IP Telephony and Phones
watch here Journey banner_2
Labels
Hi,     When the call manager sends the call unity or unity connection ( when integration is SCCP ), it sends the called number, calling number and reason for forwarding. Please help me to understand, which voice mail will be reached, for the scenari...
I am having an issue with an MCGP gateway and CUCM 8. The MGCP gateway status is shown as unregistered in CCM. Below is the config of the MGCP gateway and here as you can see it.Voice>enVoice#sh runBuilding configuration...Current configuration : 285...
I have a CME/CUE system where the MWI is not working. You can type in the DN to enable or disable the MWI, but it will not happen automatically. I cannot seem to locate the issue causing the MWI not to work. I have included the running config of the ...
putney_m by Level 1
  • 2054 Views
  • 2 replies
Has anyone worked with the 2N® Helios IP Family of surveillance/intercom products specifically on Call Manager Express?If so, can you share your experiences and where I can find some installation/technical docs for how to get the two to work together...
Kynnzak by Level 1
  • 715 Views
  • 0 replies
I am having an issue with a 9971 phone not receiving an IP address. We are planning to use the 9971s for Phone VPN at user's home sites.The phone is connected to a linksys router through a Cisco switch that is tagging the router's traffic on VLAN 912...
Hi,We recently upgraded CUCM to 7.1 (7.1.3.30000-1 exactly). When we were running 6.1 I had no problem using the BAT spreadsheet. Since we did the major upgrade I decided to download the new version of the BAT spreadsheet. I am running Excel 2007 (wh...
webberr by Level 1
  • 1549 Views
  • 2 replies
Hi all,I am having an issue with inbound SIP calls connecting very slowly. After a call is initiated, it can take anywhere from 10-15 seconds to connect. In the IPIP Gateway (3845 Version 12.4(24)T6), I see the call hit immediately but I am getting a...
Top Solution Authors
