Outgoing Calls SiP Cube
martynch1
Wonder if you could help me out here, I'm currently setting up a new cube but hitting problems placing outgoing calls, incoming calls are working fine, if I place an outgoing call to my mobile number I get a message (I can hear it) Sorry the service you require can not be connected.  Below you will find my running config stripped and a few debugs.
Debug ccsip call
Jul 13 07:16:08.075: //96612/B2C67D800000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7F0626233170
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 45000
Called Number            : 07973xxxxxx
Source IP Address (Sig  ): 10.2.251.57
Destn SIP Req Addr:Port  : 82.16.19.2:5060
Destn SIP Resp Addr:Port : 82.16.19.2:5060
Destination Name         : 82.16.19.2
Jul 13 07:16:08.075: //96612/B2C67D800000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711alaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 8 (tx), 8 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 10.2.251.57
Source IP Port    (Media): 8190
Destn  IP Address (Media): 82.16.19.18
Destn  IP Port    (Media): 10100
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 487
Jul 13 07:16:08.076: //96616/B2C67D800000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7F0626241C80
TCP Sockets Used         : YES
Destn SIP Req Addr:Port  : :0
Destn SIP Resp Addr:Port : :0
Destination Name         :
Jul 13 07:16:08.077: //96616/B2C67D800000/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Port    (Media): 8192
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Jul 13 07:16:08.077: //96616/B2C67D800000/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 188
Disconnect Cause (SIP)   : 200
Jul 13 07:16:08.080: //96611/B2C67D800000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7F062621D0D8
Source IP Address (Sig  ): 10.0.12.30
Destn SIP Req Addr:Port  : 10.0.12.17:5060
Destn SIP Resp Addr:Port : 10.0.12.17:34867
Destination Name         : 10.0.12.17
Jul 13 07:16:08.080: //96611/B2C67D800000/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Address (Media): 10.0.12.30
Source IP Port    (Media): 8188
Destn  IP Address (Media): 172.30.152.11
Destn  IP Port    (Media): 32362
Disconnect Cause (CC)    : 38
Disconnect Cause (SIP)   : 503
Debug ccsip message
Jul 13 07:10:30.638: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:07973xxxxxx@10.0.12.30:5060 SIP/2.0
Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eead65cae8f3
From: "VM SIP TEST 2" <sip:45000@10.0.12.17>;tag=404459~9c2c55f8-f6da-4001-942f-f8cb268e11d0-49787915
To: <sip:0797xxxxxx@10.0.12.30>
Date: Mon, 13 Jul 2020 07:10:30 GMT
Call-ID: ee147c80-f0c108e6-15b0f-110c000a@10.0.12.17
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM11.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Session-ID: 30bca1117401e23b8117f8034def3ba0;remote=00000000000000000000000000000000
Cisco-Guid: 3994320000-0000065536-0000004169-0285999114
Session-Expires:  1800
P-Asserted-Identity: "VM SIP TEST 2" <sip:45000@10.0.12.17>
Contact: <sip:45000@10.0.12.17:5060;transport=tcp>
Max-Forwards: 70
Content-Length: 0
Jul 13 07:10:30.642: //96514/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <sip:07973xxxxxx@10.0.12.30>
CSeq: 101 INVITE
Allow-Events: kpml, telephone-event
Server: Cisco-SIPGateway/IOS-16.6.6
Session-ID: 00000000000000000000000000000000;remote=30bca1117401e23b8117f8034def3ba0
Content-Length: 0
Jul 13 07:10:30.645: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:07973xxxxxx@82.16.19.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12084228B
From: "VM SIP TEST 2" <sip:45000@10.2.251.57>;tag=14803119-1814
To: <sip:07973xxxxxx@82.16.19.2>
Call-ID: C544F9D6-C40E11EA-B9A3B5A2-101A3230@10.2.251.57
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-16.6.6
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1594624230
Contact: <sip:45000@10.2.251.57:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
P-Asserted-Identity: "VM SIP TEST 2" <sip:45000@10.2.251.57>
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 243
v=0
o=CiscoSystemsSIP-GW-UserAgent 1948 8484 IN IP4 10.2.251.57
s=SIP Call
c=IN IP4 10.2.251.57
t=0 0
m=audio 8184 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Jul 13 07:10:30.649: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.0.12.30:5060 SIP/2.0
Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eeae2d555626
To: <sip:10.0.12.30>
Call-ID: ee147c80-f0c108e6-15b10-110c000a@10.0.12.17
CSeq: 101 OPTIONS
Contact: <sip:10.0.12.17:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Jul 13 07:10:30.651: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.0.12.30>;tag=1480311F-2001
CSeq: 101 OPTIONS
