02-24-2011 03:10 AM - edited 03-16-2019 03:37 AM
morning all,
I was wondering if you could assist here. I am trying to configure a call handler which allows the caller to dial into UCM which directs to a call handler and plays a message. The caller has a choice to press 1 if they know the extension they would like to dial.
This is all working. However when you press 1, and then enter the extension number (8xxx) Unity says "you cannot be transferred to this number".
I have checked the restriction tables and they have the standard 91??????* etc, and I have added in 8??? to allow dialing these 8xxx extension numbers but this still does not work.
I have checked the PT and CSS on UCM and these are all ok.
Any pointers you could help with?
Solved! Go to Solution.
02-24-2011 06:57 AM
Hi Carl,
Just to add a note to Java's great tips (+5 "J")
Have you checked the numbers in question within the CS_Default_System_Transfer restriction table to see if it permits it.
Restricts numbers that can be used for Caller system transfers, which allow unidentified callers to transfer to a number that they specify. For example, callers may want to dial a lobby or conference room phone that is not associated with a Cisco Unity subscriber. By default, the table does not allow Cisco Unity to dial any numbers.
Cheers!
Rob
02-24-2011 04:18 AM
Is the DN you're trying to reach already configured in Unity? I mean, is it in a call handler, subscriber, etc?
Are you using a call system transfer?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-24-2011 06:57 AM
Hi Carl,
Cheers!
Rob
03-01-2011 04:57 AM
Thanks for the reply chaps,
as you can see the 5th entry should allow all calls through, I specifically put in 8* for the 8175 extension on UCM. This is not being used on any call handler either.
Dial String Call pattern Allow
0 8* Yes
1 91???????* No
2 9011???????* No
3 9???????????* No
4 900* No
5 * Yes
Any other ideas?
03-01-2011 05:11 AM
Rob,
you were right! I added in them numbers 3??? and 8??? and I can now dial.
Many thanks!
Carl
03-01-2011 05:53 AM
Hey Carl,
Nice work my friend Glad to be of some small help here.
Cheers!
Rob
03-01-2011 06:28 AM
Cheers again mate.
Carl
