outbound call routing
Hi All,
I had some headache for a month. i trying to configure outbound call with specific line ISDN, here is my configuration for outbound :
dial-peer cor custom
name 1xx
name 8xx
name 2xx
name 5xx
dial-peer cor list Allow1xx
member 1xx
member 2xx
dial-peer cor list Allow8xx
member 8xx
member 5xx
dial-peer voice 1 pots
corlist outgoing Allow1xx
tone ringback alert-no-PI
translation-profile incoming 2
translation-profile outgoing 1
destination-pattern 9.T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number 81..
no digit-strip
direct-inward-dial
port 0/1/0:15
forward-digits all
dial-peer voice 3 pots
corlist outgoing Allow8xx
incoming called-number 88..
no digit-strip
direct-inward-dial
port 0/2/0:15
forward-digits all
i want my 2xx extension outbound call through same ISDN line with 1xx, and then my 5xx through same ISDN line with 8xx.
but with the configuration above, my outbound calls still round robin, i'm already googling but still stuck.
Any body could help me please ?
22 Replies 22
MOHIT SINGH
Hi Yudistra,
Both dial peers have same pattern "9.T" so one of them will be matched randomly despite of COR list configuration. What I will suggest is you configure an inbound translation on ephone DNs to add a prefix to called number based on extension and configure outbound dial peer pattern to match the prefix. This way you can segregate selection of outbound dial peer
Hi Mohit,
IMO, it is not a correct behavior. COR list configuration will prevent matching outbound dial peer based on corlist assigned to inbound dial peer, hence having same destination pattern should not be an issue here. With corlist configuration in place, only those outbound dial peers are checked which is allowed as per corlist configuration and then destination-pattern is matched.
Hi Yudistira,
Can you please share show run.
- Vivek
Hi Mohit and Vivek
Thank you for your reply, yes i set 9.T as destination pattern because i want to keep users consistency call outbound, if i making different pattern it will confused users and also my management will rejected the options.
I attached the show run by the way.
Thank you.
I can not see any ephone or SIP phone configuration, your call control is CME or CUCM?
- Vivek
Hi Vivek,
I use CUCM as my call control, and connecting by H.323 Gateway.
Thank you.
Hi Yudistira,
Let us try to fix it for one extension range. As you mentioned before, you would like the extensions 5XX to use dial-peer voice 3 pots for outbound call.
Since you have applied corlist incoming Allow8XX to dial-peer voice 992, it should select the outbound dial peer 3 pots as the same corlist is applied to dial peer 3 in outbound direction. For calls made from 5XX, if respective outbound dial peer is not being used, call may be hitting incorrect dial peer.
Please make a test call from 5XX and get the output of debug voice ccapi inout and share the same.
Also note that there are many other dial peers (seems analog ports) which can also handle the calls made to 9.T pattern and since no corlist is assigned to those dial peers, any inbound call from CUCM can use those outbound dial peers irrespective of the corlist assigned to inbound dial peers.
- Vivek
Hi Vivek,
I'm Already debug voice ccapi inout, but no result on my router, it's weird for me. As you see i have 3 pots for outboound calls, 1, 2, and 3. which pots number 2 is for 3xx number. but like i mentioned early the outbound calls from 2xx and 5xx just round robin at pots 1 and 3. never through pots 2. Any suggestions ?
Thank you.
You have answer-address command in three DP's viz 990, 991 and 992. These three dial peers seem to match ANI of 1xx, 3xx and 8xx respectively as per answer-address command configured. Hence I don't know which inbound dial peer is being used for calls with ANI of 2xx and 5xx.
I suggest your should review your configuration and explicitly document the following for us to assist you further;
1. Calls from 1XX
Inbound dial peer - ?
Outbound dial peer - ?
