HiIs it possible to create a callpickup group with members on both sides of a Intercluster Trunk ?
Hello,I have an IP Phone model 9971 and Call Manager 8.6 configured with Extension Mobility but the problem is I can not find the expansion module configuration section under the User device Profile although I am Using the same Phone buttopn template...
Dears,By refering to the subject,It is not clear if blf speed dials is supported or not - as per cisco document it is supported; but we configure it for our expansion module for the 9971 it is not working (it does not show the status for the speed di...
Hi Experts,I have CUCM 6.1.2; i have two lines on my IP phone. I am facing a problem which is i can not differenciate in Missed calls list between which missed came in which line..how can i do that deffernciation?Please advise urgent as my customer f...
I am trying trying to get my phones, which are registered to CUCM to place calls to the PSTN through a SIP Trunk terminating on a CUBE system.The SIP trunk to my ITSP is working, because I can register phones to CUCME on the router terminating the SI...
Our customer has a Cisco 3845 based CCME environment running 12.4(24)T8,with a mixture of 7941 and 7931 handsets. On the 7931 handsets, the users have to shoutdown the handsets for anyone to hear them. How can we increase the GAIN on the handset soth...
Hello,I am newbie with Cisco. I have only been using the system for a little over a month.Our vendor set up a line group that rings to 2 extensions but unfortunately after about 8 rings it just hangs up.How do I configure this to go to one of the ext...
Hello I have a problem with incoming and outgoing translations.We are using the CUCM 8.0.3.20000-2.Okay here my problem:First I want to translate every incoming number from 000XXXXXXX to +XXXXXXX.That works fine I used the Calling Party Transformatio...
I have an issue with a Call recorder who requires the CDR records that are provided in realtime (through the Billing Server), where they require records going back a couple of months in the same format (i.e. the individual call).I know I can extract ...
HelloWehave CUCM 6 which is going to be upgraded to version 9. I would like to know ifthere is any difference in the CDR output format of existing CUCM 6 with thenewer version. We want to make sure that our billing system will continue towork. Thanks
I would like to configure CUBE Failover for SIP trunks to our service provider. We currently have two 2900 ISR routers that will be used for the configuration. From a circuit perspective we have two MPLS circuits from the same provider terminating in...
Hi,I have an IP Telephony setup with CME version 9.1.I have integrated with Cisco Jabber for both Anroid and Apple Iphone.Succesfully registered and we can make outgoing calls with cisco jabber.The issue is that Caller A has 2 phones - the jabber iph...
Hi all. Easy question...I've got the same shared line on my desk phone (IP Phone 7940) and on my Android device (Samsung Galaxy II with Jabber).When the call arrives, obviously both ring...Well, during the call, how can I move the call from the desk ...
Hello all!I have PBX Aastra MX-ONE TSW which is connected to Cisco 2651xm via E1 PRI. So, Cisco2651xm is connected to Asterisk 11.2.1 via SIP trunk.Cisco 2651xm has ip address 172.26.18.200Asterisk has ip address 10.2.210.13I can to make call from so...
Hello All,What is the exact purpose of the command no-reg in SRST. I found below definitions from cisco doc.#Globally disables ephone registration with an H.323 gatekeeper or SIP proxy.#To specify that the pilot number for a Cisco CallManager Express...
Subject | Author | Posted |
02-07-2025 02:45 AM | ||
02-04-2025 01:17 PM | ||
02-04-2025 06:55 AM | ||
02-04-2025 01:31 AM | ||
02-03-2025 03:57 AM |
User | Count |
5 | |
4 | |
1 | |
1 | |
1 |
