Problem with g711 to g729 transcode using sip & 2811 dspfarm
bobl12345
Hello-
I would like to connect a generic g711 SIP endpoint to a generic g729r8 or g729br8 endpoint using transcoder on 2811 dspfarm.
I have multiple PVDM2-64s installed on 2811.
The 2811 is registered to a CME on a different router.
My dial-peers are targeted at a generic non-cisco sip server.
Everything works fine as long as its g711 to g711, or g729 to g729 but I can't seem to force g711 to g729.
If I set dial-peer 100 codec to g729  and dial-peer 101 codec to g711
I send a sip INVITE to 101@server  with G729
The 2811 sends back unsupported, 501 not implemented Q.850 cause code 65.
I suspect the problem is with dial-peer setup and codec preferences/classes or I need to point my session target at CME?
Thanks very much for helping!
Here is my 2811 config.
#show sdspfarm units
mtp-1 Device: TCP socket:[-1]  UNREGISTERED
actual_stream:0 max_stream 0 IP:0.0.0.0  0  Unknown 0 keepalive 0
max-mtps:4, max-streams:16, alloc-streams:0, act-streams:0
# running config snip
sccp local FastEthernet0/0
sccp ccm xxxxx identifier 1 version 5.0.
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate profile 1 register 123456
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 5
associate application SCCP
dial-peer voice 100 voip
service session
session protocol sipv2
session target ipv4:192.168.0.3
incoming called-number 100
dial-peer voice 101 voip
destination-pattern 101
codec g711alaw
gateway
timer receive-rtp 1200
sip-ua
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP   Status : ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 5
Number of Resource Available : 5
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
SLOT DSP VERSION  STATUS CHNL USE   TYPE   RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
1    3   25.0.256 UP     N/A  FREE  xcode  1      -         -         -
Total number of DSPFARM DSP channel(s) 5
#show sccp all
SCCP Admin State: UP
Gateway IP Address: xxxxxxx, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: xxxxxxxx, Port Number: 2000
                Priority: N/A, Version: 5.0.1, Identifier: 1
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: xxxxxxx, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 10, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
SCCP Application Service(s) Statistics:
Profile Identifier: 1, Service Type: Transcoding
TCP packets rx 165, tx 167
Unsupported pkts rx 0, Unrecognized pkts rx 0
Register tx 1, successful 1, rejected 0, failed 0
KeepAlive tx 162, successful 162, failed 0
OpenReceiveChannel rx 0, successful 0, failed 0
CloseReceiveChannel rx 0, successful 0, failed 0
StartMediaTransmission rx 0, successful 0, failed 0
StopMediaTransmission rx 0, successful 0, failed 0
PortReq rx 0
PortRes tx 0, successful 0, failed 0
PortClose rx 0
QosListen rx 0
QosPath rx 0
QosTeardown rx 0, send 0, recv 0, sendrecv 0
QosResvNotify tx 0, send 0, recv 0, sendrecv 0
QosErrorNotify tx 0, send 0, recv 0, sendrecv 0
   err0 0, err1 0, err2 0, err3 0, err4 0, err5 0,
   err6 0, err7 0, err8 0, err9 0, err10 0, err11 0,
   err12 0
QosModify rx 0, send 0, recv 0, sendrecv 0
UpdateDscp rx 0
Reset rx 0, successful 0, failed 0
MediaStreamingFailure rx 0
MediaStreamingFailure tx 0
Switchover 0, Switchback 0
CCM Group Identifier: 1
Description: None
Binded Interface: FastEthernet0/0, IP Address: xxxxxxxxxxxxx
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated Profile: 1, Registration Name: 123456
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 5, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: IMMEDIATE, Switchback Method: IMMEDIATE
Switchback Interval: 5 sec, Switchback Timeout: 0 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
Total number of active session(s) 0, and connection(s) 0
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
Total active sessions 0, connections 0, rsvp sessions 0
25 Replies 25
Dave -
Here is the config from the working model above...
-Bob
Building configuration...
