one touch call forward all
Dear All,
I want to forward all my calls while i am going out of office with only OneTouch. As the normal case i will press CFwALL and then enter the number but i want to configure my mobile number in this button so once i press it should forward all my call to my mobile number without me entering my mobile number.
please help me with that.
Regards.
Jaime Valencia
You cannot do that, the closest thing you can do is to configure your mobile as a speed dial on the phone so you just press CFA + speed dial.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
yes you are righ , i configured the same and it worked fine.
thanks man
