Problem to Transfer Calls
crusier2015
Could you plz help me in this situation ?
Suppose that one inbound external call came from SIP trunk and one extension pickup this call , and try transfer this call to another internal extension didnt work, when this extension that is trying transfer click on transfer button on phone, not happens, The same happens with internal calls, if i try transfer internal call generated internally occurs the same behavior mentioned.
So never didnt get success to transfer the call.
Follow attached the show run, and the follow debug output making tests trying transfer calls from external inbound.
ROUTER#
Jan 12 18:49:01.756: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:551126111111@2.2.2.2.130 SIP/2.0
Via: SIP/2.0/UDP 1.1.1.1:5060;branch=z9hG4bK2ace7435;rport
Max-Forwards: 70
To: <sip:551126111111@2.2.2.2.130>
Contact: <sip:119999999@1.1.1.1:5060>
Call-ID: 3afb0a383c6973155a1deb6231545925@1.1.1.1:5060
CSeq: 102 INVITE
User-Agent: BR-SAO-CO1-SVV-SBC-01
Date: Thu, 12 Jan 2023 18:42:03 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces
Content-Type: application/sdp
Content-Length: 282
v=0
o=root 1227227379 1227227379 IN IP4 1.1.1.1
s=Asterisk PBX 13.16.0
c=IN IP4 1.1.1.1
t=0 0
m=audio 14758 RTP/AVP 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptim
ROUTER#e:150
a=sendrecv
Jan 12 18:49:01.768: //570670/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 12 Jan 2023 18:49:01 GMT
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.6.3.M9
Session-ID: 00000000000000000000000000000000;remote=3c2db40747315d48b7ab1edb924533b4
Content-Length: 0
Jan 12 18:49:01.768: //570671/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:201@192.168.22.21:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA53222F
From: <sip:119999999@192.168.22.10>;tag=4DD3A280-24DB
To: <sip:201@192.168.22.21>
Call-ID: 9D64C11E-91E011ED-8C76FC01-A571E559@192.168.22.10
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 2640506022-2447380973-2356214785-2775704921
User-Agent: Cisco-SIPGateway/IOS-15.6.3.M9
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1673549341
Contact: <sip:119999999@192.168.22.10:5060>
Expires: 180
Max-Forwards: 69
Session-ID: 3c2db40747315d48b7ab1edb924533b4;remote=00000000000000000000000000000000
Content-Disposition: session;handling=required
Content-Lengt
ROUTER#h: 274
v=0
o=CiscoSystemsSIP-GW-UserAgent 6812 8293 IN IP4 192.168.22.10
s=SIP Call
c=IN IP4 192.168.22.10
t=0 0
m=audio 18872 RTP/AVP 8 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Jan 12 18:49:01.780: //570671/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Session-ID: 6fd68ed300105000a000204c9eb24ea4;remote=3c2db40747315d48b7ab1edb924533b4
Date: Thu, 12 Jan 2023 18:49:00 GMT
CSeq: 101 INVITE
Server: Cisco-CP7861/14.1.1
Contact: <sip:BE8C-1652@192.168.22.21:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP204C9EB24EA4"
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 0
Recv-Info: conference
Recv-Info: x-cisco-conference
Jan 12 18:49:01.884: //570671/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:201@192.168.22.21>;tag=204c9eb24ea429bc4f9c57eb-22c0dae6
CSeq: 101 INVITE
Remote-Party-ID: "Milena" <sip:201@192.168.22.10>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
Jan 12 18:49:01.884: //570670/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:551126111111@2.2.2.2.130>;tag=4DD3A2F4-194C
CSeq: 102 INVITE
Contact: <sip:551126111111@192.168.22.10:5060>
ROUTER#b7ab1edb924533b4
Content-Length: 0
Jan 12 18:49:03.712: //570671/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Thu, 12 Jan 2023 18:49:02 GMT
CSeq: 101 INVITE
Content-Length: 221
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 20561 0 IN IP4 192.168.22.21
s=SIP Call
t=0 0
m=audio 16856 RTP/AVP 8 101
c=IN IP4 192.168.22.21
b=TIAS:64000
a=fmtp:101 0-15
a=sendrecv
Jan 12 18:49:03.716: //570671/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:BE8C-1652@192.168.22.21:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA54161D
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 3c2db40747315d48b7ab1edb924533b4;remote=6fd68ed300105000a000204c9eb24ea4
Content-Length: 0
