10-02-2012 06:04 AM - edited 03-16-2019 01:28 PM
Hi all,
We use Cisco IP Phone 7941 in office, and was wondering how to allow users to add speed dials to their phones?
I can see from the Directories menu on the phone that there are 2 options for speed dials, one is Local Speed Dial, and the other is Personal Speed Dial. However, when I select either of them, I get only two options:
- Update
- Exit
Update doesn't do anything, it only shows the word "Requesting.." which THEN disappears in less than a second.
Can someone please advice what is easiest method of creating speed dials?
Thanks!
10-02-2012 06:38 AM
They can use CCMUser so they can manage their speed dials
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-02-2012 10:42 PM
Is there any guide that explains how to create/configure a CCMUser?
We are using CME 7.1
Thanks!
