On-off & Off hook Digit Strip issue on CME
Nitin Kapoor
Dear All,
I am using CME in our network and we are facing very strange issue.
When i dialed the number by using "off-hook" then Cisco Iphone is not sending the complete dialed digit to CME.
Whereas when i use "on-hook" way to dial the digit then Cisco IP Phone are sending the complete dialed digit to CME.
However i was suspecting this could be inter-digit timeout issue, however it is not making more sense to me if i think in that way, since in "off-hook" we can dial the whole number first and then press push button etc, and in that manner no timeout issue can be there between the digits.
Can anyone please help me on this? Thank you in advance.
-Nitin
13 Replies 13
Vivek Batra
Using SCCP or SIP?
I assume it is SIP and suspect that when you are dialing off-hook, phone is using KPML which dials the number digit by digit, however in case of on-hook dialing, digits are sent enblock.
Try configuring following command under 'voice register pool' and see if it makes any difference (don't forget to use 'no create profile' -> 'create profile' -> reset the phone).
no digit collect kpml
- Vivek
Hi Vivek,
Thanks for the reply. However i do not see any particular "Voice Register pool" for my Configured phone.
This is my phone what i can see in "sh run"
ephone-dn 9 dual-line
number 319
label Nitin Kapoor
description XXX-XXXX
name Nitin Kapoor
call-forward busy 99880
call-forward noan 99880 timeout 20
mwi sip
I can see only below Pool and none of the for my extension. So i am little bit confuse which pool i should make the change.
voice register pool 1
id mac 0000.0000.0000
number 1 dn 1
dtmf-relay rtp-nte sip-notify
voice-class codec 1
username 331 password XXXXXX
no vad
voice register pool 2
number 1 dn 2
voice-class codec 1
username 318 password XXXXXX
no vad
voice register pool 3
number 1 dn 3
voice-class codec 1
username 333 password XXXXXX
no vad
voice register pool 4
number 1 dn 4
voice-class codec 1
username 335 password XXXXXX
no vad
voice register pool 5
number 1 dn 5
voice-class codec 1
username 337 password XXXXXX
no vad
voice register pool 6
number 1 dn 6
voice-class codec 1
username 338 password lXXXXXX
no vad
voice register pool 7
number 1 dn 7
voice-class codec 1
username 380 password XXXXXX
no vad
voice register pool 8
number 1 dn 8
voice-class codec 1
username 339 password XXXXXX
voice register pool 9
number 1 dn 9
voice-class codec 1
username 336 password XXXXXX
no vad
Which phone type (/model) are you using?
Are you using third party SIP phones?
What is the number assigned to phone which is having reported problem?
- Vivek
Hi Vivek,
We are using Cisco 6941  Ipphone model.
I am using Eyebeam aswell to make call when we ae not in office. But with Eyebeam we do not have any problem.
Problem is having in every phone which is registered individually.
Do you think i should try the "kpml" command in all the pool 1 by one and confirm by making test calls?
Nitin
Hi Nitin,
Yes, you won't get any issue with Eyebeam as it will always use enblock dialing.
I can not see relevant configuration for Cisco 6941 in running-confg you shared before. Can you please share actual config and also let me know are you using it as SCCP or SIP?
- Vivek
Hi Vivek,
Sorry for incinviennce. We are using sip as far as i know.
Also as you mentioned below is the running configuration. I deleted some unwanted information. You can see my line is configured as below.
