07-07-2017 12:59 PM - edited 03-17-2019 10:43 AM
Any idea it was working fine .. recently our ISP have a disconnect and restore create problems.. Attached Configuration
Building configuration...
Current configuration : 9556 bytes
version 12.4
service password-encryption
service sequence-numbers
hostname HO_GW_3825_1
boot-start-marker
boot-end-marker
!card type command needed for slot 1
card type e1 2 1
logging buffered 4096
enable secret 5 .
aaa new-model
aaa authentication login default local line
aaa session-id common
no network-clock-participate slot 1
network-clock-participate slot 2
network-clock-select 1 E1 2/0
dot11 syslog
ip cef
no ip domain lookup
ip domain name bal.com
voice-card 0
no dspfarm
voice-card 1
no dspfarm
voice-card 2
no dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
bind control source-interface Loopback0
bind media source-interface Loopback0
voice class h323 1
h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /^1......../ /9602/
rule 2 /^5......../ /9602/
voice translation-profile outgoing
translate calling 1
crypto pki trustpoint TP-self-signed-3729740792
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3729740792
revocation-check none
rsakeypair TP-self-signed-3729740792
crypto pki certificate chain TP-self-signed-3729740792
certificate self-signed 01
30820252 308201BB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33373239 37343037 3932301E 170D3130 30313231 30353535
33395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 37323937
34303739 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C7C9 B1B29409 07BE43FC 9D13AD44 23673084 EBB0B091 18EC68F3 3682B58B
95E66698 25131A01 6D406D01 873B1C88 E36A8E32 71173A2E 62110973 A4B520AE
CC64C7D4 0E444245 4AEE1D71 10B21DBD D7475231 FE29AF20 2659C0A2 04E5BD0D
681E5416 8CFCCCBF 8EC5F303 8F6003BA F6B16BCF 22922D78 8CD22438 515C5411
E9130203 010001A3 7A307830 0F060355 1D130101 FF040530 030101FF 30250603
551D1104 1E301C82 1A484F5F 47575F33 3832355F 312E4261 6C736861 7261662E
636F6D30 1F060355 1D230418 30168014 73DA9F19 B279B610 4F47A110 0201CC39
C90A1CA1 301D0603 551D0E04 16041473 DA9F19B2 79B6104F 47A11002 01CC39C9
0A1CA130 0D06092A 864886F7 0D010104 05000381 810040AD F23F4FB7 FFE0B3D8
5FD56D23 6D6F8070 88F8209D F94CCE5C 016D05AA D15791F1 F6BEC56E 4D31BC43
642153DE 62F291A8 810940B8 8D8B9C8A 083DE1FF B07EBDBF 163501D2 922C3DD8
2043BF99 56DA2DE6 8C4D611B 21EBF48D C1F0CEB8 9392C864 3B38B9CF 43D50403
4F3B21FB 65E37512 271EC2C9 4EB4E9D3 CFD1225E 1FFE
quit
username admin privilege 15
archive
log config
hidekeys
controller E1 2/0
framing NO-CRC4
ds0-group 1 timeslots 1-15 type r2-digital r2-compelled ani
ds0-group 2 timeslots 17-30 type r2-digital r2-compelled ani
cas-custom 1
country saudiarabia use-defaults
cas-custom 2
controller E1 2/1
framing NO-CRC4
cas-custom 1
cas-custom 2
interface Loopback0
ip address 10.1.200.9 255.255.255.252
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.200.9
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.1.200.2 255.255.255.252
ip flow ingress
ip flow egress
duplex half
speed auto
media-type rj45
interface GigabitEthernet0/1
description $ES_LAN$
ip address 10.1.201.2 255.255.255.252
ip flow ingress
ip flow egress
duplex half
speed auto
media-type rj45
router eigrp 100
network 10.0.0.0
no auto-summary
ip forward-protocol nd
ip route 10.1.0.0 255.255.255.0 10.1.205.2
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination 10.1.100.40 9996
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 50 permit 10.1.100.105
access-list 50 permit 10.1.100.40
snmp-server community
snmp-server ifindex persist
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps xgcp
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps flash insertion removal
snmp-server enable traps ds3
snmp-server enable traps envmon
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps atm subif
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps memory bufferpeak
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps mpls ldp
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls vpn
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps vsimaster
snmp-server enable traps vtp
snmp-server enable traps pw vc
snmp-server enable traps ccme
snmp-server enable traps srst
snmp-server enable traps voice
snmp-server enable traps dnis
snmp-server host 10.1.100.105
snmp-server host 10.1.100.40
control-plane
voice-port 2/0:1
voice-port 2/0:2
voice-port 2/1:1
voice-port 2/1:2
dial-peer voice 1234 voip
destination-pattern ....