Accept: application/sdp
Content-Length: 163
v=0
o=CiscoSystemsSIP-GW-UserAgent 8832 2086 IN IP4 10.0.12.30
s=SIP Call
c=IN IP4 10.0.12.30
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
c=IN IP4 10.0.12.30
Jul 13 07:10:30.654: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Jul 13 07:10:30.662: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Proxy-Authenticate: Digest realm="Realm",nonce="MTU5NDYyMDIyMTg3NjU3ZTRlZGJjZTRiNTdlYjQ4OGU5NTFiMzQyY2Q1Yzc5",stale=false,algorithm=MD5,qop="auth"
To: <sip:07973xxxxxx@82.16.19.2>;tag=3803613030-698069643
From: "VM SIP TEST 2" <sip:45000@10.2.251.57;user=phone>;tag=14803119-1814
CSeq: 101 INVITE
Allow: UPDATE,PRACK,INFO,NOTIFY,OPTIONS,BYE,INVITE,ACK,CANCEL
Contact: <sip:07973xxxxxx@82.16.19.2:5060>
Content-Length: 0
Jul 13 07:10:30.663: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:07973xxxxxx@82.16.19.2:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: ;remote=
Content-Length: 0
Jul 13 07:10:30.664: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.2.251.57:5060;branch=z9hG4bK12085A0C
Min-SE:  1800
CSeq: 102 INVITE
Expires: 180
Proxy-Authorization: Digest username="onboard09",realm="Realm",uri="sip:07973xxxxxx@82.16.19.2:5060",response="ad85f4c9c9878a2375cec50674659789",nonce="MTU5NDYyMDIyMTg3NjU3ZTRlZGJjZTRiNTdlYjQ4OGU5NTFiMzQyY2Q1Yzc5",cnonce="E6D38045",qop=auth,algorithm=MD5,nc=00000001
Max-Forwards: 69
Content-Length: 243
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
Jul 13 07:10:30.673: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
Jul 13 07:10:30.725: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <sip:07973xxxxxx@82.16.19.2>;tag=3803613030-1020988772
CSeq: 102 INVITE
Content-Length: 252
v=0
o=brnt-voiponboardsbc1-a 201206121 201206121 IN IP4 82.16.19.2
s=sip call
c=IN IP4 82.16.19.18
t=0 0
m=audio 10098 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
a=silenceSupp:off - - - -
Jul 13 07:10:30.728: //96514/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:07973xxxxxx@10.0.12.30>;tag=1480316D-1AD7
CSeq: 101 INVITE
Require: 100rel
RSeq: 8573
Contact: <sip:07973xxxxxx@10.0.12.30:5060;transport=tcp>
Supported: sdp-anat
Session-ID: 58d9216120e7570f97bc8825f965a0f7;remote=30bca1117401e23b8117f8034def3ba0
Content-Length: 240
v=0
o=CiscoSystemsSIP-GW-UserAgent 3781 3104 IN IP4 10.0.12.30
s=SIP Call
c=IN IP4 10.0.12.30
t=0 0
m=audio 8182 RTP/AVP 8 101
c=IN IP4 10.0.12.30
a=fmtp:101 0-15
a=ptime:20
Jul 13 07:10:30.793: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:07973xxxxxx@10.0.12.30:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.12.17:5060;branch=z9hG4bK1eeaf1d80c380
CSeq: 102 PRACK
RAck: 8573 101 INVITE
Max-Forwards: 70
Content-Length: 245
v=0
o=CiscoSystemsCCM-SIP 404459 1 IN IP4 10.0.12.17
s=SIP Call
c=IN IP4 172.30.152.11
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 32116 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
Jul 13 07:10:30.796: //96514/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Jul 13 07:10:31.209: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.0.12.16:5060;branch=z9hG4bK6bae22f24ecca
Date: Mon, 13 Jul 2020 07:10:31 GMT
Call-ID: eead1300-f0c108e7-4aa6e-100c000a@10.0.12.16
CSeq: 101 OPTIONS
Contact: <sip:10.0.12.16:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Jul 13 07:10:31.211: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.0.12.30>;tag=14803350-A2F
CSeq: 101 OPTIONS
Content-Length: 163
v=0
o=CiscoSystemsSIP-GW-UserAgent 4174 9701 IN IP4 10.0.12.30
s=SIP Call
c=IN IP4 10.0.12.30
t=0 0
c=IN IP4 10.0.12.30
Jul 13 07:10:37.860: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
To: <sip:0797xxxxxx@82.16.19.2>;tag=3803613030-1020988772
CSeq: 102 INVITE
Content-Length: 0
Jul 13 07:10:37.862: //96515/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Jul 13 07:10:37.865: //96514/EE147C800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
CSeq: 101 INVITE
Reason: Q.850;cause=0
Content-Length: 0
Jul 13 07:10:37.867: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:07973xxxxxx@10.0.12.30:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Debug ccisp error
SIP: (96454) Group (a= group line) attribute, level 65535 instance 1 not found.
SIP: Attribute mid, level 1 instance 1 not found.
SIP: setup attribute, level 1 instance 1 not found.
SIP: connection attribute, level 1 instance 1 not found.
SIP: Attribute label, level 1 instance 1 not found.
SIP: a=framerate attribute, level 1 instance 1 not found.
Jul 13 07:07:03.183: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
 Unexpected VoIPCodec Type :No Codec
SIP: (96453) Group (a= group line) attribute, level 65535 instance 1 not found.