hostname CME_XX
boot-start-marker
boot-end-marker
card type t1 0 0
logging buffered 2000000
no logging console
no logging monitor
no aaa new-model
network-clock-participate wic 0
ip cef
ip domain name yourdomain.com
no ipv6 cef
isdn switch-type primary-dms100
trunk group XXX_PRI
hunt-scheme round-robin
crypto pki trustpoint TP-self-signed-2859488564
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2859488564
revocation-check none
rsakeypair TP-self-signed-2859488564
voice-card 0
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 X.X.X.X
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server
no call service stop
voice class codec 100
codec preference 1 g729r8
codec preference 2 g729br8
voice class codec 101
codec preference 1 g711ulaw
voice class codec 1
codec preference 2 g729r8
voice class codec 102
voice class sip-profiles 1000
request INVITE sip-header From modify "(From:)(.*<)\"" "\1 \"Test_Call \"<"
voice register global
mode cme
source-address X.X.X.X port 5060
max-dn 30
max-pool 30
authenticate realm X.X.X.X
tftp-path flash:
create profile sync XXXXX-XXXXX
voice register dn 1
number 331
name XXXX-SoftPhone-XXXXX
label XXXXX-XXXXX
mwi
voice register dn 2
number 318
name XXXX
label XXXXX-XXXXX
mwi
voice register dn 3
number 333
name XXXXX-XXXXX
label XXXXX-XXXXX
voice register dn 4
number 335
name XXXXX-XXXXX
label XXXXX-XXXXX
voice register dn 5
number 337
name XXXXX-XXXXX
label XXXXX-XXXXX
voice register dn 6
number 338
name -SoftPhone-Nitin
label XXXXX-Nitin
voice register dn 7
number 380
call-forward b2bua noan ******** timeout 20
name XXXXX-XXXXX
label XXXXX-XXXXX
voice register dn 8
number 339
name SoftPhone-XXXXX-XXXXX
label SoftPhone-XXXXX-XXXXX
mwi
voice register dn 9
number 336
name XXXXX-XXXXX
label XXXXX-XXXXX
number 1 dn 1
voice-class codec 1
username XXXXX-XXXXX password XXXXX-XXXXX
no vad
number 1 dn 2
voice-class codec 1
no vad
number 1 dn 3
voice-class codec 1
no vad
number 1 dn 4
voice-class codec 1
no vad
number 1 dn 5
voice-class codec 1
no vad
number 1 dn 6
voice-class codec 1
no vad
number 1 dn 7
voice-class codec 1
no vad
number 1 dn 8
voice-class codec 1
number 1 dn 9
voice-class codec 1
no vad
voice hunt-group 1 parallel
final 507
list 311,313,315,316,317,338,319
timeout 18
pilot 401
voice translation-rule 7
rule 1 /7\(.*\)/ /*********\1/
voice translation-rule 8
rule 1 /^8/ //
voice translation-rule 71
rule 1 /71\(.*\)/ /*******\1/
voice translation-rule 81
rule 1 /^81/ //
voice translation-rule 99
rule 1 /^99/ //
voice translation-rule 100
rule 1 /9\(.*\)/ /*********\1/
voice translation-rule 102
rule 1 /9\(.*\)/ /*******\1/
voice translation-profile International
translate calling 101
translate called 100
voice translation-profile incoming
translate called 103
voice translation-profile local
translate called 102
voice translation-profile nextonetest
translate called 8
voice translation-profile nextonetest-g711
translate called 81
voice translation-profile sonustest
translate called 7
voice translation-profile sonustest-g711
translate called 71
voice translation-profile strip99
translate called 99
application
package callfeature
param long-dur-disc-cause 34
param long-dur-duration 120
param long-dur-action disconnect
param long-dur-call-mon enable
hw-module ism 0
hw-module pvdm 0/0
redundancy
controller T1 0/0/0
clock source internal
cablelength long 0db
pri-group timeslots 1-24
description ***Conencting to XXXXX-XXXXX_PRI***
no ip ftp passive
translation-rule 101
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description XXXXX-XXXXX-INFO-GE 0/0$
ip address XXXXX-XXXXX 255.255.255.0
duplex auto
speed auto
interface ISM0/0
ip unnumbered GigabitEthernet0/0
service-module ip address XXXXX-XXXXX 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway XXXXX-XXXXX
