Open CUCM via SSH over PHP and run a command
hghghghghg
I'm trying to connect to the SSH Consolle of our CUCM via a PHP script. The connection (login) to the CUCM works, but when i set up a command, it gives me the error message below. Other Cisco SSH consoles work via PHP properly.
I found this website, but via php connector it doesn`t work...
https://community.cisco.com/t5/ip-telephony-and-phones/cm-platform-access-with-plink-exe/m-p/1822270
stty: standard input: Invalid argument
Exception in thread "main" java.lang.NumberFormatException: For input string: ""
	at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
	at java.lang.Integer.parseInt(Integer.java:504)
	at java.lang.Integer.parseInt(Integer.java:527)
	at sdMain.initialize(sdMain.java:501)
	at sdMain.main(sdMain.java:676)
Command Line Interface is starting up, please wait ...
Chris Deren
What command are you sending and are you waiting long enough for specific admin prompt as unlike IOS devices for example the CUCM SSH session takes longer to load and it's important to wait/confirm an expected prompt is present before pushing commends.
Now it works with SOPA API (AXLAPI.wsdl).