Jan 12 18:49:03.720: //570670/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 8332 1132 IN IP4 192.168.22.10
s=SIP Call
t=0 0
m=audio 18848 RTP/AVP 8 101
a=fmtp:101 0-16
a=ptime:20
Jan 12 18:49:03.724: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:551126111111@192.168.22.10:5060 SIP/2.0
Via: SIP/2.0/UDP 1.1.1.1:5060;branch=z9hG4bK79074bd3;rport
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
ROUTER#
Jan 12 18:49:06.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:119999999@192.168.22.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK07d5c0ed
From: <sip:201@192.168.22.21>;tag=204c9eb24ea429bc4f9c57eb-22c0dae6
To: <sip:119999999@192.168.22.10>;tag=4DD3A280-24DB
Max-Forwards: 70
Date: Thu, 12 Jan 2023 18:49:05 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP7861/14.1.1
Accept: application/sdp
Call-Info: <urn:x-cisco-remotecc:hold>; reason= transfer; protect= true; noholdreversion
Content-Length: 340
v=0
o=Cisco-SIPUA 20561 1 IN IP4 192.168.22.21
s=SIP Call
t=0 0
m=audio 16856 RTP/AVP 8 0 116 18 101
b=TIAS:64000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendonly
Jan 12 18:49:06.904: //570671/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 12 Jan 2023 18:49:06 GMT
CSeq: 101 INVITE
Content-Length: 0
Jan 12 18:49:06.904: //570670/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:119999999@1.1.1.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA557FF
From: <sip:551126111111@2.2.2.2.130>;tag=4DD3A2F4-194C
To: <sip:119999999@1.1.1.1>;tag=as3a7ea394
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1673549346
Expires: 180
Content-Length: 286
v=0
o=CiscoSystemsSIP-GW-UserAgent 8332 1133 IN IP4 192.168.22.10
s=SIP Call
t=0 0
m=audio 18848 RTP/AVP 8 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
a=sendonly
ROUTER#
Jan 12 18:49:06.908: //570670/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA557FF;received=2.2.2.2.130;rport=55538
CSeq: 101 INVITE
Server: BR-SAO-CO1-SVV-SBC-01
Supported: replaces
Content-Length: 0
Jan 12 18:49:07.924: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2@192.168.22.10;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK2b7198b3
From: "Milena" <sip:201@192.168.22.10>;tag=204c9eb24ea429bd466e9920-4a3f7682
To: <sip:2@192.168.22.10>
Call-ID: 204c9eb2-4ea40724-2842f22f-718a8858@192.168.22.21
Max-Forwards: 70
Session-ID: 0beddf8c00105000a000204c9eb24ea4;remote=00000000000000000000000000000000
CSeq: 101 INVITE
Expires: 180
Remote-Party-ID: "Milena" <sip:201@192.168.22.10>;party=calling;id-type=subscriber;privacy=off;screen=yes
Content-Length: 351
v=0
o=Cisco-SIPUA 16050 0 IN IP4 192.168.22.21
s=SIP Call
b=AS:4064
t=0 0
m=audio 23986 RTP/AVP 8 0 116 18 101
b=TIAS:64000
a=fmtp:116 mode=20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
Jan 12 18:49:07.932: //570672/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 12 Jan 2023 18:49:07 GMT
CSeq: 101 INVITE
Session-ID: 00000000000000000000000000000000;remote=0beddf8c00105000a000204c9eb24ea4
Content-Length: 0
Jan 12 18:49:07.972: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:2@192.168.22.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK278af46a
To: <sip:2@192.168.22.10>;tag=4DD3BA94-1A1C
From: <sip:201@192.168.22.21>;tag=204c9eb24ea429be2d5fd499-3a94bb9c
Call-ID: A111507A-91E011ED-8C7CFC01-A571E559@192.168.22.10
Session-ID: 5bf2a1ab00105000a000204c9eb24ea4;remote=00000000000000000000000000000000
CSeq: 1000 NOTIFY
Event: kpml
Subscription-State: active; expires=7200
Max-Forwards: 70
ROUTER#2@192.168.22.21:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP204C9EB24EA4"
Content-Length: 0
Jan 12 18:49:08.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK2e2c3498
CSeq: 1001 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Content-Type: application/kpml-response+xml
<?xml version="1.0" encoding="UTF-8"?>
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="0" tag="Backspace OK"/>
Jan 12 18:49:09.504: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK6ca4fc55
CSeq: 1002 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="7" tag="Backspace OK"/>
