OFFNET to OFFNET transfer Open for some phones
Humood-J-Humood
Dear all,
I need to blocked all PSTN transfer by globally in my organization ( :  Sevice Parameter> Block Offnet to Offnet = True.)
and need to open for some of the phones … Is it possible…?
advice me plz
Jaime Valencia
That's not possible, if you look at the section on which the parameter it's located it mentions that they're clusterwide parameters. Meaning it's either all phones or no phones.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
