Pickup notification
mibrahim1986
is it possible to set the Pickup notification for individual users to different settings in CUCM 6.0? I can only find the global "Call Pickup Group Notification Policy" configuration within the pickup group. But some users dont want a audio notfication...
Jaime Valencia
each call pickup group has this parameter:
have you tried that?
It's not for individual users but for all the users who are part of the group, BTW this cannot be set per user (unless EACH user is in his own pickup group)
java
if this helps, please rate
I think Ive found the solution.
There is a Call Pickup Group Audio Alert Setting Phone Idle and Phone Active directly in the DN menu. There You can set the alerting per user.
Moe