Current configuration : 3457 bytes
version 12.4
service sequence-numbers
hostname zzzzz103
boot-start-marker
boot system flash c2800nm-ipvoicek9-mz.124-15.T5.bin
boot system flash c2800nm-ipvoice-mz
boot-end-marker
card type e1 1 1
logging buffered 10000000
no logging console
enable secret 5 $1$40e6$6DTSj.6Ls/N1FRIHK/9N00
no aaa new-model
network-clock-participate slot 1
dot11 syslog
ip cef
no ip domain lookup
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice-card 1
dspfarm
dsp services dspfarm
voice call carrier capacity active
voice dsp crash-dump file-limit 4
voice dsp crash-dump destination flash:DSPcrash.log
voice service pots
voice service voip
allow-connections sip to sip
sip
  no call service stop
voice class codec 1
codec preference 1 g729r8
voice hpi capture buffer 10000000
archive
log config
  hidekeys
controller E1 1/0
framing NO-CRC4
clock source internal
ds0-group 1 timeslots 7 type e&m-immediate-start dtmf dnis
description Cabled to GL Card #5 for subjective test.
controller E1 1/1
shutdown
description LVCC Voice LAN
ip address zzzzz.202.233 255.255.254.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.20 255.255.255.0
duplex auto
speed auto
ip default-gateway zzzzz.202.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 zzzzz.202.1
ip http server
no ip http secure-server
control-plane
voice-port 1/0:1
sccp ccm zzzzz.202.233 identifier 1 version 5.0.1
sccp
sccp ccm group 1
keepalive retries 5
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 5
dial-peer voice 2001 pots
destination-pattern 2001
dial-peer voice 5010 voip
destination-pattern 5010
no modem passthrough
session target ipv4:zzzzz.202.231
dtmf-relay rtp-nte
playout-delay nominal 30
playout-delay minimum low
playout-delay mode fixed
codec g711alaw bytes 80
no vad
dial-peer voice 4722 pots
destination-pattern zzzzz7334722
port 1/0:1
dial-peer voice 2003 pots
destination-pattern 2003
description ***To Ext 100***
destination-pattern 100
incoming called-number 101
no vad
description **** To ext 101*****
codec g711alaw
no vad
gateway
sip-ua
telephony-service
sdspfarm units 4
sdspfarm transcode sessions 8
sdspfarm tag 1 123456
max-ephones 1
max-dn 1
ip source-address zzzzz.202.233 port 2000
max-conferences 8 gain -6
transfer-system full-consult
ephone-dn  1
number AAAA
ephone  1
mac-address CCCC.CCCC.CCCC
button  1:1
line con 0
exec-timeout 0 0
privilege level 15
password cisco
line aux 0
password nvs
line vty 0 4
exec-timeout 0 0
privilege level 15
password cisco
no login
scheduler allocate 20000 1000
end
Your config looks good, only one problem I see:
telephony-service
sdspfarm  units 4
sdspfarm transcode sessions 8  <------Change this to 5
max-ephones 1
max-dn  1
conf t
telephony-service
sdspfarm transcode sessions 5
exit
no sccp
sccp
This should register your profile locally.
You do have DSP's on this 2811 right?
Thanks, -Dave
Dave -
My 2811 has 4 PVDM slots filled, each occupied with PVDM2-64s.  I am going to do some additional testing with real media traffic and I'll report back with results.   Thanks again for sticking with me on this!
-Bob
NP, but if you get stuck I'd suggest opening a TAC case, that way we can log in and look at everything with you...much easier than going back and
forth.
Your pertinent configs are attached, see below:
voice-card 0
dspfarm
voice-card 1
dspfarm
sccp
sccp ccm group 1
keepalive retries 5
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 5
telephony-service
sdspfarm  units 4
max-ephones 1
max-dn  1
If you have your DSP's in the PVDM slots, on the motherboard, then you need to farm them out from "voice-card 0" like in the above config.
Other than that, everything looks fine.
Thanks, -Dave
Thanks, Dave-
Just to confirm, you saw the SIP call flow I posted above showing success?  The thread is sort of fragmented so I want to make sure you saw that.
I am going to run some call tests to make sure the media is OK.
-Bob
Yup, I did...thanks Bob.
