Phone Keep rining even after PSTN disconnected..
anilkumar.cisco
Level 4
Level 4
Error: of Debug ISDN Q931
Cause i = 0x80E6 - Recovery on timer expiry
Phone mode: 3905 and 7821
CUCM : System version: 10.0.1.10000-24
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
cisco ISR4331/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FDO2132A0QV
3 Gigabit Ethernet interfaces
31 Serial interfaces
1 Channelized E1/PRI port
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:.
Gateway is configured as H.323
VG configuration..
ip dhcp excluded-address X.X.29.1
ip dhcp excluded-address X.X.29.6
ip dhcp excluded-address X.X.29.2
ip dhcp pool VOICE
 network X.X.29.0 255.255.255.0
 default-router X.X.29.1
 option 150 ip X.X.10.62 X.X.10.72 X.X.29.1
subscriber templating
isdn switch-type primary-net5
voice service voip
 no ip address trusted authenticate
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/0/0
  bind media source-interface GigabitEthernet0/0/0
  registrar server expires max 600 min 60
voice class codec 1
 codec preference 1 g722-64
 codec preference 2 g729r8
voice class h323 2
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
voice register global
 mode esrst
 source-address X.X.29.1 port 5060
 no allow-hash-in-dn
 timeouts interdigit 5
 max-dn 400
 max-pool 110
 timezone 39
 date-format D/M/Y
 dialplan-pattern 1 666... extension-length 4
 ntp-server X.X.8.1 mode directedbroadcast
 conference hardware
voice register pool  1
 id network X.X.29.0 mask 255.255.255.0
 type 3905
 dtmf-relay rtp-nte sip-kpml
 codec g711ulaw
 no vad
voice register pool  2
 busy-trigger-per-button 2
 type 7821
 codec g711ulaw
 no vad
voice-card 0/1
 dsp services dspfarm
 no watchdog
voice-card 0/4
 no watchdog
license udi pid ISR4331/K9 sn FDO21310YDH
redundancy
 mode none
controller E1 0/1/0
 pri-group timeslots 1-31
vlan internal allocation policy ascending
 ip address X.X.29.1 255.255.255.0
 negotiation auto
 h323-gateway voip interface
 h323-gateway voip bind srcaddr X.X.29.1
interface GigabitEthernet0/0/1
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface Service-Engine0/1/0
interface Serial0/1/0:15
 encapsulation hdlc
 isdn incoming-voice voice
interface Service-Engine0/4/0
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 no ip address
 shutdown
ip default-gateway X.X.29.6
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 X.X.29.6
control-plane
voice-port 0/1/0:15
mgcp call-agent X.X.10.62 service-type mgcp version 0.1
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0/0
sccp ccm X.X.10.72 identifier 1 priority 1 version 7.0
sccp ccm X.X.10.62 identifier 2 priority 2 version 7.0
sccp ccm X.X.29.1 identifier 3 priority 3 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/0/0
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate ccm 3 priority 3
 associate profile 2 register TRANSC
 associate profile 1 register CONFER
ccm-manager config server X.X.10.62
ccm-manager config
telephony-service
 sdspfarm units 2
 sdspfarm transcode sessions 3
 sdspfarm tag 1 CONFER
 sdspfarm tag 2 TRANSC
 conference hardware
 max-ephones 10
 max-dn 10
 max-conferences 8 gain -6
 transfer-system full-consult
dspfarm profile 2 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 11
 associate application SCCP
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 3
dial-peer voice 1 pots
 destination-pattern .T
 incoming called-number .
 direct-inward-dial
 port 0/1/0:15
dial-peer voice 10 voip
 preference 1
 destination-pattern 666...
 session target ipv4:X.X.10.62
 incoming called-number 666...