ip address XXXXX-XXXXX XXXXX-XXXXX
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn timer T310 35000
isdn incoming-voice voice
isdn map address . plan isdn type national
trunk-group XXXXX-XXXXX_PRI
no cdp enable
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash0:
ip route 0.0.0.0 0.0.0.0 XXXXX-XXXXX
ip route XXXXX-XXXXX 255.255.255.255 ISM0/0
ip route XXXXX-XXXXX 255.255.255.0 XXXXX-XXXXX
tftp-server flash0:DSP69xx.12-4-122-02-121029.zz.sgn
tftp-server flash0:cmterm-69xx-sccp.9-1-1-0.cop.sgn
tftp-server flash0:SCCP69xx.9-3-3-2.zz.sgn
tftp-server flash0:SCCP69xx.9-3-3-2.loads
tftp-server flash0:SCCP69xx.9-1-1-0.loads
tftp-server flash:SCCP69xx.9-1-1-0.zz.sgn alias SCCP69xx.9-1-1-0.zz.sgn
tftp-server flash:DSP69xx.0-0-0-4.zz.sgn alias DSP69xx.0-0-0-4.zz.sgn
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
control-plane
voice-port 0/0/0:23
translation-profile incoming incoming
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm XXXXX-XXXXX identifier 1 version 4.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register confprof1
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 2 transcode
codec g711alaw
codec g711ulaw
codec g729ar8
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
maximum sessions 2
dial-peer voice 300 voip
session protocol sipv2
incoming called-number 3..
codec g711ulaw
no vad
dial-peer voice 7 voip
translation-profile outgoing sonustest
destination-pattern 7T
session target ipv4:XXXXX-XXXXX
voice-class codec 100
voice-class sip profiles 1000
dtmf-relay rtp-nte
clid strip name
no vad
dial-peer voice 8 voip
translation-profile outgoing XXXXX-XXXXX
destination-pattern 8T
dtmf-relay rtp-nte
clid strip name
dial-peer voice 109 voip
description ***USA Calls***
translation-profile outgoing local
destination-pattern 91..........$
dtmf-relay rtp-nte
clid strip name
no vad
dial-peer voice 110 voip
description ***International Calls***
translation-profile outgoing International
destination-pattern 9[2-9]T
dtmf-relay rtp-nte
clid strip name
no vad
dial-peer voice 100 voip
destination-pattern 100
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 999 pots
description *** Inbound Calls ***
incoming called-number .
direct-inward-dial
dial-peer voice 200 voip
destination-pattern 2..
codec g711ulaw
no vad
dial-peer voice 500 voip
destination-pattern 5..
codec g711ulaw
no vad
dial-peer voice 400 voip
incoming called-number 4..
codec g711ulaw
no vad
dial-peer voice 71 voip
translation-profile outgoing XXXXX-XXXXX-g711
destination-pattern 71T
voice-class codec 101
clid strip name
no vad
dial-peer voice 81 voip
destination-pattern 81T
dtmf-relay rtp-nte
clid strip name
dial-peer voice 1800 pots
trunkgroup XXXXX-XXXXX_PRI
description ***Toll-Free Calls***
destination-pattern 91800.......$
forward-digits 11
dial-peer voice 1844 pots
destination-pattern 91844.......$
forward-digits 11
dial-peer voice 1855 pots
destination-pattern 91855.......$
forward-digits 11
dial-peer voice 1877 pots
destination-pattern 91877.......$
forward-digits 11
dial-peer voice 1888 pots
destination-pattern 91888.......$
forward-digits 11
dial-peer voice 101 voip
destination-pattern 101
codec g711ulaw
no vad
dial-peer voice 770 voip
translation-profile outgoing strip99
destination-pattern 99880$
codec g711ulaw
no vad
dial-peer voice 1 voip
destination-pattern 880
codec g711ulaw
no vad
dial-peer voice 99770 voip
destination-pattern 99770
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:XXXXX-XXXXX expires 3600 port 5060 transport udp
gatekeeper
shutdown
telephony-service
sdspfarm units 2
sdspfarm transcode sessions 4
sdspfarm tag 1 confprof1
sdspfarm tag 2 transcode
conference hardware
no auto-reg-ephone