Dave-
Many thanks again for the help. I have one small remaining glitch. My media from g711 to g729 is good quality. My media from g729 to g711 results in "comfort noise" out of the 2811 g711 side (see #3 below) . So I have only half the duplex working.
I'm sending in vanilla g729 at 10 msec. No annex b.
Here is what I've done so far to debug-
1. Verified my originating g711, g729 streams and the terminating 2811 g729 streams are all good qualty by using audio packet reference tool.
2.  Captured the g729 packets output from the good leg of the duplex (i.e. the g711 to g729 output from the 2811) and then fed them back into g729 input side of the 2811 just to absolutely remove any rtp/g729 format problem on my end (I prevented hall of mirrors by just running a few seconds and analyzing the g711 data).
3. When I look at (and listen to)  the g711 audio output from the 2811 - it seems like 100% comfort noise, however VAD is off. It is definately not all "zero or idle" and definately not wild data.  Seems to be inserting nothing but legit comfort noise. The noise is in regular g711a packets, rather than special CN pkts.
I'm going to try to add another ephone just in case it nees to see two phantom endpoints.
Config is exactly same as in above posts.  Hoping this rings a bell and its a simple config setting I am missing.
-Bob
Message was edited by: bobl12345  edited to add clarification of comfort noise
Adding log file...
Received:
INVITE sip:101@192.168.0.3 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.3;branch=z9hG4bKtest0
To: <101>
Call-ID: test-192.168.0.3:9128-19128
CSeq: 1 INVITE
Contact: <100>
User-Agent: zzzzz zzzzzzzz
Allow: INVITE
Allow: ACK
Allow: CANCEL
Allow: BYE
Allow: INFO
Max-Forwards: 70
Content-Type: application/sdp
Content-Length: 178
v=0
o=test 19128 6729127220 IN IP4 192.168.0.3
s=test session
c=IN IP4 192.168.0.3
t=0 0
m=audio 19128 RTP/AVP 18
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=ptime:10
003396: *Aug 28 00:03:34.141: //116/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
003397: *Aug 28 00:03:34.141: //-1/88A41A6280D8/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=100
   ----- ccCallInfo IE subfields -----
   cisco-ani=100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=101
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
003398: *Aug 28 00:03:34.145: //-1/88A41A6280D8/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x45F683C0, Call Info(
   Calling Number=100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=101(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=116
003399: *Aug 28 00:03:34.145: //-1/88A41A6280D8/CCAPI/ccCheckClipClir:
   In: Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
003400: *Aug 28 00:03:34.145: //-1/88A41A6280D8/CCAPI/ccCheckClipClir:
   Out: Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
003401: *Aug 28 00:03:34.145: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003402: *Aug 28 00:03:34.145: :cc_get_feature_vsa malloc success
003403: *Aug 28 00:03:34.145: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003404: *Aug 28 00:03:34.145:  cc_get_feature_vsa count is 1
003405: *Aug 28 00:03:34.145: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003406: *Aug 28 00:03:34.145: :FEATURE_VSA attributes are: feature_name:0,feature_time:1175235856,feature_id:116
003407: *Aug 28 00:03:34.145: //116/88A41A6280D8/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=101(TON=Unknown, NPI=Unknown))
003408: *Aug 28 00:03:34.145: //116/88A41A6280D8/CCAPI/cc_process_call_setup_ind:
   Event=0x472E30E8
003409: *Aug 28 00:03:34.153: //116/88A41A6280D8/CCAPI/ccCallSetContext:
   Context=0x482266A8
003410: *Aug 28 00:03:34.153: //116/88A41A6280D8/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 116 with tag 100 to app "_ManagedAppProcess_Default"
003411: *Aug 28 00:03:34.153: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <101>
Date: Sat, 28 Aug 2010 00:03:34 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Allow-Events: telephone-event
Content-Length: 0
003412: *Aug 28 00:03:34.153: //116/88A41A6280D8/CCAPI/ccCallProceeding:
003413: *Aug 28 00:03:34.157: //116/88A41A6280D8/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=101, Params=0x48227570, Progress Indication=NULL(0)
003414: *Aug 28 00:03:34.157: //116/88A41A6280D8/CCAPI/ccCheckClipClir:
003415: *Aug 28 00:03:34.157: //116/88A41A6280D8/CCAPI/ccCheckClipClir:
003416: *Aug 28 00:03:34.157: //116/88A41A6280D8/CCAPI/ccCallSetupRequest:
   Destination Pattern=101, Called Number=101, Digit Strip=FALSE
003417: *Aug 28 00:03:34.157: //116/88A41A6280D8/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=100, Final Destination Flag=TRUE,
   Guid=88A41A62-B16E-11DF-80D8-A52D4E45C415, Outgoing Dial-peer=101
003418: *Aug 28 00:03:34.157: //116/88A41A6280D8/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=100
   cisco-ani=100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=101
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
003419: *Aug 28 00:03:34.157: //116/88A41A6280D8/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x45F683C0, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=101(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=101, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
003420: *Aug 28 00:03:34.157: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003421: *Aug 28 00:03:34.157: :cc_get_feature_vsa malloc success
003422: *Aug 28 00:03:34.157: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003423: *Aug 28 00:03:34.157:  cc_get_feature_vsa count is 2
003424: *Aug 28 00:03:34.157: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003425: *Aug 28 00:03:34.161: :FEATURE_VSA attributes are: feature_name:0,feature_time:1175236720,feature_id:117
003426: *Aug 28 00:03:34.161: //117/88A41A6280D8/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
003427: *Aug 28 00:03:34.161: //117/88A41A6280D8/CCAPI/ccCallSetContext:
   Context=0x48227520
003428: *Aug 28 00:03:34.161: //116/88A41A6280D8/CCAPI/ccSaveDialpeerTag:
003429: *Aug 28 00:03:34.161: //117/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_stream:
003430: *Aug 28 00:03:34.161: cc_api_set_xcode_stream Line: 4391
003431: *Aug 28 00:03:34.161: //116/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_stream:
003432: *Aug 28 00:03:34.161: cc_api_set_xcode_stream Line: 4391
003433: *Aug 28 00:03:34.161: //117/88A41A6280D8/CCAPI/cc_api_event_indication:
   Event=150, Call Id=117
003434: *Aug 28 00:03:34.161: //117/88A41A6280D8/CCAPI/cc_api_event_indication:
   Event Is Sent To Conferenced SPI(s) Directly
003435: *Aug 28 00:03:34.165: //117/88A41A6280D8/CCAPI/cc_api_call_proceeding:
   Interface=0x45F683C0, Progress Indication=NULL(0)
003436: *Aug 28 00:03:34.165: //116/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
003437: *Aug 28 00:03:34.165: cc_api_get_xcode_stream : 4369
003438: *Aug 28 00:03:34.169: //117/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
003439: *Aug 28 00:03:34.169: cc_api_get_xcode_stream : 4369
003440: *Aug 28 00:03:34.169: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:101@192.168.0.3:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.20:5060;branch=z9hG4bK45D32
Remote-Party-ID: <100>;party=calling;screen=no;privacy=off
To: <101>
Call-ID: 88A86012-B16E11DF-80DDA52D-4E45C415@192.168.0.20
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 2292456034-2976780767-2161681709-1313195029
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1282953814
Contact: <100>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 8833 5368 IN IP4 192.168.0.20
s=SIP Call
c=IN IP4 192.168.0.20
t=0 0
m=audio 19422 RTP/AVP 8
a=rtpmap:8 PCMA/8000
a=ptime:20
003441: *Aug 28 00:03:34.173: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <101>;tag=3de9ebe2test1
CSeq: 101 INVITE
Contact: <100>
Allow: INVITE
Allow: ACK
Allow: CANCEL
Allow: BYE
Allow: INFO
Content-Length: 178
v=0
o=test 9128 20768432111 IN IP4 192.168.0.3
s=test session
t=0 0
m=audio 9128 RTP/AVP 8 13
a=rtpmap:13 CN/8000
a=ptime:20
003442: *Aug 28 00:03:34.177: //117/88A41A6280D8/CCAPI/cc_api_event_indication:
   Event=141, Call Id=117
003443: *Aug 28 00:03:34.177: //117/88A41A6280D8/CCAPI/cc_api_event_indication:
003444: *Aug 28 00:03:34.177: //117/88A41A6280D8/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=117,
   Caps(Codec=0x0, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
003445: *Aug 28 00:03:34.177: //117/88A41A6280D8/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=250(ms), Fax Nom=300(ms))
003446: *Aug 28 00:03:34.177: //116/88A41A6280D8/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=117, Source Call Id=116,
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=10, Signal Type=2, Seq Num Start=1)
003447: *Aug 28 00:03:34.177: //117/88A41A6280D8/CCAPI/cc_api_call_connected:
   Interface=0x45F683C0, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
