08-08-2014 09:06 AM - edited 03-16-2019 11:40 PM
Hi everyone.
I have a problem with call in CUCME to GK and CUCM.
The calls are made in CUCME to IP Phones in other office that registered at CUCM, the link between GK and CUCME is MPLS.
When try call to IP Phone in CUCME to IP Phone in CUCM the call not complete until after 2 attempts.
The number source is 532888 and the call destiny is 570777
I have logs about GK and CUCME and I follewed the message RAS found this errors:
Aug 5 17:33:43.917: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type RELEASEIND_CHOSEN
Aug 5 17:33:43.917: //162027/BA3D480884A3/H323/release_ind: Disconnect cause 16 location code 0
Aug 5 17:33:43.917: //162027/BA3D480884A3/H323/cch323_h225_receiver: RELEASEIND_CHOSEN: src address = 10.44.194.65; dest address = 10.44.226.1
Aug 5 17:33:43.917: //162027/BA3D480884A3/H323/run_h225_sm: Received event H225_EV_RELEASE_IND while at state H225_ACTIVE
Aug 5 17:33:43.921: //162027/BA3D480884A3/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_ACTIVE
Aug 5 17:33:43.921: //162027/BA3D480884A3/H323/cch323_h225_set_new_state: Changing from H225_ACTIVE state to H225_WAIT_FOR_DRQ state
Aug 5 17:33:43.921: //162027/BA3D480884A3/H323/cch323_h225_send_release: Cause = 16; Location = 0
Aug 5 17:33:43.921: //162027/BA3D480884A3/H323/cch323_h225_send_release: h225TerminateRequest: src address = 170705473; dest address = 10.44.226.1
Aug 5 17:33:43.921: H225.0 OUTGOING PDU ::=
Other calls not complete
Aug 5 17:32:54.882: //162025/9EA3F665849E/H323/release_ind: Disconnect cause 38 location code 0
Aug 5 17:31:00.024: //162019/593FFAC28492/H323/release_ind: Disconnect cause 18 location code 0
When call connect the message h323 that found is connect, releaseComplete, callproceeding, setup, etc.
The configuration in the GK is
interface GigabitEthernet0/0.50
description VOZ
encapsulation dot1Q 50
ip address 10.44.209.1 255.255.255.0
ip accounting output-packets
h323-gateway voip interface
h323-gateway voip id gk-brasil.domain.br ipaddr 10.44.209.1 1719
h323-gateway voip h323-id gk-brasil.domain.br
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 10.44.209.1
service-policy input LAN_in
gatekeeper
zone local gk-brasil.domain.br domain.br 10.44.209.1
zone local brasil-tda002.domain.br domain.br
zone local brasil-tda001.domain.br domain.br
zone local brasil-tda003.domain.br domain.br
zone local brasil-saopaulo.domain.br domain.br
zone local brasil-t0007.domain.br domain.br
zone local Modulo-Paranagua-T0008.domain.br domain.br
zone local brasil-OficinaBoqueirao.domain.br domain.br
zone local brasil-tda004.domain.br domain.br
zone local OficinaBoqueirao.domain.br domain.br
zone local brasil-tda008.domain.br domain.br
zone local brasil-MOD006.domain.br domain.br
zone local brasil-loja006.domain.br domain.br
zone local brasil-t0010.domain.br domain.br
zone local Modulo-ALMIRANTE-T0012.domain.br domain.br
zone local brasil-loja012.domain.br domain.br
zone local brasil-loja005.domain.br domain.br
zone local brasil-loja014.domain.br domain.br
zone local brasil-PONTAGROSSA.domain.br domain.br
zone prefix brasil-tda001.domain.br 0001..
zone prefix brasil-tda002.domain.br 0002..
zone prefix brasil-tda003.domain.br 0003..
zone prefix brasil-tda004.domain.br 0004..
zone prefix brasil-loja005.domain.br 0005..
zone prefix brasil-loja006.domain.br 0006..
zone prefix brasil-t0007.domain.br 0007..
zone prefix brasil-tda008.domain.br 0008.. gw-priority 0 brasil-tda008.domain.br
zone prefix brasil-t0010.domain.br 0010..
zone prefix brasil-loja012.domain.br 0012.. gw-priority 0 brasil-loja012.domain.br
zone prefix brasil-loja014.domain.br 0014..
zone prefix gk-brasil.domain.br 532... gw-priority 0 brasil-OficinaBoqueirao.domain.br
zone prefix brasil-saopaulo.domain.br 533... gw-priority 0 brasil-saopaulo.domain.br
zone prefix Modulo-Paranagua-T0008.domain.br 534... gw-priority 0 Modulo-Paranagua-T0008.domain.br
zone prefix Modulo-ALMIRANTE-T0012.domain.br 535... gw-priority 0 Modulo-ALMIRANTE-T0012.domain.br
zone prefix brasil-PONTAGROSSA.domain.br 536... gw-priority 0 brasil-PONTAGROSSA.domain.br
zone prefix brasil-MOD006.domain.br 580... gw-priority 0 brasil-MOD006.domain.br
gw-type-prefix 1#* default-technology
no shutdown
The configuration en el CUCME is
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
call start slow
modem passthrough nse codec g711ulaw
sip
min-se 1000 session-expires 1000
no call service stop
interface GigabitEthernet0/0.80
description *** RED-VOZ OFICINAS BOQUERAO ***
encapsulation dot1Q 80
ip address 10.44.194.65 255.255.255.192
h323-gateway voip h323-id brasil-OficinaBoqueirao.domain.br
h323-gateway voip bind srcaddr 10.44.194.65
service-policy input EntradaLanCE
dial-peer voice 101 voip
description ** Marcacion IP **
destination-pattern [0,5][0-7]....
session target ras
dial-peer voice 100 voip
description *** Llamadas a CM Mexico ***
destination-pattern 525.....
session target ras
I have separeted de CUCME and CUCM of GK and connected both directly via Dial-Peer voip with session target IPV4 and work fine.
Somebody any experience with this problem?
I hope your comments
Solved! Go to Solution.
08-14-2014 08:57 AM
Hi Chintan, the configuration applied was successful.
The all calls completed now!!!
Thanks so much for your help and is a pleasure work with you.
