04-21-2011 02:39 AM - edited 03-16-2019 04:37 AM
There is a server of Publisher with current version CUCM 6.1.4.2190-3. At installation Subscriber there was a problem. In Cisco Unity Reporting in report Unified CM Cluster Overview shows that 2 components are not installed on Subscriber:
The version 12.1.5(3) of cactus on 10.0.3.77 does not match across all nodes
Error The component cactus is not installed on node 10.0.3.78
Warning The version 3AS(0.20060712) of comps on 10.0.3.77 does not match across all nodes
Error The component comps is not installed on node 10.0.3.78
10.0.3.77 - publisher; 10.0.3.78 - subscriber.
What it is necessary to make for elimination of these errors?
04-21-2011 05:51 AM
Hi there,
These errors are "Cosmetic' only
CSCsz94171 Bug Details |
Cheers!
Rob
04-21-2011 06:16 AM
Thanks a lot, Rob.