voice-class h323 1
session target ipv4:10.1.100.101
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 4321 voip
voice-class h323 1
session target ipv4:10.1.100.100
codec g711ulaw
dial-peer voice 1111 pots
incoming called-number .
direct-inward-dial
dial-peer voice 103 pots
description International-Calls
destination-pattern .T
port 2/1:2
dial-peer voice 106 pots
port 2/0:2
dial-peer voice 108 pots
description Local
destination-pattern .......
port 2/1:2
forward-digits all
dial-peer voice 109 pots
description national
destination-pattern 0[2345678].......
port 2/1:2
forward-digits all
dial-peer voice 110 pots
description Mobile
translation-profile outgoing outgoing
destination-pattern 05........
port 2/1:2
forward-digits all
dial-peer voice 111 pots
description Local
port 2/0:2
forward-digits all
dial-peer voice 112 pots
port 2/0:2
forward-digits all
dial-peer voice 113 pots
description Mobile
port 2/0:2
forward-digits all
dial-peer voice 1090 pots
description new-national
destination-pattern 01[2346789].......
port 2/1:2
forward-digits all
dial-peer voice 1120 pots
port 2/0:2
forward-digits all
line con 0
line aux 0
line vty 0 4
privilege level 15
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
scheduler allocate 20000 1000
end
07-07-2017 01:32 PM
What does the debugs say?
07-07-2017 04:29 PM
HO_GW_3825_1#debug voip ccapi inout
Syslog logging: enabled (11 messages dropped, 2 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 3427 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 3427 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
Trap logging: level informational, 106 message lines logged
Log Buffer (4096 bytes):
PI/ccIFCallSetupRequestPrivate:
Interface=0x674740C8, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=535811834,(Calling Name=)(TON=Network, NPI=Unknown , Screening=Not Screened, Presentation=Allowed),
Called Number=9722(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10 6, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl ication Call Id=)
Sub Calling(TON=Unknown, NPI=Private, Data=I(g^B6^Xgo8`md^\`mkxg^B7, Length=1 03)
001445: *Jul 6 17:20:45.925: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001446: *Jul 6 17:20:45.925: :cc_get_feature_vsa malloc success
001447: *Jul 6 17:20:45.925: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001448: *Jul 6 17:20:45.925: cc_get_feature_vsa count is 2
001449: *Jul 6 17:20:45.925: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001450: *Jul 6 17:20:45.925: :FEATURE_VSA attributes are: feature_name:0,featur e_time:1730016280,feature_id:630
001451: *Jul 6 17:20:45.925: //630/480A24CC8662/CCAPI/ccIFCallSetupRequestPriva te:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
001452: *Jul 6 17:20:45.925: //630/480A24CC8662/CCAPI/ccCallSetContext:
Context=0x677CAC20
001453: *Jul 6 17:20:45.925: //629/480A24CC8662/CCAPI/ccSaveDialpeerTag:
Outgoing Dial-peer=106
001454: *Jul 6 17:20:46.225: //630/480A24CC8662/CCAPI/cc_api_call_proceeding:
Interface=0x674740C8, Progress Indication=NULL(0)
001455: *Jul 6 17:21:00.917: //629/480A24CC8662/CCAPI/cc_api_call_disconnected:
Cause Value=0, Interface=0x674912E0, Call Id=629
001456: *Jul 6 17:21:00.917: //629/480A24CC8662/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=FALSE, Cause Value=0, Retry Count=0)
001457: *Jul 6 17:21:00.917: //630/480A24CC8662/CCAPI/ccCallDisconnect:
Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Ca use=0)
001458: *Jul 6 17:21:00.917: //630/480A24CC8662/CCAPI/ccCallDisconnect:
Cause Value=0, Call Entry(Responsed=FALSE, Cause Value=0)
001459: *Jul 6 17:21:00.917: //630/480A24CC8662/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
