Problem uploading Background image for 8945 IP Phone with CME 10.5
mateenuddinmohd
I have a problem in uploading Image to Cisco ip phone 8945 . IP phone can locate List.xml file but unable to locate image.png files.
<CiscoIPPhoneImageList>
<ImageItem Image="TFTP:Desktops/640x480x24/Roots.png"
URL="TFTP:Desktops/640x480x24/Roots.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/Thumb.png"
URL="TFTP:Desktops/640x480x24/Thumb.png"/>
</CiscoIPPhoneImageList>
When i go to setting--> preferences >background the image is loading as Question Mark.
Thx every one the problem is fixed.
the below command was having mistake
tftp-server flash:Desktops/640x480x24/Thumb.png
instead I was trying with tftp-server flash:/Desktops/640x480x24/Thumb.png
there should not to forward slash before Desktops.
8 Replies 8
I think it should be.
Thx for the response.
My full size image  640x480 is Roots.png and 123x111 is Thumb.png . I tried this setting but doesn't help. Picture attached the error appear on the phone as Question mark.
Please check that both PNG files (background and thumbnail) are stored in the /Desktops/640x480x24/ directory at the TFTP.
And also check that the List.xml was updated.
Inside my List.xml file
Below is the debug tftp event
ROOTS_GRP#debug tftp events
TFTP Event debugging is on
ROOTS_GRP#ter
ROOTS_GRP#terminal mon
ROOTS_GRP#terminal monitor
ROOTS_GRP#
May 22 11:48:32.308: TFTP: Server request for port 43954, socket_id 0x1B27793C for process 178
May 22 11:48:32.308: TFTP: read request from host 172.30.73.202(43954) via GigabitEthernet0/0
May 22 11:48:32.308: TFTP: Looking for Desktops/640x480x24/List.xml
May 22 11:48:32.308: TFTP: Opened flash0:Desktops/640x480x24/List.xml, fd 4, size 152 for process 178
May 22 11:48:32.308: TFTP: Sending block 1 (retry 0), len 152, socket_id 0x1B27793C
May 22 11:48:32.352: TFTP: Received ACK for block 1, socket_id 0x1B27793C
May 22 11:48:32.352: TFTP: Finished flash0:Desktops/640x480x24/List.xml, time 00:00:00 for process 178
May 22 11:48:32.624: TFTP: Server request for port 48551, socket_id 0x1B26907C for process 178
May 22 11:48:32.624: TFTP: read request from host 172.30.73.202(48551) via GigabitEthernet0/0
May 22 11:48:32.624: TFTP: Looking for Desktops/640x480x24/Thumb.png
May 22 11:48:32.624: TFTP: Sending error 1 No such file
May 22 11:51:26.963: TFTP: Server request for port 49156, socket_id 0x1B27793C for process 65
May 22 11:51:26.963: TFTP: read request from host 192.168.26.2(49156) via GigabitEthernet0/0
May 22 11:51:26.963: TFTP: Looking for CTLSEP5CFC665CD3CB.tlv
May 22 11:51:26.963: TFTP: Sending error 1 No such file
May 22 11:51:27.359: TFTP: Server request for port 49157, socket_id 0x1B26907C for process 65
Jaime Valencia
Are the images in the right format for the phone model?
java
if this helps, please rate
In addition, make sure that your images were uploaded to all cucm nodes in the cluster along List file. Then restart tftp service on all nodes.
I am sorry I just realized that its CME not CUCM.
Did you try to rename the files? Format flash?