 voice-class codec 1
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 11 voip
 session target ipv4:X.X.10.72
 voice-class codec 1
 voice-class h323 1
 no vad
sip-ua
ephone-dn  1  octo-line
 number DDDD
 conference ad-hoc
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password P@ssw0rd
 login
end
anilkumar.cisco
Level 4
Level 4
out put of Debug voice ccapi inout
*Dec 27 07:55:52.806: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x014B
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x2183, '01147811216'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '666299'
                Plan:ISDN, Type:Subscriber(local)
        Sending Complete
*Dec 27 07:55:52.807: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0x814B callID = 0x0190 switch = primary-net5 interface = User
*Dec 27 07:55:52.808: //-1/320C557A8216/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=01147811216
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=666299
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFFFFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Dec 27 07:55:52.808: //-1/320C557A8216/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x7FE93BEB0CA0, Call Info(
   Calling Number=01147811216,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=666299(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Dec 27 07:55:52.808: //-1/320C557A8216/CCAPI/ccCheckClipClir:
   In: Calling Number=01147811216(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=01147811216(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
*Dec 27 07:55:52.808: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 27 07:55:52.808: :cc_get_feature_vsa malloc success
*Dec 27 07:55:52.808:  cc_get_feature_vsa count is 1
*Dec 27 07:55:52.808: :FEATURE_VSA attributes are: feature_name:0,feature_time:140639638784620,feature_id:1478
*Dec 27 07:55:52.808: //2105/320C557A8216/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=01147811216(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=666299(TON=Subscriber, NPI=ISDN))
*Dec 27 07:55:52.809: //2105/320C557A8216/CCAPI/cc_process_call_setup_ind:
   Event=0x7FE937B81BE8
*Dec 27 07:55:52.809: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 666299
*Dec 27 07:55:52.809: //2105/320C557A8216/CCAPI/ccCallSetContext:
   Context=0x7FE944E75448
   >>>>CCAPI handed cid 2105 with tag 1 to app "_ManagedAppProcess_Default"
*Dec 27 07:55:52.809: //2105/320C557A8216/CCAPI/ccCallProceeding:
*Dec 27 07:55:52.809: //2105/320C557A8216/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=11, Params=0x7FE93C742FB8, Progress Indication=NULL(0)
*Dec 27 07:55:52.810: //2105/320C557A8216/CCAPI/ccCheckClipClir:
*Dec 27 07:55:52.810: //2105/320C557A8216/CCAPI/ccCallSetupRequest:
   Destination Pattern=666..., Called Number=666299, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=320C557A-EA12-11E7-8216-74860BB98030, Outgoing Dial-peer=11
*Dec 27 07:55:52.810: //2105/320C557A8216/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=666299
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Dec 27 07:55:52.810: //2105/320C557A8216/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x7FE933AFD258, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=01147811216,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=666299(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=11, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Dec 27 07:55:52.810: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 27 07:55:52.810: :cc_get_feature_vsa malloc success
*Dec 27 07:55:52.810:  cc_get_feature_vsa count is 2
*Dec 27 07:55:52.810: :FEATURE_VSA attributes are: feature_name:0,feature_time:140639638787308,feature_id:1479
*Dec 27 07:55:52.810: //2106/320C557A8216/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Dec 27 07:55:52.810: //2106/320C557A8216/CCAPI/ccCallSetContext:
   Context=0x7FE93C742F38
*Dec 27 07:55:52.810: //2105/320C557A8216/CCAPI/ccSaveDialpeerTag:
*Dec 27 07:55:52.810: //2106/320C557A8216/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Dec 27 07:55:52.810: //2106/320C557A8216/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
