Output from: Debug VoIP CCAPI INOUT
JustForVoice_2
Level 4
Level 4
I have a trunk from CUCM to GW.
In the GW I created the following dial-peer to accept any call:
dial-peer voice 15 voip
 session protocol sipv2
 incoming called-number .
But no match!
In CUCM the SIP trunk status: Unknown - OPTIONS Ping not enabled
Options ping is under the sip profile settings..Apply it to the sip profile used on the sip trunk..Then reset the trunk
Please rate all useful posts
6 Replies 6
JustForVoice_2
Level 4
Level 4
*DATE:51.859: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x7AA8FF17BB80, Interface Type=9, Destination=0.0.0.0, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*DATE:51.859: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*DATE:51.859: :cc_get_feature_vsa malloc success
*DATE:51.859:  cc_get_feature_vsa count is 1
*DATE:51.859: :FEATURE_VSA attributes are: feature_name:0,feature_time:140364013349612,feature_id:29
*DATE:51.859: //221/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
*DATE:51.859: //221/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x7FA8FF893A70
   Interface=0x7FA8FF0F6268, Interface Type=25, Destination=, Mode=0x0,
*DATE:51.859:  cc_get_feature_vsa count is 2
*DATE:51.860: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*DATE:51.860: :FEATURE_VSA attributes are: feature_name:0,feature_time:140364013349388,feature_id:30
*DATE:51.860: //222/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Interface=0x7FA8FF0F6268, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*DATE:51.860: //222/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=25, FlowMode=1
*DATE:51.860: //222/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x7FA8FF893AA0
*DATE:51.860: //221/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Interface=0x7AA8FF17BB80, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
*DATE:51.860: //222/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFFFFFFFFFF, callID1=0xDE, gcid=0-0-0-0, tag=0x0)
*DATE:51.860: //221/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFFFFFFFFFF, callID2=0xDD, gcid=0-0-0-0, tag=0x0)
   Conference Id=0xFFFFFFFFFFFFFFFF, Call Id1=222, Call Id2=221, Tag=0x0
*DATE:51.860: //222/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0xF, Source Interface=0x7FA8FF0F6268, Source Call Id=222,
   Destination Call Id=221, Disposition=0x0, Tag=0x0
*DATE:51.860: //221/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
*DATE:51.860: call_info mainst_callID:0xDD, peer_callID:0xDE, confID:0xF, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
*DATE:51.860:   stream[0]: callid:0xDD, media_passthrough:1
*DATE:51.860: //221/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0xF, Source Interface=0x7AA8FF17BB80, Source Call Id=221,
   Destination Call Id=222, Disposition=0x0, Tag=0x0
*DATE:51.860: //222/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xF, Destination Call Id=221)
   Call Entry(Conference Id=0xF, Destination Call Id=222)
*DATE:51.860: confID:0xF; callEntry1 callID1:0xDE, type:25; callEntry2 callID2:0xDD, type:9
*DATE:51.860: //221/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x0, Params=0x7FA902F553C8, Call Id=221
*DATE:51.861: //222/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xF, Call Id1=222, Call Id2=221
*DATE:51.861: //221/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x7AA8FF17BB80, Call Id=221
*DATE:51.861: //221/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
*DATE:51.861: call_info mainst_callID:0xDD, peer_callID:0xDE, confID:0xF, spi_type:6, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
*DATE:51.861:   stream[0]: callid:0xDD, media_passthrough:1
*DATE:51.861: //221/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x7FA902F55A30, Params=0x7FA902F55A08, Call Id=221
*DATE:51.865: //222/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
   Conference Id=0xF, Tag=0x0
*DATE:51.865: confID:0xF; callEntry1 callID1:0xDE, type:25; callEntry2 callID2:0xDD, type:9
*DATE:51.865: //222/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*DATE:51.865: //221/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*DATE:51.865: //222/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
*DATE:51.865: //221/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
   Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=0, Call Entry(Responsed=TRUE, Cause Value=0)
*DATE:51.866: //221/xxxxxxxxxxxx/CCAPI/cc_api_nw_stats:
   Call Stats=0x7FA90E87A3F8, Call Id=221
*DATE:51.866: //221/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7AA8FF17BB80, Tag=0x0, Call Id=221,
   Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*DATE:51.866: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*DATE:51.866: :cc_free_feature_vsa freeing 7FA90B27AAE0
*DATE:51.866:  vsacount in free is 1
*DATE:51.866: //222/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
*DATE:51.866: //222/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7FA8FF0F6268, Tag=0x0, Call Id=222,
*DATE:51.867: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*DATE:51.867: :cc_free_feature_vsa freeing 7FA90B27AA00
*DATE:51.867:  vsacount in free is 0
Well, this information is not enough to know what is going on..
Can you attach your sh run..
What is the called number and calling number..
Did you reset the sip trunk after you created it?
do another test call and send the ff:
debug ccsip mess
debug voip ccapi inout
what do you mean by:
I mean you should do another test call..
The options ping message is normal. You will need to enable options ping on the trunk for you to see the status of the sip trunk
I solved the issue. it was codec issue :)
Can I know the codec from the previous debug output?
I tried to search about ping option in trunk configuration page but I could find it.
