IP Telephony and Phones
Labels
Hi, is it possible to set the Pickup notification for individual users to different settings in CUCM 6.0? I can only find the global "Call Pickup Group Notification Policy" configuration within the pickup group. But some users dont want a audio notfi...
I'm looking for the best path to do an upgrade from 3.3(3) to 4.2. according to the documentation this would require a 2 step upgrade, so I was wondering would it be better to upgrade to 3.3(5) or 4.1(3) before going to 4.2.Any thought? Is there an...
Hi,We have 2 CallManager Express setup. One is located in Canada and the other one is located in Italy.They are in the same private network as we are using a global VPN connection between our offices.I would like to know if it is possible to route ex...
Resolved! POE to 7914
Hi all. Im trying to hook up a 7914 to a 7960 phone powered via POE. At this point, I dont have a separate power supply for the 7914. Is there a way to power it via POE, like the phone?
jjoseph01 by Level 3
  • 2370 Views
  • 10 replies
Hi,We are using using a TCL IVR over IP (IPIPGW) for a Calling card Application. It is running on a Cisco 3745 with c3745-ipvoice_ivs-mz.124-11.T4.binEverything works perfectly for the first call based on the following call flow:Calls are SIP-SIP (...
