01-18-2008 02:01 AM - edited 03-15-2019 08:17 AM
My topic is quit simple to be honest.I need to know if there is an operational way to import contacts from an Outlook 2003 account to the Personal address book of an Ip phone.
My company uses Windows Exchange 2003,CCM
5.1.3 and the ip phones are 7970/61/40 series. Any advice or help will be appreciated
Thanks in advance J.Kapiris
01-18-2008 05:59 AM
You can use the IP Phone Address Book Synchronizer. See the following link.
Hope this helps. If so, please rate the post.
Brandon
01-18-2008 08:29 AM
Remember though, it does not sync with Outlook, it only syncs with Outlook Express. So you have to export your contacts from Outlook to Outlook Express, **THEN** run the sync tool. (kind of a pain)
cheers
