Personal Speed Dial - IP Phone 7941
mike_j009
Hi all,
We use Cisco IP Phone 7941 in office, and was wondering how to allow users to add speed dials to their phones?
I can see from the Directories menu on the phone that there are 2 options for speed dials, one is Local Speed Dial, and the other is Personal Speed Dial. However, when I select either of them, I get only two options:
- Update
- Exit
Update doesn't do anything, it only shows the word "Requesting.." which THEN disappears in less than a second.
Can someone please advice what is easiest method of creating speed dials?
Thanks!
Jaime Valencia
They can use CCMUser so they can manage their speed dials
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Is there any guide that explains how to create/configure a CCMUser?
We are using CME 7.1
Thanks!
