IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5822 Views
  • 14 replies
Dear all NetPro gurus,One of my new customers was wondering what is the feature "Do Not Disturb" for??I configured it on a 9971 phone.  It seems that all it does is when a call comes in, the phone will just 'blink' but it wont ring.Is that all it doe...
huntlee by Level 1
  • 542 Views
  • 1 replies
Our problem in accessing the Paging System (Pager) from PABX old System(Ericsson) using access “78” via IP-Call Manager. after dialing “78” followed by “*9” plus pager unit number “i.e. 5404” is allowed.Ericsson system(PABX old system) connected to C...
Hello,I try to reconfigure a 8 ports t1 blade on a catalyst 6000.this actual config :#module 2 : 8-port T1set port voice interface  2/1 dhcp disable 10.3.1.41/255.255.255.0 vlan 8 tftp 10.3.1.2 gateway 10.3.1.1and then...everytime i try to paste the ...
desrochj1 by Level 1
  • 438 Views
  • 2 replies
Hi,i have branches gateways connected as H323 to a call manager cluster. i am using centralized call processing for all the users in branches.i want to configure MOH for the branch phones and wondering what to do. note that my ISP does not support mu...
ichehouri by Level 2
  • 1915 Views
  • 7 replies
Hello,My config :CUCM6-----------ISR2811------(sip)--------NAT+FW-------(sip)--------SIP ProviderISR2811 and NAT+FW are not the same equipment.ISR2811 : IP-to-IP feature, only one network interface + private ip address.NAT+FW : not a Cisco equipment....
Can someone please share a defined QoS policy map for ICCS Cluster over Wan CUCM 7.1.3 or the best way to match traffic for all ICCSThanksclass-map match-all VOICE-RTP  description VOIP Bearer Trafficmatch access-group name VOICEclass-map match-all V...
shaftstri by Level 1
  • 874 Views
  • 2 replies
