PC can't communicate when IP Phone 7941 registered
digit29
I have an infrastructure with Cisco IP Phone 7941 + PC running Win10 connected
to a switch from HPE 'R5130'.
With IP phones like 7941 or 7961 plus a PC connected behind, when the IP phone finishes registering
the PC is disconnected.
However PC is still authenticated with dot1x and IP Phone authenticated via Mac-Auth.
Until now we don't understand why the communication on the PC port of the IP Phone
is cut when the IP Phone is registered.
I have given the reference of the IP Phone 7941 below.
I have looked at the settings of the Ip Phone but nothing special.
PS: with IP Phones 7940, 7942 or 7960 it works fine but these IP phones have few lldp features
 System description  : Cisco IP Phone 7941G,V1, SCCP41.9-4-2SR1-1S
 System capabilities supported : Bridge, Telephone
 System capabilities enabled   : Bridge, Telephone
 Management address type           : IPv4
 FirmwareRev                : 7941G_64-02070631Amd64megRel.bin
 SoftwareRev                : SCCP41.9-4-2SR1-1S
 SerialNum                  : FCH10489J3G
 Manufacturer name          : Cisco Systems, Inc.
 Model name                 : CP-7941G
regards.
HARIS_HUSSAIN
Does it work when u disable dot1x authentication and register phone?
Thanks for the answer.
We haven't tested to disable  the dot1x for the PC because dot1x has to be maintained.
Even when the connection is cut on The PC and the IP Phone still working
by running display mac, we still see both terminals authenticated
[xx-GigabitEthernet1/0/1]dis mac-address int g1/0/1
MAC Address      VLAN ID    State            Port/NickName            Aging
40b0-34ec-b24b   10         DOT1X            GE1/0/1                  N    <== PC
001a-6d70-c728   26         AUTH             GE1/0/1                  N     <== IP Phone 7941
In the config of the port Gi1/0/1 we have following lldp commands:
lldp compliance admin-status cdp txrx
lldp tlv-enable med-tlv network-policy xx
We have analyzed debug datas taken  on the switch but nothing abnormal found.
I don't know if on the IP Phone we can find interesting info.
regards.