003448: *Aug 28 00:03:34.177: //117/88A41A6280D8/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
003449: *Aug 28 00:03:34.181: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:100@192.168.0.3:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.20:5060;branch=z9hG4bK4611A3
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
003450: *Aug 28 00:03:34.181: //116/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4561D288, callID1=0x74, callID2=0x75, tag=0x0)
003451: *Aug 28 00:03:34.181: //116/88A41A6280D8/CCAPI/ccConferenceCreate:
   Conference Id=0x4561D288, Call Id1=116, Call Id2=117, Tag=0x0
003452: *Aug 28 00:03:34.181: //116/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
003453: *Aug 28 00:03:34.181: ccConferenceCreate: ret1=0, codecMask1=4, bytes1=10, negot1=1, dtmf1=0
                    ret2=0, codecMask2=2, bytes2=160, negot2=1, dtmf2=0
003454: *Aug 28 00:03:34.181: //116/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
003455: *Aug 28 00:03:34.181: cc_api_get_xcode_stream : 4369
003456: *Aug 28 00:03:34.181: //117/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
003457: *Aug 28 00:03:34.181: cc_api_get_xcode_stream : 4369
003458: *Aug 28 00:03:34.181: //116/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
003459: *Aug 28 00:03:34.181: cc_api_get_xcode_stream : 4369
003460: *Aug 28 00:03:34.181: //116/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
003461: *Aug 28 00:03:34.185: cc_api_get_xcode_stream : 4369
003462: *Aug 28 00:03:34.185: //116/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x46, Source Interface=0x45F683C0, Source Call Id=116,
   Destination Call Id=117, Disposition=0x0, Tag=0x0
003463: *Aug 28 00:03:34.185: //117/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
003464: *Aug 28 00:03:34.185: cc_api_get_xcode_stream : 4369
003465: *Aug 28 00:03:34.185: //117/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x46, Source Interface=0x45F683C0, Source Call Id=117,
   Destination Call Id=116, Disposition=0x0, Tag=0x0
003466: *Aug 28 00:03:34.185: //116/88A41A6280D8/CCAPI/cc_generic_bridge_done:
003467: *Aug 28 00:03:34.185: //116/88A41A6280D8/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x46, Destination Call Id=117)
003468: *Aug 28 00:03:34.185: //117/88A41A6280D8/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x46, Destination Call Id=116)
003469: *Aug 28 00:03:34.185: //116/88A41A6280D8/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x46, Call Id1=116, Call Id2=117
003470: *Aug 28 00:03:34.185: //116/88A41A6280D8/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
003471: *Aug 28 00:03:34.185: //116/88A41A6280D8/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
003472: *Aug 28 00:03:34.189: //116/88A41A6280D8/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=116
003473: *Aug 28 00:03:34.193: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <101>;tag=1C91D98-1796
CSeq: 1 INVITE
Remote-Party-ID: <101>;party=called;screen=no;privacy=off
Contact: <100>
Supported: replaces
Content-Length: 214
v=0
o=CiscoSystemsSIP-GW-UserAgent 2463 2129 IN IP4 192.168.0.20
s=SIP Call
t=0 0
m=audio 17000 RTP/AVP 18
a=fmtp:18 annexb=no
a=ptime:10
003474: *Aug 28 00:03:34.193: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:101@192.168.0.3 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.3;branch=z9hG4bKtest1
CSeq: 1 ACK
Contact: <100>
Allow: INVITE
Allow: ACK
Allow: CANCEL
Allow: BYE
Allow: INFO
Max-Forwards: 70
Content-Length: 0
003475: *Aug 28 00:03:34.225: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x46633C60, Interface Type=9, Destination=0.0.0.0, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
003476: *Aug 28 00:03:34.225: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003477: *Aug 28 00:03:34.225: :cc_get_feature_vsa malloc success
003478: *Aug 28 00:03:34.225: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003479: *Aug 28 00:03:34.225:  cc_get_feature_vsa count is 3
003480: *Aug 28 00:03:34.229: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003481: *Aug 28 00:03:34.229: :FEATURE_VSA attributes are: feature_name:0,feature_time:1175236504,feature_id:118
003482: *Aug 28 00:03:34.229: //118/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
003483: *Aug 28 00:03:34.229: //118/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x45624770
003484: *Aug 28 00:03:34.229: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x464C503C, Interface Type=25, Destination=, Mode=0x0,
