Prerequisites for personal and mobile communicator
karthikeyanm
Can anybody list requirements for Personal and mobile communicator? I have a CUCMBE with general license. Is that enough or CUWL is needed.
-HTH Karthik.
Jaime Valencia
Release Notes for Cisco Unified Personal  Communicator Release 8.5
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cupc/8_5/english/release/notes/cupc85.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Ok. I understand that CUP is needed. Can I install CUP in same appliance? What licenses do I need for it? CUWL?
-HTH Karthik.
Only assuming you're running VMs you can install it along other Cisco Apps, if you mean install on MCS you need a server per app.
Review the ordering guides for the licensing questions and what to order.
java
java