*Dec 27 07:55:52.811: //2105/320C557A8216/CCAPI/ccSetMediaclassIp2ipTags:
*Dec 27 07:55:52.811: //2106/320C557A8216/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
*Dec 27 07:55:52.811: //2105/320C557A8216/CCAPI/ccGet_xc_nr_asp_info:
*Dec 27 07:55:52.811: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x814B
*Dec 27 07:55:53.068: //2106/320C557A8216/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
*Dec 27 07:55:53.068: //2106/320C557A8216/CCAPI/cc_api_call_proceeding:
   Interface=0x7FE933AFD258, Progress Indication=NULL(0)
*Dec 27 07:55:53.364: //2106/320C557A8216/CCAPI/cc_api_set_called_ccm_detected:
*Dec 27 07:55:53.364: //2106/320C557A8216/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
*Dec 27 07:55:53.364: //2106/320C557A8216/CCAPI/cc_api_call_alert:
   Interface=0x7FE933AFD258, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
*Dec 27 07:55:53.364: //2105/320C557A8216/CCAPI/ccCallAlert:
*Dec 27 07:55:53.365: //2105/320C557A8216/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
*Dec 27 07:55:53.365: //2105/320C557A8216/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=2105
*Dec 27 07:55:53.368: ISDN Se0/1/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x814B
*Dec 27 07:55:53.368: //2106/320C557A8216/CCAPI/cc_api_set_called_ccm_detected:
*Dec 27 07:55:53.368: //2106/320C557A8216/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x7FE933AFD258, Call Id=2106
*Dec 27 07:55:53.369: //2106/320C557A8216/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
*Dec 27 07:55:53.369: //2106/320C557A8216/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
*Dec 27 07:55:53.369: //2105/320C557A8216/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=2105
*Dec 27 07:55:57.103: //2106/320C557A8216/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
*Dec 27 07:55:57.386: //2106/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Dec 27 07:55:57.386: cc_api_get_xcode_stream : 4983
*Dec 27 07:55:57.386: //2106/320C557A8216/CCAPI/cc_api_call_connected:
   Interface=0x7FE933AFD258, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Dec 27 07:55:57.387: //2106/320C557A8216/CCAPI/cc_api_set_called_ccm_detected:
*Dec 27 07:55:57.387: //2106/320C557A8216/CCAPI/cc_api_call_notify:
*Dec 27 07:55:57.387: //2105/320C557A8216/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
*Dec 27 07:55:57.387: //2105/320C557A8216/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFFFFFFFFFF, callID1=0x839, gcid=320C557A-EA1211E7-82167486-BB98030, tag=0x0)
*Dec 27 07:55:57.387: //2106/320C557A8216/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFFFFFFFFFF, callID2=0x83A, gcid=320C557A-EA1211E7-82167486-BB98030, tag=0x0)
   Conference Id=0xFFFFFFFFFFFFFFFF, Call Id1=2105, Call Id2=2106, Tag=0x0
*Dec 27 07:55:57.387: //2105/320C557A8216/CCAPI/cc_api_bridge_done:
   Conference Id=0x1D3, Source Interface=0x7FE93BEB0CA0, Source Call Id=2105,
   Destination Call Id=2106, Disposition=0x0, Tag=0xFFFFFFFFFFFFFFFF
*Dec 27 07:55:57.387: //2106/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Dec 27 07:55:57.387: cc_api_get_xcode_stream : 4983
*Dec 27 07:55:57.387: //2106/320C557A8216/CCAPI/cc_api_bridge_done:
   Conference Id=0x1D3, Source Interface=0x7FE933AFD258, Source Call Id=2106,
   Destination Call Id=2105, Disposition=0x0, Tag=0x0
*Dec 27 07:55:57.387: //2105/320C557A8216/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1D3, Destination Call Id=2106)
   Call Entry(Conference Id=0x1D3, Destination Call Id=2105)
*Dec 27 07:55:57.387: confID:0x1D3; callEntry1 callID1:0x839, type:6; callEntry2 callID2:0x83A, type:1
*Dec 27 07:55:57.388: //2105/320C557A8216/CCAPI/cc_api_caps_ind:
   Destination Interface=0x7FE933AFD258, Destination Call Id=2106, Source Call Id=2105,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Dec 27 07:55:57.388: //2106/320C557A8216/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
*Dec 27 07:55:57.388: //2106/320C557A8216/CCAPI/cc_api_get_ccm_detected:
