Problem MOH
oelmassaoudi
hi all,
I have a problem with MOH, when I put on hold a local IP Phone, the user listens to the MOH correctly.
the problem has been detected in the external calls, when I call a ouside destination and I put it on hold, the recipient hear only silence.
il have CUCM V 8.0.3
best ragards,
Oualid
Jaime Valencia
Make sure the GW has the right MOH server via the MRGL or device pool.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
sumimanc
Hi Oualid
please see this thread and check all the things mentioned here
https://supportforums.cisco.com/message/3354845#3354845
Please rate useful Posts
sumit
