07-15-2011 11:22 AM - edited 03-16-2019 05:58 AM
Hello.
I have problem with configuring 9971 IP phone in CME 8.6. I followed the instructions from http://www.cisco.com/en/US/products/sw/voicesw/ps2156/products_configuration_example09186a0080b82d00.shtml but IP phone is not being correctly registered. I mean that commands "show voice register pool mac MAC" and "show voice register pool all" indicate the phone has registered but on IP phone display I see "Phone not registered" and I'm unable to make calls.
Below is the output from the above commands.
#show voice register pool mac E8BA.70FB.1990
Pool ID IP Address Ln DN Number State
2 E8BA.70FB.1990 10.10.10.17 1 1 55 REGISTERED
#show voice register pool all
Pool Tag 2
Config:
Mac address is E8BA.70FB.1990
Type is 9971
Number list 1 : DN 1
Proxy Ip address is 0.0.0.0
Current Phone load version is Cisco-CP9971/9.1.1
DTMF Relay is enabled, rtp-nte
Call Waiting is enabled
DnD is disabled
Video is enabled
Camera is enabled
Busy trigger per button value is 0
keep-conference is enabled
registration expires timer max is 3600 and min is 120
username test password pass
kpml signal is enabled
Lpcor Type is none
Transport type is udp
service-control mechanism is supported
registration Call ID is e8ba70fb-1990009e-443626c7-342a9293@10.10.10.17
Registration method: per line
Privacy feature is not configured.
Privacy button is disabled
active primary line is: 55
contact IP address: 10.10.10.17 port 5060
Phone SIS Version: 5.1.0
GW SIS Version: 1.0.0
Dialpeers created:
Dial-peers for Pool 2:
dial-peer voice 40003 voip
destination-pattern 55
session target ipv4:10.10.10.17:5060
session protocol sipv2
dtmf-relay rtp-nte
digit collect kpml
codec g711ulaw bytes 160
no vad
after-hours-exempt FALSE
Statistics:
Active registrations : 18
Total SIP phones registered: 1
Total Registration Statistics
Registration requests : 175
Registration success : 175
Registration failed : 0
unRegister requests : 157
unRegister success : 157
unRegister failed : 0
Attempts to register
after last unregister : 0
Last register request time : 20:01:30.279 CET Fri Jul 15 2011
Last unregister request time : 20:00:28.247 CET Fri Jul 15 2011
Register success time : 20:01:30.279 CET Fri Jul 15 2011
Unregister success time : 20:00:28.247 CET Fri Jul 15 2011
This is the only SIP IP phone. The rest of IP phones are using SCCP. I tried resetting that IP phone but it didn't work.
Has anyone successfully registered 9971 in CME 8.6? If yes, please share with the sample configuration.
Below is my configuration regarding SIP.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 3600 min 120
voice register global
mode cme
source-address 10.10.1.1 port 5060
max-dn 10
max-pool 10
load 9971 sip9971.9-1-1SR1
create profile sync 006095145366745A
ip qos dscp af42 video
camera
video
voice register dn 1
number 55
name Office
voice register pool 2
id mac E8BA.70FB.1990
type 9971
number 1 dn 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
camera
video
tftp-server flash:dkern9971.100609R2-9-1-1SR1.sebn alias dkern9971.100609R2-9-1-1SR1.sebn
tftp-server flash:kern9971.9-1-1SR1.sebn alias kern9971.9-1-1SR1.sebn
tftp-server flash:rootfs9971.9-1-1SR1.sebn alias rootfs9971.9-1-1SR1.sebn
tftp-server flash:sboot9971.031610R1-9-1-1SR1.sebn alias sboot9971.031610R1-9-1-1SR1.sebn
tftp-server flash:sip9971.9-1-1SR1.loads alias sip9971.9-1-1SR1.loads
tftp-server flash:skern9971.022809R2-9-1-1SR1.sebn alias skern9971.022809R2-9-1-1SR1.sebn
Thanks in advance.
07-19-2012 12:32 PM
Did you check if the SEPE8BA70FB1990.cnf.xml files was created on flash:?
Insert these commands under voice register global:
tftp-path flash:
load 9971 sip9971.9-1-1SR1.loads
create profile
reset
