PRI Card port number
angel-moon
Level 3
Level 3
                   Hello everyone,
can anyone tell me the correct part number for  a PRI card that goes into a 2800 series router and above?  I am coming up with 3 different part numbers, all different.
Thanks in advance.  All replies rated.
Chris Deren
They are probably all correct, if this is non G703 then use:
VWIC3-1MFT-T1/E1 for one port
VWIC3-2MFT-T1/E1 for dual port
VWIC3-4MFT-T1/E1 for qued port
HTH,
Chris
Chris Deren
HTH,
Chris
Angel , Chris.
I think there is a wee type here.
You can only use a VWIC3 in ISR-G2 routers
(1900, 2900 3900 ranges)
For the 2880 range you need to stick with VWIC2s
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_qas0900aecd8028d2e5.html
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Oops, I misread the post as 29XX as they've been around for some time now :-) Thanks Alex for correcting me (+5).
Chris
Thanks to both of you.  Teamwork!  Yay!
