am facing this issue from last months. Please suggest me how can i resolve this issue.
I have a 7945G which I have successfully flashed to SIP v9-4-2SR3 (it rejected v8.5.4) and registered with 3cx. Everything works with the exception of the time setting. I have <dateTimeSetting><dateTemplate>D/M/Y</dateTemplate><timeZone>Central Europ...
I'm having an issue where internal calls made to an extension ring the remote destination as configured, but when a translated call from the outside over a PRI comes in, the desk phone rings but the remote destination does not. Any ideas why it woul...
Having trouble with SIP calls between 2 internal networks. Voice and data are on separate networks internally but they can communicate. We are trying to use a softphone app on a cellphone. it works fine when on an external network but when the phone ...
Dear Allwe have an issue with fxo portsour deployment isCUCM ----H.323 GW with FXOOutgoing calls works fine ,but no incoming calls success .This Gateway in Tanzaniakindly find attached run config and debug commands
We recently upgraded to CUCM 11, which added the "home cluster" options on the end user page. In our environment, all users are LDAP synchronized and we filter the users that are imported, so only our own region is synchronized and all of the importe...
In CUCM 8.6+ how long does the audit log remain before its overwritten? Can this be changed in Enterprise parameters? I know you can grab them in RTMT but wasn't sure of the retention period. Thanks,
Hi- facing this challenge with translation patterns. Our company has 3 locations and we use 3 digit dialing for 2 of them now. Issue is, we are over 1000+ numbers. Is there any way to accommodate this many translation patterns with this amount of num...
Hi,Miscellaneous signaling debug data: (ch=1). When i start the router my voice card showing green light stable and not getting the dial tone. Kindly suggest how can i fix this issue.
Very odd request. Customer needs MRA to Internet as normal spanning over firewalls. But security is setup so that no workstations can communicate to any other workstation. So point-to-point traffic such as audio/video, screen share, file transfer,...
Subject | Author | Posted |
07-23-2025 12:10 PM | ||
07-16-2025 12:00 PM | ||
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM |
User | Count |
11 | |
2 | |
2 | |
1 | |
1 |