Jul 13 07:07:03.184: //96454/72B2CB000000/SIP/Error/sipSPIGetNewLocalMediaDirection:
 Unknown media direction (0) from remote end
Jul 13 07:07:03.225: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
 Freeing NULL pointer!
Jul 13 07:07:03.227: //96453/72B2CB000000/SIP/Error/sipSPIGetNewLocalMediaDirection:
Jul 13 07:07:10.158: //96453/72B2CB000000/SIP/Error/sipSPIFlushDeferredQueue:
 Invalid deferredQueue
Jul 13 07:07:10.165: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIRemoveBranchName:
 invalid ccb, bName or branch list for sipSPIRemoveBranchName
Jul 13 07:07:10.169: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_iwf_process_event:
 Dead CCB
Jul 13 07:07:10.169: //96454/72B2CB000000/SIP/Error/ccsip_offer_ans_md_invite_ack_answer_sent_hdlr:
 Unable to send ACK sent peer event
And finally my running config
no voice hunt unassigned-number
no voice hunt no-response
no voice hunt dest-out-of-order
no voice hunt invalid-number
voice call send-alert
voice rtp send-recv
voice service voip
 mode border-element license capacity 200
 allow-connections sip to sip
 redirect ip2ip
 fax protocol pass-through g711alaw
 sip
  session refresh
  header-passing
  subscription maximum originate 2
  asserted-id pai
  privacy pstn
  options-ping 60
  no update-callerid
  early-offer forced
  midcall-signaling passthru
  privacy-policy passthru
voice class e164-pattern-map 9
 description *** PSTN Numbers Outbound ***
  e164 +800T
  e164 +44T
  e164 ^1800[01]$
  e164 ^999$
  e164 ^11[68]...$
  e164 ^1..$
  e164 ^[01]T
  e164 ^[02]T
  e164 ^[2]T
voice class dpg 90
 description *** SBC DPG ***
 dial-peer 90 preference 1
 dial-peer 91 preference 2
voice class dpg 1000
 description *** CUCM DPG ***
 dial-peer 1000 preference 1
 dial-peer 1001 preference 2
voice class sip-options-keepalive 1
 description ** global options pings settings **
 up-interval 30
 retry 3
 transport udp
voice translation-rule 1
 rule 1 /^\([127-9]......\)$/ /0115\1/
voice translation-profile BlockedNumbers
 translate calling 777
voice translation-profile OutboundCalledPartyforShortDIAL
 translate called 1
interface GigabitEthernet0/0/0
 ip address 10.2.251.57 255.255.255.252
 no ip redirects
 no ip proxy-arp
 media-type rj45
 negotiation auto
interface GigabitEthernet0/0/1
 ip address 10.0.12.30 255.255.255.0
 no ip redirects
 no ip proxy-arp
 negotiation auto
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 9 voip
 description ** INBOUND Dial-Peer from SIP Platform **
 translation-profile incoming BlockedNumbers
 call-block disconnect-cause incoming unassigned-number
 session protocol sipv2
 session transport udp
 destination dpg 1000
 incoming uri via ITSP
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0/0
 voice-class sip bind media source-interface GigabitEthernet0/0/0
 dtmf-relay rtp-nte
 ip qos dscp cs3 signaling
 no vad
dial-peer voice 10 voip
 description *** CUCM to CUBE (inbound) ***
 translation-profile incoming OutboundCalledPartyforShortDIAL
 session transport tcp
 destination dpg 90
 incoming uri via CUCM
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0/1
 voice-class sip bind media source-interface GigabitEthernet0/0/1
 dtmf-relay rtp-nte sip-kpml
 no vad
dial-peer voice 1000 voip
 description *** CUBE to CUCM LOX-SUB 1 (outbound) ***
 preference 1
 destination-pattern 69...
 session target ipv4:10.0.12.17
 voice-class sip options-keepalive profile 1
 codec g711alaw
 no vad
dial-peer voice 90 voip
 description *** SBC3 Birmingham - Preferred Route ***
 preference 1
 destination-pattern .T
 session target ipv4:xx.xx.xx.xx
 voice-class sip options-ping 60
 voice-class sip options-keepalive retry 3
 dtmf-relay rtp-nte
 dtmf-interworking rtp-nte
 codec g711alaw
 no vad
dial-peer voice 1001 voip
 description *** CUBE to CUCM WTG-SUB 1(outbound) ***
 preference 2
 session target ipv4:SUBSCRIBER
 codec g711alaw
 no vad
dial-peer voice 1002 voip
 description *** CUBE to CUCM PUB (outbound) ***
 preference 3
 session target ipv4:PUBLISHER
 codec g711alaw
 no vad
dial-peer hunt 1
sip-ua
 authentication username XXXXX password 7 XXXXX
 no remote-party-id
 aaa username proxy-auth
 retry invite 4
 timers options 600
 reason-header override
 connection-reuse
Thanks in advance
Martyn
31 Replies 31
Thanks for the detailed response I will approach our ITSP
What are you using to show your call flow diagram?
Martyn
Its Translator X.
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