003485: *Aug 28 00:03:34.229: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003486: *Aug 28 00:03:34.229: :cc_get_feature_vsa malloc success
003487: *Aug 28 00:03:34.229: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003488: *Aug 28 00:03:34.229:  cc_get_feature_vsa count is 4
003489: *Aug 28 00:03:34.229: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003490: *Aug 28 00:03:34.229: :FEATURE_VSA attributes are: feature_name:0,feature_time:1175236072,feature_id:119
003491: *Aug 28 00:03:34.229: //119/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Interface=0x464C503C, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
003492: *Aug 28 00:03:34.229: //119/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
003493: *Aug 28 00:03:34.229: //119/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=25, FlowMode=1
003494: *Aug 28 00:03:34.229: //119/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x45624790
003495: *Aug 28 00:03:34.233: //118/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Interface=0x46633C60, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
003496: *Aug 28 00:03:34.233: //118/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
003497: *Aug 28 00:03:34.233: //119/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x47E86FC8, callID1=0x77, callID2=0x76, tag=0x0)
003498: *Aug 28 00:03:34.233: //119/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   Conference Id=0x47E86FC8, Call Id1=119, Call Id2=118, Tag=0x0
003499: *Aug 28 00:03:34.233: //119/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x47, Source Interface=0x464C503C, Source Call Id=119,
   Destination Call Id=118, Disposition=0x0, Tag=0x0
003500: *Aug 28 00:03:34.233: //118/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x47, Source Interface=0x46633C60, Source Call Id=118,
   Destination Call Id=119, Disposition=0x0, Tag=0x0
003501: *Aug 28 00:03:34.233: //119/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
003502: *Aug 28 00:03:34.233: //119/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x47, Destination Call Id=118)
003503: *Aug 28 00:03:34.233: //118/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x47, Destination Call Id=119)
003504: *Aug 28 00:03:34.233: //118/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x0, Params=0x47E86BC0, Call Id=118
003505: *Aug 28 00:03:34.237: //119/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x47, Call Id1=119, Call Id2=118
003506: *Aug 28 00:03:34.237: //118/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46633C60, Call Id=118
003507: *Aug 28 00:03:34.241: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
003508: *Aug 28 00:03:34.241: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003509: *Aug 28 00:03:34.241: :cc_get_feature_vsa malloc success
003510: *Aug 28 00:03:34.241: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003511: *Aug 28 00:03:34.241:  cc_get_feature_vsa count is 5
003512: *Aug 28 00:03:34.241: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003513: *Aug 28 00:03:34.241: :FEATURE_VSA attributes are: feature_name:0,feature_time:1175236288,feature_id:120
003514: *Aug 28 00:03:34.241: //120/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
003515: *Aug 28 00:03:34.241: //120/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x456247B0
003516: *Aug 28 00:03:34.245: //120/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
003517: *Aug 28 00:03:34.245: //120/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
003518: *Aug 28 00:03:34.245: //118/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x47E87008, Params=0x47E86FE8, Call Id=118
003519: *Aug 28 00:03:34.245: //119/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x47E86FC8, callID1=0x77, callID2=0x78, tag=0x0)
003520: *Aug 28 00:03:34.245: //119/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   Conference Id=0x47E86FC8, Call Id1=119, Call Id2=120, Tag=0x0
003521: *Aug 28 00:03:34.245: //120/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x48, Source Interface=0x46633C60, Source Call Id=120,
003522: *Aug 28 00:03:34.245: //119/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x48, Destination Call Id=118)
003523: *Aug 28 00:03:34.245: //120/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x48, Destination Call Id=119)
003524: *Aug 28 00:03:34.245: //119/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x48, Source Interface=0x464C503C, Source Call Id=119,
