Phone 6921 / FW 9.0.2.0 cannot get XMLDefault.cnf.xml
Jean Carlos
Hi Guys,
I have several 6921 phones with 9.0.2.0 firmware. But unfortunatelly my CUCM is far away from those phones and the delay is huge. So I can't upgrade firmware direct from CUCM.
New FW is 9-2-4-3.
So I've decided to create a local TFTP server and provide a new firmware with XMLDefault.cnf.xml.
For some phones it was worked as well, but for phones with FW 9.0.2.0 not.
They can get XMLDefault.cnf.xml but can't "understand" the loadinformation line, because they never try to upgrade the firmware from my local TFTP server.
If I put the SEPXXXX.cnf.xml on my local tftp, the phones can upgrade. But I wouldn't like to copy all my SEP files from my CUCM. :)
Someone had this issue before? Do you guys, have a tip for me?
Jean
Manish Prasad
Level 5
Level 5
Did you tried by using suffix ".bin, .sbin, .loads"  ?
Manish
Hi, I'm using the ".loads and .zz.sgn".
I've downloaded the file cmterm-69xx-sccp.9-1-1-sr2.zip from Cisco.
It's about that you saying?
Thanks.
Then give a try by removing suffix.
Manish
Thanks for you help. But unfortunatelly it didn't work. Any more ideas?
Jean
