10-25-2014 01:19 PM - edited 03-17-2019 12:41 AM
Hi all. I have PAWS-M installed. Is it possible to upgrade PAWS-M to PCD or not ?
10-25-2014 10:54 PM
PAWS-M is an interface on CUCM, PCD is an application that uses PAWS-M, not sure what you're asking here.
Id suggest yo to read the PCD documentation.
10-25-2014 11:24 PM
Hi Jaime.
I think that you are wrong. PAWS-M is stand alone application that was introduced in CUCM 9.
Also there is the documentations for it
In CUCM 10.5 introdice PCD, but there isn't any informatin about how to upgrade PAWS-M to PCD.
10-26-2014 07:46 AM
Interesting, I only knew of the API in the UC apps, however, PCD does not upgrade from anything else, you need to fresh install PCD the first time, and then upgrade with the PCD upgrade files. FYI, PCD was actually introduced in 10.0