Jan 12 18:49:09.512: //570673/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:207@192.168.22.68:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA581459
From: "Milena" <sip:201@192.168.22.10>;tag=4DD3C0C0-1CE7
To: <sip:207@192.168.22.68>
Date: Thu, 12 Jan 2023 18:49:09 GMT
Call-ID: A20268BE-91E011ED-8C7EFC01-A571E559@192.168.22.10
Min-SE: 1800
Cisco-Guid: 2702186538-2447380973-2356673537-2775704921
CSeq: 101 INVITE
Timestamp: 1673549349
Contact: <sip:201@192.168.22.10:5060>
Expires: 180
Max-Forwards: 69
Content-Length: 274
v=0
o=CiscoSystemsSIP-GW-UserAgent 2344 9845 IN IP4 192.168.22.10
s=SIP Call
t=0 0
m=audio 18868 RTP/AVP 8 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Jan 12 18:49:09.528: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK35e71f16
CSeq: 1003 NOTIFY
Event: kpml
Subscription-State: terminated; reason=timeout
Max-Forwards: 70
Content-Length: 218
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="487" text="Subscription Exp" suppressed="false" forced_flush="false" digits="" tag="Backspace OK"/>
Jan 12 18:49:09.544: //570673/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.22.10:5060;received=192.168.22.10;branch=z9hG4bKDA581459
CSeq: 101 INVITE
Content-Length: 0
Jan 12 18:49:09.784: //570673/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:207@192.168.22.68>;tag=OkYrfqSoSSFEea8wvE74an-OCV1H0Hqt
CSeq: 101 INVITE
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Contact: <sip:BEB0-21F9@192.168.22.68:5060>
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.0.0,X-cisco-xsi-7.0.1
Remote-Party-ID: "Jaqueline"<sip:207@192.168.22.10:5060>;privacy=off;screen=yes
Content-Length: 0
Jan 12 18:49:09.788: //570672/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Sent:
ROUTER#SIP/2.0 180 Ringing
To: <sip:2@192.168.22.10>;tag=4DD3C1D0-1FE1
CSeq: 101 INVITE
Contact: <sip:BEB0-21F9@192.168.22.10:5060>
Session-ID: 79a4b92bf36d53c2be6b9e59e0350ba1;remote=0beddf8c00105000a000204c9eb24ea4
Content-Length: 0
Jan 12 18:49:10.408: //570670/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 282
v=0
o=root 1227227379 1227227380 IN IP4 1.1.1.1
c=IN IP4 1.1.1.1
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=recvonly
Jan 12 18:49:10.416: //570670/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:119999999@1.1.1.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA5922BC
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jan 12 18:49:10.416: //570671/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: timer
Content-Length: 262
v=0
o=CiscoSystemsSIP-GW-UserAgent 6812 8294 IN IP4 192.168.22.10
s=SIP Call
t=0 0
a=recvonly
a=fmtp:101 0-16
a=ptime:20
Jan 12 18:49:10.424: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ROUTER#ACK sip:119999999@192.168.22.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK7322f889
Max-Forwards: 70
Date: Thu, 12 Jan 2023 18:49:08 GMT
CSeq: 101 ACK
Content-Length: 0
ROUTER#
Jan 12 18:49:15.588: //570673/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 222
v=0
o=- 2211427613 2211427614 IN IP4 192.168.22.68
s=FOXPHONE
t=0 0
a=X-nat:0
m=audio 16390 RTP/AVP 8 101
c=IN IP4 192.168.22.68
a=sendrecv
a=fmtp:101 0-15
Jan 12 18:49:15.592: //570673/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:BEB0-21F9@192.168.22.68:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA5A252E
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 0beddf8c00105000a000204c9eb24ea4;remote=79a4b92bf36d53c2be6b9e59e0350ba1
Content-Length: 0
Jan 12 18:49:15.596: //570672/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <sip:207@192.168.22.10:5060>
Supported: replaces
Supported: timer
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 8443 1496 IN IP4 192.168.22.10
s=SIP Call
t=0 0
m=audio 18876 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
Jan 12 18:49:15.636: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ROUTER#ACK sip:207@192.168.22.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK7a5cbe83
Max-Forwards: 70
Date: Thu, 12 Jan 2023 18:49:14 GMT
CSeq: 101 ACK
Content-Length: 0
ROUTER#
Jan 12 18:49:19.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:207@192.168.22.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK629b95e6
Max-Forwards: 70
