06-12-2013 06:27 AM - edited 03-16-2019 05:50 PM
I am moving all of my lines to a SIP trunk.
What I would like to do is have the phone company move a few DIDs at a time in order to isolate problems if/when they occur.
I'm having some trouble figuring out how outbound calls work when doing this. I set up a new route patter for my cell phone number and associated it with the new route list. It works when I call it from one of the new DIDs, but when I call it from one of the old numbers, the call fails.
Lets assume that I have a partition called Local_PT with a route pattern in it of 9.1800[2-9]XXXXXX
Can I set up a new partition called Local_SIP_PT and put the same route pattern in it and associate that pattern with the SIP route list?
I hope this makes sense
neill
06-12-2013 06:39 AM
No, you manage failover thru GW/trunks via route groups and route lists, not by creating the same RPs. That won't work.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
06-12-2013 06:47 AM
If I add the SIP trunk to the route list used for everything else, will calls fail over to the ELD/PRI if they fail on the SIP trunk?
Neill
06-12-2013 06:51 AM
Yes, that's why you configure the trunks/GWs in a particular order in the RG/RLs, if you're not familiar with this, I'd recommend you to review the SNRD chapter on dial plan to fully understand this.
java
06-12-2013 06:49 AM
Hi ,
I believe the working is , create a local_sip_pt and local_css, give that loca_pt to the Route pattern. This Routepattern will point it to Route List, which has the Route Group, which has the sip trunk.
Call flow:
RP-->RL-->RG-->SIPtrunk-->CUBE-->SIP-->ITSP. Give the local_pt to the RP and local_css to end devices.
Please rate, if this helps by clicking the stars below.
06-12-2013 06:51 AM
Or I guess a better question might be, how do I make calls from the new DIDs go out over the SIP trunk and calls from the old DIDs go over the PRI
06-12-2013 12:14 PM
Create 2 PT,
Local_SIP_PT
Local_PRI_ PT
Create two CSS,
CSS_SIP <---Local_SIP_PT
CSS_PRI <---Local_PRI_ PT
Create 2 RG
SIP_RG
PRI_ RG
Create 2 RL
SIP_RL <---SIP_RG
PRI_ RL <---PRI_RG
Create 2 RP
9.1800[2-9]XXXXXX <---Local_SIP_PT , SIP_RL
9.1800[2-9]XXXXXX <---Local_PRI_ PT , PRI_ RL
Assign CSS_SIP to all new DN
Assign CSS_PRI to all old DN
Hope this helps.
Please rate helpful.
