02-25-2015 10:00 PM - edited 03-17-2019 02:07 AM
I have new router 2921, with IOS 15.2(4)M, CME 9.1, phones 7821 and 7941 but no phones can register, plz need your help?
when i try #debug tftp event, show to me "Looking for.." repeated
#dir flash:
Directory of flash0:/
1 -rw- 99137584 Jul 30 2014 15:14:12 +00:00 c2900-universalk9-mz.SPA.152-4.M6a.bin
2 -rw- 3064 Jul 30 2014 15:25:28 +00:00 cpconfig-29xx.cfg
3 -rw- 600 Feb 24 2015 08:28:58 +00:00 vlan.dat
4 drw- 0 Jul 30 2014 15:25:52 +00:00 ccpexp
245 -rw- 2464 Jul 30 2014 15:27:34 +00:00 home.shtml
246 drw- 0 Feb 24 2015 12:19:50 +00:00 its
256487424 bytes total (154882048 bytes free)
Thank you
Solved! Go to Solution.
03-01-2015 04:49 AM
Can you add the following if you havent already:
tftp-server flash:sip78xx.10-1-1SR1-4.loads
tftp-server flash:rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash:sboot78xx.10-1-1SR1-4.sbn
and all other files in flash for 78xx.
Also below:
voice register global
mode cme
load 7821 sip78xx.10-1-1SR1-4
no create profile
create profile
Then try and let me know, how you go. If you are still having issues, attach a sh run and the same debug tftp eve output.
-Terry
02-25-2015 10:27 PM
I didnt notice the its directory, it should have the files, just configure tftp server on router to serve the files.
Ref:http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmeinstl.html#26777
once done let me know how you go.
02-26-2015 05:11 AM
as i checked online cme version 9.1 not support 7821phone , so i go to download cme version 10.0
Unified Communications Manager Express Complete Support File Set->CME 10.0 file set
cme-153-3Mv2.rar
After i installed this file and extract show me following files:-
-CME 9.1.0 GUI [folder]
-IP_Phones [folder]
-7970-71-75-Background-readme-v1.txt
-7970-71-75-backgroundsv1.tar
-cme-b-acd-3.0.0.2.zip
-cme-tsp-2.2.0.5.zip
-cucme-mlpp.tar
-music-on-hold.au
-ringtones.tar
Should i import all of tar file by archive command and another extension by copy tftp command
Thank you
02-26-2015 05:38 AM
Yes its correct for 78XX phones you need at least CME version 10. To upgrade CME you would first need to upgrade your IOS version to the below:
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
Cisco IOS Release 1 | Cisco Unified CME Version | Cisco Unified CME GUI Version 2 | Version Specification Link 3 |
T-Train | S-Train | — | — | — |
15.4(3)M | 15.4(3)S | 10.5 | 10.5.0.0 | |||||||||||
15.3(3)M | — | 10.0 - Recommended Version | 10.0.0 |
Once IOS version is upgraded, Then you install the phone firmware files.
Then you should be able to register the phone.
-Terry
Please rate all helpful posts
02-26-2015 10:47 AM
Following url mention 7821 Requires IOS 15.4(1)T,
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme10spc.html
but when access 2921 router to download ios 15.4(1)T show me ios that above IOS 15.4(1)T,
15.5.1T
02-26-2015 05:16 PM
It appears better to use 15.4.3MX as its later release and may have updates/new features etc.
-Terry
03-01-2015 12:16 AM
i upgrade ios to 15.4(3)M2, and CME to Version 10.5, but phone still not register, plz need your help
03-01-2015 04:49 AM
Also below:
mode cme
no create profile
create profile
-Terry
03-01-2015 06:12 AM
Hi Terry
Thank you so much, works (:
03-01-2015 04:50 PM
Good one :) - thx for the update!
-Terry
