09-24-2008 08:19 AM - edited 03-15-2019 01:30 PM
I'm running CM 6.1 and using extension mobility, it's all working fine except one small problem, when I search for the phone by directory number of the EM user I can't find it, all phones are showing up as the auto-reg number and not the DN that is logged into the phone.
Has anyone seen this before?
Tks
Paul
Solved! Go to Solution.
09-24-2008 08:51 AM
on the related links option from device -> phone select the EM option to view currently logged devices
java
if this helps, please rate
09-24-2008 08:51 AM
java
09-25-2008 12:49 AM
Thank you very much