001460: *Jul 6 17:21:00.917: //629/480A24CC8662/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C ause=0)
001461: *Jul 6 17:21:00.917: //629/480A24CC8662/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
001462: *Jul 6 17:21:00.917: //629/480A24CC8662/CCAPI/cc_api_get_transfer_info:
001463: *Jul 6 17:21:01.013: //630/480A24CC8662/CCAPI/cc_api_call_disconnect_do ne:
Disposition=0, Interface=0x674740C8, Tag=0x0, Call Id=630,
Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
001464: *Jul 6 17:21:01.013: //630/480A24CC8662/CCAPI/cc_api_call_disconnect_do ne:
Call Disconnect Event Sent
001465: *Jul 6 17:21:01.013: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001466: *Jul 6 17:21:01.013: :cc_free_feature_vsa freeing 671DF410
001467: *Jul 6 17:21:01.013: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001468: *Jul 6 17:21:01.013: vsacount in free is 1
001469: *Jul 6 17:21:01.061: //629/480A24CC8662/CCAPI/cc_api_call_feature:
Feature Type=6, Interface=0x674912E0, Call Id=629
001470: *Jul 6 17:21:03.065: //629/480A24CC8662/CCAPI/cc_api_call_disconnect_do ne:
Disposition=0, Interface=0x674912E0, Tag=0x0, Call Id=629,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
001471: *Jul 6 17:21:03.065: //629/480A24CC8662/CCAPI/cc_api_call_disconnect_do ne:
001472: *Jul 6 17:21:03.065: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001473: *Jul 6 17:21:03.065: :cc_free_feature_vsa freeing 671DF338
001474: *Jul 6 17:21:03.065: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001475: *Jul 6 17:21:03.065: vsacount in free is 0
001476: *Jul 6 17:24:03.065: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
ccAppShutdownMode: remove it from the queue
HO_GW_3825_1#debug mgcp all
This may severely impact network performance. Continue[confirm]yMedia Gateway Control Protocol all debugging is on, trace-level Verbose
H.225:
H.225 Q931 IE Details debugging is on
CCAPI:
debug voip ccapi inout is ON (filter is OFF)
MGCP:
Media Gateway Control Protocol media events debugging is on, trace level Verbose
Media Gateway Control Protocol nas pkg events debugging is on, trace level Verbose
Media Gateway Control Protocol events debugging is on, trace level Verbose
Media Gateway Control Protocol errors debugging is on
Media Gateway Control Protocol packets debugging is on
Media Gateway Control Protocol parser debugging is on, trace level Verbose
Media Gateway Control Protocol VoIPCAC debugging is on, trace level Verbose
Media Gateway Control Protocol System Resource Check CAC debugging is on, trace level Verbose
Media Gateway Control Protocol endpoint database debugging is on, trace level Verbose
Media Gateway Control Protocol state transition debugging is on, trace level Verbose
Media Gateway Control Protocol inout debugging is on, trace level Verbose
Media Gateway Control Protocol gcfm debugging is on, trace level Verbose
HO_GW_3825_1#show logging
Console logging: level debugging, 863 messages logged, xml disabled,
filtering disabled
filtering disabled
Buffer logging: level debugging, 863 messages logged, xml disabled,
filtering disabled
E)
000401: *Jul 6 13:40:15.722: //596/7A37885D85FE/CCAPI/cc_api_call_alert:
Interface=0x67027268, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
000402: *Jul 6 13:40:15.722: //596/7A37885D85FE/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
000403: *Jul 6 13:40:15.722: //595/7A37885D85FE/CCAPI/ccCallAlert:
000404: *Jul 6 13:40:15.722: //595/7A37885D85FE/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, AlertSent=TRUE)
000405: *Jul 6 13:40:15.726: //596/7A37885D85FE/CCAPI/cc_api_set_called_ccm_detected:
CallInfo(called ccm detected=TRUE ccmVersion 3)
