12-06-2015 03:43 AM - edited 03-17-2019 05:08 AM
Hi All,
We have planned to upgrade CUOM 9.0 to Prime Collaboration 10.6 Advanced. please clarify below doubts.
1)As per the upgrade guide , we should upgrade to 10.6 from either 10.0 or 10.5.
2) If we are going to follow this 2 stage procedure,before upgrades to 10.6 will we need to install valid license in 10.5 ?
3) We have already purchased the Upgrade Kit. Is it ok to install the 10.6 directly & upload the new license ?
Thanks in Advance !!!
12-06-2015 05:41 AM
I never did upgrade for CUOM but as you are upgrading from 9 to 10, it would be counted as a major upgrade.
As u have mentioned in step 3, that u have purchased the upgrade kit, it means u have ordered through PUT.You won't be able to upload the licenses directly since that would be the upgrade licenses.
You can involve licensing team and share the SO along with old license file so that they provide u the fresh lic file for 10.6
regds,
aman
12-08-2015 12:36 AM
Hi Aman,
Thanks for your Reply. I installed 10.6 directly & Install the upgrade licenses.
