Option 150 Problem
sheerazkhatri
I have CCM 4.1(2) and using 3750 switches for DHCP. I often have this problem that when my phones (7912G) boot up, there directory services option is missing although the TFTP server IP (CCM in my case) is mentioned in dhcp configuraton under dhcp option 150. What I do is to delete the dhcp pool from the switch, clear the dhcp bindings and arp cache, re-insert the dhcp pool and restart the phone. This always bring back the dc directory option. Any solution to this? Thank you.
6 Replies 6
paolo bevilacqua
Would you check that you are running the latest firmware on the 7912? Should be
CP7912080002SCCP060817A.sbin
I have CP7912060101SCCP050429B.sbin.
I would upgrade and check again.
bparker
Here is a copy of my pool off my 3750
ip dhcp excluded-address 10.153.5.1 10.153.5.16
ip dhcp excluded-address 10.153.33.1 10.153.33.16
ip dhcp excluded-address 10.153.5.255
ip dhcp pool PC's
network 10.153.5.0 255.255.255.0
default-router 10.153.5.1
dns-server 10.150.1.31 10.11.1.30
ip dhcp pool VOIP-PHONE
network 10.153.33.0 255.255.255.0
default-router 10.153.33.1
option 150 ip 10.153.32.16 10.153.32.17
interface GigabitEthernet1/0/1
switchport access vlan 105
switchport mode access
switchport voice vlan 133
no logging event link-status
no logging event power-inline-status
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
IOS c3750-ipservicesk9-mz.122-25.SEE2
As I said I would upgrade the phone firmware because many troubles are caused by bugs in that.
Let me try upgrading the firmware. Once I had the problem of not picking up the IP from DHCP by 7936 conference stations. I upgraded the firmware and that resolved my problem.