2. Calls from 2XX
3. Calls from 3XX
4. Calls from 5XX
5. Calls from 8XX
- Vivek
Hi Vivek,
Maybe this will help :
1. Calls from 1XX
Inbound dial peer 990 voip
Outbound dial peer 1 pots
2. Calls from 2XX
3. Calls from 3XX
Inbound dial peer 991 voip
Outbound dial peer 2 pots
4. Calls from 5XX
Inbound dial peer 992 voip
Outbound dial peer 3 pots
5. Calls from 8XX
In my opinion since 2xx as member Allow1xx and 5xx member Allow8xx it will create also as answer-address dial-peer 990 and 993. is it right ?
when someone calling 28548844 it will be directed into extension 844 and so on. But 2xx and 5xx no have DID numbers, I just want to create outbound calls for those extension.
FYI, FXO line is for my backup line.
Thank you.
Your configuration for calls from 1XX, 3XX and 8XX looks good because of answer-address configuration, however it doesn't work we will have to see debug voice ccapi inout logs to verify whether calls are hitting desired dial peer or not.
I didn't exactly get your point but you should note that you need to explicitly define 'answer-address' command to match the calls from 2XX and 5XX since inbound dial peer is matched before checking CoR configuration.
You can have following two additional dial peers to take care of 2XX and 5XX calls;
dial-peer voice 993 voip
 corlist incoming Allow1xx
 answer-address 285482..
 voice-class codec 1
 dtmf-relay h245-alphanumeric
 ip qos dscp cs5 media
 ip qos dscp cs4 signaling
 no vad
dial-peer voice 994 voip
 corlist incoming Allow8xx
 answer-address 285485..
 voice-class codec 1
 no vad
Please note that if you don't apply CoR list to FXO dial peers, it will be selected by any inbound dial peer. You need to carefully apply CoR list to FXO dial peer as well and add 'preference' command so that these dial peers are used as backup only.
- Vivek
Hi VIvek,
Is it related with outbound call for 2xx and 5xx, because 258548xxx is my ISDN from telco there is only 2585481xx , 2585483xx and 2585488xx so i can't create 2585482xx and 2585485xx.
I'm sorry if my questions making you confused. Because this is my first time configure voice gateway.
I'll do.
Thank you.
Ya, seems some sort of confusion but I will try to nail it down as much as possible for me :)
So we are talking about outbound calls only from CUCM to gateway, correct?
Now if you have extensions only in the range of 1XX, 3XX and 8XX, then your configuration looks good as per following;
1. Calls from 1XX
2. Calls from 3XX
3. Calls from 8XX
Inbound dial peers with 'answer-address' and corlist is already configured and outbound dial peers are also configured with respective corlist. If intended outbound dial peer is not being selected, please share the output of debug voice ccapi inout so that we can check where the issue is.
- Vivek
Hi Vivek,
Could I configure like this :
voice translation-rule 5
Rule 1 /\(2..\/ /28548100\1/
voice translation-rule 6
Rule 1 /\(5..\/ /28548800\1/
voice translation-profile out_2xx
translate calling 5
voice translation-profile out_5xx
translate calling 6
voice-port 0/1/0:15
translation-profile incoming 3
translation-profile outgoing out_2xx <-- Adding Here
cptone ID
timeouts initial 1
timeouts interdigit 2
bearer-cap Speech
voice-port 0/2/0:15
translation-profile outgoing out_5xx <--Adding Here
cptone ID
timeouts initial 1
bearer-cap Speech
Without disrupted existing inbound and outbound calls for 1xx, 3xx, and 8xx ?
Thank you for guiding me so far.
When you apply translations to voice port, this has nothing to do with CoR since voice-port is selected at the end of call routing logic, so I really don't know what you are trying to achieve here.
But I can tell you from configuration that when port 0/1/0:15 will be selected for outbound call, it will translate the ANI with 2XX to 285481002XX. Similarly for port 0/2/0:15, ANI with 5XX will be translated to 285488005XX. That is what you want to achieve?
- Vivek