000406: *Jul 6 13:40:15.726: //596/7A37885D85FE/CCAPI/cc_api_call_notify:
Data Bitmask=0x7, Interface=0x67027268, Call Id=596
000407: *Jul 6 13:40:15.726: //596/7A37885D85FE/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
CallInfo(ssCTreRoutingNotSupported=FALSE)
000408: *Jul 6 13:40:15.726: //596/7A37885D85FE/CCAPI/cc_api_get_ccm_detected:
CallInfo(ccm detected=TRUE)
000409: *Jul 6 13:40:15.726: //595/7A37885D85FE/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=595
000410: *Jul 6 13:40:48.310: //595/7A37885D85FE/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x674912E0, Call Id=595
000411: *Jul 6 13:40:48.310: //595/7A37885D85FE/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
000412: *Jul 6 13:40:48.310: //595/7A37885D85FE/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Network, Params=0x0, Call Id=595
000413: *Jul 6 13:40:48.310: //596/7A37885D85FE/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
000414: *Jul 6 13:40:48.310: //596/7A37885D85FE/CCAPI/ccCallDisconnect:
000415: *Jul 6 13:40:48.310: //596/7A37885D85FE/CCAPI/cc_api_get_transfer_info:
000416: *Jul 6 13:40:48.314: //595/7A37885D85FE/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
000417: *Jul 6 13:40:48.314: //595/7A37885D85FE/CCAPI/ccCallDisconnect:
000418: *Jul 6 13:40:48.314: //595/7A37885D85FE/CCAPI/cc_api_get_transfer_info:
000419: *Jul 6 13:40:48.314: //596/7A37885D85FE/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x67027268, Tag=0x0, Call Id=596,
000420: *Jul 6 13:40:48.314: //596/7A37885D85FE/CCAPI/cc_api_call_disconnect_done:
000421: *Jul 6 13:40:48.314: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000422: *Jul 6 13:40:48.314: :cc_free_feature_vsa freeing 671DF338
000423: *Jul 6 13:40:48.314: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000424: *Jul 6 13:40:48.314: vsacount in free is 1
000425: *Jul 6 13:40:50.314: //595/7A37885D85FE/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x674912E0, Tag=0x0, Call Id=595,
000426: *Jul 6 13:40:50.314: //595/7A37885D85FE/CCAPI/cc_api_call_disconnect_done:
000427: *Jul 6 13:40:50.314: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000428: *Jul 6 13:40:50.314: :cc_free_feature_vsa freeing 671DF410
000429: *Jul 6 13:40:50.314: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000430: *Jul 6 13:40:50.314: vsacount in free is 0
000431: *Jul 6 13:43:50.314: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
000432: *Jul 6 13:45:53.998: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_by_ifn(1326):[lvl=0]Entered
000433: *Jul 6 13:45:53.998: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_tree_link_by_ifn(1145):[lvl=0]Entered
000434: *Jul 6 13:45:53.998: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_tree_link_by_ifn(1152):[lvl=2]endptdb for protocol 0 does not exist.
HO_GW_3825_1#debug h225 q931
H.225:
CCAPI:
Console logging: level debugging, 858 messages logged, xml disabled,
filtering disabled
filtering disabled
Buffer logging: level debugging, 858 messages logged, xml disabled,
filtering disabled
000398: *Jul 6 13:40:15.718: //596/7A37885D85FE/CCAPI/cc_api_call_proceeding:
000399: *Jul 6 13:40:15.722: //596/7A37885D85FE/CCAPI/cc_api_set_called_ccm_detected:
000400: *Jul 6 13:40:15.722: //596/7A37885D85FE/CCAPI/cc_api_set_delay_xport:
CallInfo(delay xport=TRUE)
While outgoing no dial from Ip phone calls are shown in Voice GW router as below
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0x251 1095 0x674AE524 2/1:2.29 2/1:1 *0541752xxx None 1234/110
after some time it will disconnect .. No problem for any incoming call as well inside local extensions (Intercom ext) working fine.