max-ephones 100
max-dn 50
ip source-address XXXXX-XXXXX port 2000
max-redirect 7
caller-id block code *67
timeouts interdigit 2
cnf-file location flash:
load 6921 SCCP69xx.9-1-1-0.loads
load 6941 SCCP69xx.9-1-1-0
load 6961 SCCP69xx.9-1-1-0.loads
time-zone 13
voicemail 99880
max-conferences 4 gain -6
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Jun 17 2015 12:32:55
ephone-dn 1 dual-line
number 311
pickup-group 1
label Victor Ho
name XXXXX-XXXXX
mwi sip
ephone-dn 2 dual-line
number 313
pickup-group 1
label XXXXX-XXXXX
name XXXXX-XXXXX
mwi sip
ephone-dn 3 dual-line
number 315
pickup-group 1
label XXXXX-XXXXX
name XXXXX-XXXXX
mwi sip
ephone-dn 4 dual-line
number 317
pickup-group 1
label XXXXX-XXXXX
name XXXXX-XXXXX
mwi sip
ephone-dn 5 octo-line
number A001
conference ad-hoc
preference 3
ephone-dn 6 octo-line
number A002
conference ad-hoc
preference 3
ephone-dn 7 dual-line
number 350
label XXXXX-XXXXX
name XXXXX-XXXXX
mwi sip
ephone-dn 8 dual-line
number 316
pickup-group 1
label XXXXX-XXXXX
name XXXXX-XXXXX
mwi sip
number 319
label Nitin Kapoor
description Nitin Kapoor
name Nitin Kapoor
mwi sip
ephone-dn 10 octo-line
number A003
conference ad-hoc
preference 3
ephone-dn 11 octo-line
number A004
conference ad-hoc
preference 3
ephone 6
mac-address XXXXXXXXXXX
username "XXXXX-XXXXX" password XXXXX-XXXXX
type 6941
button 1:9
pin 1234
Hi Nitin,
If it is SIP phone, can you help me in getting the point that why you didn't configure the phone type and relevant mac address (id mac) under voice register pool because in absence of this, phone won't be able to get desired configuration files.
Also let me know how did you verify that phone is sending only one digit during off-hook dialing? Using debug ccsip messages?
- Vivek
Hi Vivek,
first part i m not sure, this is configured by someone else actually.
yes i enable debug ccsip to identify this.
regards
nitin
Ok,
Try making changes in one voice register pool and see if it works (however I doubt it will work because of absence of other configuration);
number 1 dn 1
voice-class codec 1
no vad
Add the desired command in one pool say pool 1, then give no create profile, create profile and reset the phone. From respective phone (having DN 1), observe the behavior.
If it doesn't work, I would request you to add specific phone mac using 'id mac' and 'type 6941' under this pool and again observe the results.
- Vivek
I agree with Vivek (+5). You need to have phone type configured. Otherwise the phones will get the default config file (SIPDefault) which won't take your phone specific config.
Also, the KPML dialing problem has been observed in couple of SIP phones (69xx and 78xx). The command provided by Vivek most probably will resolve the problem.
Hi Mohammed,
Sorry for confusion. Actually we are using Skinny protocol not SIP. When i tried to did configuration for kpml under pool, it says there is no command.
CME_LA(config-register-pool)#no digit?
% Unrecognized command.
Hi Vivek,
Thanks a lot for all your reply. It really help me to nail down the things at some level.
However i think i given a one wrong information here. We are not using SIP actually, we are using Skinny Protocol. I think that is the reason you are seeing a different configuration or something. Also when i tried to configure the kmpl then its not giving any command option for this.
Regards.
Nitin
Hi Nitin,
Thanks for the update. I had this doubt before since without proper configuration in place (voice register pool), it won't be possible for 6941 to get the configuration file successfully.
'no digit collect kpml' command will be available only once you enter the type command under voice register pool and moreover if that phone type supports KMPL.
- Vivek
