polycom vtx 1000 connected to vg224
michaeljbyrne
Have it connected and I get dialtone from the vg224 but as soon as I press a number to dial I get fast busy. Do I need a dial peer on the vg224? I gave it a number off of the PRI.
Marcos Assakawa
Hi Michael,  The VG224 can be configured as H.323, MGCP and SCCP gateway. Depending on the protocol, the configuration will be a little bit different.   H.323: You have to configure the POTS dial peer and VOIP dial-peer   MGCP: You will need to configure the MGCP, but you will also going to need to have the CUCM in order to control the VG224 ports  SCCP: You will need to configure the SCCP, but you will also going to need to have the CUCM in order to control the VG224 ports  Please, let me know what kind of protocol are you planning to use, I may be able to send an configuration example.  Thanks,  Marcos
