02-29-2016 08:17 PM - edited 03-17-2019 06:05 AM
Hi All,
I had some headache for a month. i trying to configure outbound call with specific line ISDN, here is my configuration for outbound :
dial-peer cor custom
name 1xx
name 8xx
name 2xx
name 5xx
dial-peer cor list Allow1xx
member 1xx
member 2xx
dial-peer cor list Allow8xx
member 8xx
member 5xx
dial-peer voice 1 pots
corlist outgoing Allow1xx
tone ringback alert-no-PI
translation-profile incoming 2
translation-profile outgoing 1
destination-pattern 9.T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number 81..
no digit-strip
direct-inward-dial
port 0/1/0:15
forward-digits all
dial-peer voice 3 pots
corlist outgoing Allow8xx
incoming called-number 88..
no digit-strip
direct-inward-dial
port 0/2/0:15
forward-digits all
i want my 2xx extension outbound call through same ISDN line with 1xx, and then my 5xx through same ISDN line with 8xx.
but with the configuration above, my outbound calls still round robin, i'm already googling but still stuck.
Any body could help me please ?
03-03-2016 01:21 AM
Hi Vivek.
no, actually what i was want to achieve is all outbound calls from extension 2xx should be translated to 28548100 and outbound calls from 5xx should be translated into 28548800, where the 28548100 number is on port 0/1/0:15 and 28548800 is on port 0/2/0:15.
So that's why i wanted my 2xx extensions outbound call use same line with 1xx and my 5xx same line with 8xx.
Thank you :).
03-03-2016 01:26 AM
Ok, then translations should look like as;
voice translation-rule 5
Rule 1 /^2..$/ /28548100/
voice translation-rule 6
Rule 1 /^5..$/ /28548800/
- Vivek
03-03-2016 01:38 AM
Hi Vivek,
So it will look like this :
voice translation-profile out_2xx
translate calling 5
voice translation-profile out_5xx
translate calling 6
voice-port 0/1/0:15
translation-profile incoming 3
translation-profile outgoing out_2xx <-- Adding Here
cptone ID
timeouts initial 1
timeouts interdigit 2
bearer-cap Speech
voice-port 0/2/0:15
translation-profile outgoing out_5xx <--Adding Here
cptone ID
timeouts initial 1
bearer-cap Speech
And my existing outbound call will running well ? in example my ANI 801 will go out as 28548801 and so on ? Or should be placed on my dial-peer pots ?
Thank you
03-03-2016 04:20 AM
To change the ANI for 2XX and 5XX, translations seem good as long as you are getting 3 digits ANI from CUCM, but I have noticed that you are getting 8 digits ANI from CUCM, Is it? (as configured with answer-address command).
So if you are getting 8 digits ANI, above translation won't not work as it's matching 3 digits ANI. Moreover as I told before, you don't have inbound dial peer (answer-address) command configured for 2XX and 5XX, so we came back on the same point :) I strongly suggest you to check which inbound dial peer is being used for calls from 2XX and 5XX.
With CoR list in place, calls from 801 will hit inbound dial peer 992 and select dial peer 3 for outbound call. Under dial peer 3, you have applied translation profile 1 for outbound calls. Under translation profile 1, you are only translating called number, not calling number. So IMO, what you are trying to achieve won't work with existing configuration. Is it working?
- Vivek
03-02-2016 05:08 AM
Hi Yudistira,
As you are using CUCM so i don't think COR list is the correct way to segregate outbound dial peers based on the calling extension (if this is your only requirement).
You can configure inbound dial peers using "answer-address" and match it using calling party number. For ex; answer-address [1,2]... and answer-address [5,8]...
Add an incoming translation on these inbound dial peers and add prefix to called number for ex "1" for "answer-address [1,2]..." So called number becomes 19T. To send the call out using specific PRI create an outbound dial peer with destination pattern 19T. Now any outbound call with calling number 1XXX or 2XXX will be routed using dial peer with 19T pattern.
Similarly you can configure for 5XXX and 8XXX extension. Users can continue to use prefix "9" from any extension to dial out.
To use "answer-address" you have to make sure "incoming called-number " is not configured on any dial peer as it has higher priority than answer address.
03-02-2016 07:31 PM
Hi Mohit,
As you see on my attachment, i using DID for incoming and outgoing some numbers, so i think if I configure like what you said, it will erase the DID. is it wrong ? please correct me.
Thank you
03-02-2016 04:44 AM
Hi Vivek
For call routing, first outbound dial peer is selected based on destination pattern then the router checks if the outgoing COR list assigned to the OB dial peer is a subset of the inbound COR list. If it is a subset then call is allowed otherwise the call will fail using that dial peer.
In this case both the DP have same pattern (9.T) that's why for him DP is matched in round robin.
03-02-2016 06:22 AM
Hi Mohit,
Interesting. I would like to nail it down as I was always in the opinion that once inbound dial peer is selected, all dial peers are grouped together which are subset of inbound COR list and then then called number is matched with the destination-pattern among the subset dial peers.
If what you are saying is true where let say two dial peers are configured with same destination patterns and only one of the outbound dial peer is the subset of COR list assigned to inbound dial peer, first call attempt will route the call, then drop and then route and so on.
To validate the same, I configure the following;
name emergency
name local
dial-peer cor list 3001
member emergency
dial-peer cor list 3002
member local
dial-peer voice 901 voip
corlist outgoing 3001
session protocol sipv2
session target ipv4:192.168.15.10
dial-peer voice 902 voip
corlist outgoing 3002
session target ipv4:192.168.15.14
ephone-dn 1
number 3001
corlist incoming 3001
Now if I dial 999 from DN 3001 which is assigned corlist incoming 3001, then always dial peer 901 is selected and call is always sent to 192.168.15.10.
If what you are saying is true and there is a second call attempt from DN 3001 to 999, dial peer 902 should be selected and since COR list assigned to dial peer 902 is not a subset of inbound COR list, call will fail, but that is not the case. Call doesn't fail and always selects dial peer 901.
What do you think?
- Vivek
