06-29-2009 06:56 AM - edited 03-15-2019 06:44 PM
Hi All,
Recently i had one POC for FAX over IP using 2821 + E1 PRI.
Both On ramp and off ramp fax are working fine , but for off ramp fax with normal TIFF attached file its not transmitting to the other end . I have gone through the docs and came to know Gateway will only support TIFF-F files for off ramp fax. So any applications or converter TIFF-F conversion.
Thanks and regards
07-03-2009 12:05 PM
There are many different options and ways to use TIFF to encode data. Cisco T.37 gateways can take a TIFF attachment and convert it to a fax for off-ramp applications. However, the TIFF format must conform to profile F (TIFF-F) which is the extended black-and-white fax mode. TIFF-F supports MH, MR, and MMR encodings.
07-14-2009 04:00 AM
It is not as straightforward, - not all TIFF-F compliant files are cisco compatible, e.g. TIFF files saved in Windows Fax Console are not cisco compatible.
One of compliant commercial solutions for Windows is facsBridge T37FSP from www.sandlerco.com