   Destination Call Id=120, Disposition=0x0, Tag=0x0
003525: *Aug 28 00:03:34.249: //119/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
003526: *Aug 28 00:03:34.249: //119/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x48, Call Id1=119, Call Id2=120
003527: *Aug 28 00:03:34.249: //118/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x18E00, Params=0x47E873B8, Call Id=118
003528: *Aug 28 00:03:34.249: //118/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
003529: *Aug 28 00:03:34.253: //120/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x0, Params=0x47E86BC0, Call Id=120
003530: *Aug 28 00:03:34.253: //118/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
003531: *Aug 28 00:03:34.253: //120/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x46633C60, Call Id=120
003532: *Aug 28 00:03:34.257: //120/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x47E87008, Params=0x47E86FE8, Call Id=120
003533: *Aug 28 00:03:34.257: //120/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x18E00, Params=0x47E873B8, Call Id=120
003534: *Aug 28 00:03:34.261: //120/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
003535: *Aug 28 00:03:34.261: //120/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
003536: *Aug 28 00:04:37.449: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:101@192.168.0.3 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.3;branch=z9hG4bKtest2
CSeq: 2 BYE
Contact: <100>
Allow: INVITE
Allow: ACK
Allow: CANCEL
Allow: BYE
Allow: INFO
Max-Forwards: 70
Content-Length: 0
003537: *Aug 28 00:04:37.449: //117/88A41A6280D8/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=117
003538: *Aug 28 00:04:37.449: //116/88A41A6280D8/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x45F683C0, Call Id=116
003539: *Aug 28 00:04:37.449: //116/88A41A6280D8/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
003540: *Aug 28 00:04:37.453: //116/88A41A6280D8/CCAPI/ccConferenceDestroy:
   Conference Id=0x46, Tag=0x0
003541: *Aug 28 00:04:37.453: //116/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
003542: *Aug 28 00:04:37.453: //117/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
003543: *Aug 28 00:04:37.453: //116/88A41A6280D8/CCAPI/cc_generic_bridge_done:
003544: *Aug 28 00:04:37.453: //116/88A41A6280D8/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
003545: *Aug 28 00:04:37.453: //116/88A41A6280D8/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
003546: *Aug 28 00:04:37.453: //117/88A41A6280D8/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
003547: *Aug 28 00:04:37.453: //117/88A41A6280D8/CCAPI/ccCallDisconnect:
003548: *Aug 28 00:04:37.457: //116/88A41A6280D8/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x45F683C0, Tag=0x0, Call Id=116,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
003549: *Aug 28 00:04:37.457: //116/88A41A6280D8/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
003550: *Aug 28 00:04:37.457: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003551: *Aug 28 00:04:37.457: :cc_free_feature_vsa freeing 460CAD08
003552: *Aug 28 00:04:37.457: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003553: *Aug 28 00:04:37.457:  vsacount in free is 4
003554: *Aug 28 00:04:37.461: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sat, 28 Aug 2010 00:04:37 GMT
CSeq: 2 BYE
Reason: Q.850;cause=16
Content-Length: 0
003555: *Aug 28 00:04:37.461: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:100@192.168.0.3:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.20:5060;branch=z9hG4bK4716D9
Max-Forwards: 70
Timestamp: 1282953877
CSeq: 102 BYE
Content-Length: 0
003556: *Aug 28 00:04:37.465: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Contact: <100>
Allow: INVITE
Allow: ACK
Allow: CANCEL
Allow: BYE
Allow: INFO
Content-Length: 0
003557: *Aug 28 00:04:37.469: //117/88A41A6280D8/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x45F683C0, Tag=0x0, Call Id=117,
003558: *Aug 28 00:04:37.469: //117/88A41A6280D8/CCAPI/cc_api_call_disconnect_done:
003559: *Aug 28 00:04:37.469: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003560: *Aug 28 00:04:37.469: :cc_free_feature_vsa freeing 460CB068
003561: *Aug 28 00:04:37.469: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003562: *Aug 28 00:04:37.469:  vsacount in free is 3
003563: *Aug 28 00:04:37.729: //120/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x47E87418, Call Id=120
003564: *Aug 28 00:04:37.729: //120/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