*Dec 27 07:55:57.388: //2105/320C557A8216/CCAPI/ccCallNotify:
*Dec 27 07:55:57.389: //2105/320C557A8216/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1D3, Call Id1=2105, Call Id2=2106
*Dec 27 07:55:57.389: //2106/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Dec 27 07:55:57.389: cc_api_get_xcode_stream : 4983
*Dec 27 07:55:57.390: //2106/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Dec 27 07:55:57.390: cc_api_get_xcode_stream : 4983
*Dec 27 07:55:57.390: //2106/320C557A8216/CCAPI/cc_api_caps_ind:
   Destination Interface=0x7FE93BEB0CA0, Destination Call Id=2105, Source Call Id=2106,
   Caps(Codec=0x10000000, Fax Rate=0x80, Fax Version:=0, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
*Dec 27 07:55:57.390: //2106/320C557A8216/CCAPI/cc_api_caps_ack:
   Caps(Codec=g722-64(0x10000000), Fax Rate=FAX_RATE_14400(0x80), Fax Version:=0, Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=5042)
*Dec 27 07:55:57.390: //2105/320C557A8216/CCAPI/cc_api_caps_ack:
*Dec 27 07:55:57.390: //2105/320C557A8216/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
*Dec 27 07:55:57.393: //2105/320C557A8216/CCAPI/cc_api_voice_mode_event:
   Call Id=2105
   Call Entry(Context=0x7FE944E75448)
*Dec 27 07:55:57.393: ISDN Se0/1/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x814B
*Dec 27 07:55:57.723: ISDN Se0/1/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x014B
*Dec 27 07:55:57.845: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x014B
        Cause i = 0x8290 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*Dec 27 07:55:57.846: ISDN Se0/1/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x190
*Dec 27 07:55:57.846: //2105/320C557A8216/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=16, Progress Indication=INBAND(8), Interface=0x7FE93BEB0CA0
   Event(Progress Indication=0x0), Call Entry(Responsed=TRUE)
*Dec 27 07:55:57.846: //2105/320C557A8216/CCAPI/ccConferenceDestroy:
   Conference Id=0x1D3, Tag=0x0
*Dec 27 07:55:57.846: confID:0x1D3; callEntry1 callID1:0x839, type:6; callEntry2 callID2:0x83A, type:1
*Dec 27 07:55:57.846: //2105/320C557A8216/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2106, Disposition=0x0, Tag=0x0
*Dec 27 07:55:57.846: //2106/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Dec 27 07:55:57.846: cc_api_get_xcode_stream : 4983
*Dec 27 07:55:57.846: //2106/320C557A8216/CCAPI/cc_api_bridge_drop_done:
*Dec 27 07:55:57.846: //2105/320C557A8216/CCAPI/cc_generic_bridge_done:
*Dec 27 07:55:57.847: //2105/320C557A8216/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Dec 27 07:55:57.847: //2105/320C557A8216/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
*Dec 27 07:55:57.847: //2106/320C557A8216/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Dec 27 07:55:57.847: //2106/320C557A8216/CCAPI/cc_api_get_transfer_info:
*Dec 27 07:55:57.867: //2106/320C557A8216/CCAPI/cc_api_get_transfer_info:
*Dec 27 07:55:57.868: //2106/320C557A8216/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7FE933AFD258, Tag=0x0, Call Id=2106,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Dec 27 07:55:57.868: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 27 07:55:57.868: :cc_free_feature_vsa freeing 7FE937B614E0
*Dec 27 07:55:57.868:  vsacount in free is 1
*Dec 27 07:55:57.886: //2105/320C557A8216/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
*Dec 27 07:55:57.887: //2105/320C557A8216/CCAPI/cc_api_call_disc_cause_update:
   Call Entry(Disconnect Cause=16)
*Dec 27 07:55:57.887: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x814B
*Dec 27 07:55:57.889: //2105/320C557A8216/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7FE93BEB0CA0, Tag=0x0, Call Id=2105,
*Dec 27 07:55:57.889: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 27 07:55:57.889: :cc_free_feature_vsa freeing 7FE937B60A60
*Dec 27 07:55:57.889:  vsacount in free is 0
*Dec 27 07:55:58.051: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x014B
Check the link to your telco. Seems that you aren't receiving response for
setup message. This is the meaning of recovery timer expired