Date: Thu, 12 Jan 2023 18:49:17 GMT
CSeq: 102 INVITE
Content-Length: 351
v=0
o=Cisco-SIPUA 16050 1 IN IP4 192.168.22.21
s=SIP Call
b=AS:4064
t=0 0
b=TIAS:64000
a=fmtp:116 mode=20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendonly
Jan 12 18:49:19.572: //570672/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 12 Jan 2023 18:49:19 GMT
CSeq: 102 INVITE
Content-Length: 0
Jan 12 18:49:19.572: //570673/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:BEB0-21F9@192.168.22.68:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA5B7CF
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1673549359
Expires: 180
Content-Length: 286
v=0
o=CiscoSystemsSIP-GW-UserAgent 2344 9846 IN IP4 192.168.22.10
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
a=sendonly
Jan 12 18:49:19.740: //570673/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.22.10:5060;received=192.168.22.10;branch=z9hG4bKDA5B7CF
CSeq: 102 INVITE
Content-Length: 222
v=0
o=- 2211427613 2211427615 IN IP4 192.168.22.68
s=FOXPHONE
t=0 0
a=X-nat:0
a=fmtp:101 0-15
a=recvonly
Jan 12 18:49:19.744: //570673/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA5C1C09
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Jan 12 18:49:19.744: //570672/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: timer
Content-Length: 262
v=0
o=CiscoSystemsSIP-GW-UserAgent 8443 1497 IN IP4 192.168.22.10
s=SIP Call
t=0 0
a=recvonly
a=fmtp:101 0-15
a=ptime:20
Jan 12 18:49:19.752: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK221ed798
Max-Forwards: 70
Date: Thu, 12 Jan 2023 18:49:18 GMT
CSeq: 102 ACK
Content-Length: 0
Jan 12 18:49:19.764: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:119999999@192.168.22.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.21:5060;branch=z9hG4bK5cd2bd5d
Max-Forwards: 70
CSeq: 102 REFER
Refer-To: <sip:207@192.168.22.10?Replaces=204c9eb2-4ea40724-2842f22f-718a8858%40192.168.22.21%3Bto-tag%3D4DD3C1D0-1FE1%3Bfrom-tag%3D204c9eb24ea429bd466e9920-4a3f7682>
Referred-By: <sip:201@192.168.22.10>
Content-Length: 0
Jan 12 18:49:19.768: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 202 Accepted
CSeq: 102 REFER
Content-Length: 0
Jan 12 18:49:19.768: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:BE8C-1652@192.168.22.21:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA5D205C
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: refer
Subscription-State: pending;expires=180
Content-Type: message/sipfrag
Content-Length: 22
SIP/2.0 100 Trying
Jan 12 18:49:19.772: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
REFER sip:119999999@1.1.1.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA5E74F
CSeq: 102 REFER
Max-Forwards: 70
Refer-To: sip:207@192.168.22.10?Replaces=A20268BE-91E011ED-8C7EFC01-A571E559%40192.168.22.10%3Bto-tag%3DOkYrfqSoSSFEea8wvE74an-OCV1H0Hqt%3Bfrom-tag%3D4DD3C0C0-1CE7
Content-Length: 0
Jan 12 18:49:20.156: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Jan 12 18:49:20.160: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA5E74F;received=200.170.
ROUTER#192.130;rport=55538
CSeq: 102 REFER
Supported: replaces
Content-Length: 0
Jan 12 18:49:20.160: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:551126111111@192.168.22.10:5060 SIP/2.0
Via: SIP/2.0/UDP 1.1.1.1:5060;branch=z9hG4bK09cd7a60;rport
Max-Forwards: 70
CSeq: 103 NOTIFY
Event: refer;id=102
Subscription-state: terminated;reason=noresource
Content-Type: message/sipfrag;version=2.0
Supported: replaces
Content-Length: 33
SIP/2.0 503 Service Unavailable
Sent:
SIP/2.0 200 OK
Date: Thu, 12 Jan 2023 18:49:20 GMT
CSeq: 103 NOTIFY
Content-Length: 0
Jan 12 18:49:20.168: //570670/9D62ECA68C70/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA5F190D
Min-SE: 1800
CSeq: 103 INVITE
Max-Forwards: 70
Timestamp: 1673549360
Expires: 180
Content-Length: 274
v=0
o=CiscoSystemsSIP-GW-UserAgent 8332 1134 IN IP4 192.168.22.10
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Jan 12 18:49:20.168: //570673/A110182A8C77/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.22.10:5060;branch=z9hG4bKDA6062E
Min-SE: 1800
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 274
0 Replies 0