003565: *Aug 28 00:04:37.729: //120/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
003566: *Aug 28 00:04:37.729: //119/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
   Conference Id=0x48, Tag=0x0
003567: *Aug 28 00:04:37.729: //119/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
003568: *Aug 28 00:04:37.733: //120/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
003569: *Aug 28 00:04:37.733: //119/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
003570: *Aug 28 00:04:37.733: //120/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
   Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
003571: *Aug 28 00:04:37.733: //120/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
   Cause Value=0, Call Entry(Responsed=TRUE, Cause Value=0)
003572: *Aug 28 00:04:37.733: //120/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46633C60, Tag=0x0, Call Id=120,
   Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
003573: *Aug 28 00:04:37.733: //120/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
003574: *Aug 28 00:04:37.733: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003575: *Aug 28 00:04:37.733: :cc_free_feature_vsa freeing 460CAEB8
003576: *Aug 28 00:04:37.733: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003577: *Aug 28 00:04:37.733:  vsacount in free is 2
003578: *Aug 28 00:04:37.737: //118/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x47E87418, Call Id=118
003579: *Aug 28 00:04:37.737: //118/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
003580: *Aug 28 00:04:37.741: //118/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
003581: *Aug 28 00:04:37.741: //119/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
   Conference Id=0x47, Tag=0x0
003582: *Aug 28 00:04:37.741: //119/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
003583: *Aug 28 00:04:37.741: //118/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
003584: *Aug 28 00:04:37.741: //119/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
003585: *Aug 28 00:04:37.741: //118/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
003586: *Aug 28 00:04:37.741: //118/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
003587: *Aug 28 00:04:37.745: //118/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46633C60, Tag=0x0, Call Id=118,
003588: *Aug 28 00:04:37.745: //118/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
003589: *Aug 28 00:04:37.745: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003590: *Aug 28 00:04:37.745: :cc_free_feature_vsa freeing 460CAF90
003591: *Aug 28 00:04:37.745: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003592: *Aug 28 00:04:37.745:  vsacount in free is 1
003593: *Aug 28 00:04:37.745: //119/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
003594: *Aug 28 00:04:37.745: //119/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
003595: *Aug 28 00:04:37.745: //119/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x464C503C, Tag=0x0, Call Id=119,
003596: *Aug 28 00:04:37.749: //119/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
003597: *Aug 28 00:04:37.749: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003598: *Aug 28 00:04:37.749: :cc_free_feature_vsa freeing 460CADE0
003599: *Aug 28 00:04:37.749: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003600: *Aug 28 00:04:37.749:  vsacount in free is 0
003601: *Aug 28 00:07:37.473: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
Dave -
Please ignore problem with half-duplex, one of the TX port numbers was wrong on my end. I missed that looking at the wireshark trace. Apologies.
One thing I am wondering about is this command....
Can you summarize the meaning? Looking at the docs, I'm not quite sure of the implication. I know that I could not activate one of the dsp farms without setting it b ut not sure of the meaning.
-Bob
Hey Bob,
Sorry, I wasn't around the past few days.
This sets the T1/E1 etc... ports in slot 1 to participate in the TDM backplane clocking domain.
http://www.cisco.com/en/US/partner/docs/ios/12_3/vvf_r/vrg_n1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1001437
The command:
network-clock-select 1 T1 XXX
This tells the backplane which clock source to reference and propogate to the backplane.
-Dave
You're matching inbound dial-peer 0, instead of 101 like you intend to.
Configure:
Then read and understand this link:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
-Steve
