05-27-2013 08:09 PM - edited 03-16-2019 05:32 PM
I'm with the following problem:
I'm using B-ACD with CUCM, it's working very well but it had one problem, when I receive a call from PSTN directly on extension, no passing by B-ACD, when i will tranfer or put this call on hold, the client hear the MoH configured on CUCM.
But when this call pass by B-ACD and after goes to CUCM for the same extension for example, while the user doesn't take this call the client hear the MoH from B-ACD, but if the user take this call and to tranfer or put in on hold this client doesn't hear the MoH from CUCM.
Can someone help me?
Following is the configuration:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
codec preference 5 g722-64
voice translation-rule 1
rule 1 /^9+/ /89/
voice translation-profile fromPSTN
translate called 1
application
service aa flash:app-b-acd-aa-2.1.0.0.tcl
param number-of-hunt-grps 4
paramspace english index 1
param dial-by-extension-option 1
param handoff-string aa
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 8900
paramspace english location flash:
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
param call-retry-timer 15
param voice-mail 8902
param max-time-call-retry 700
param service-name queue
service queue flash:app-b-acd-2.1.0.0.tcl
param queue-len 10
param aa-hunt3 8998
param aa-hunt4 8997
param aa-hunt10 8902
param aa-hunt2 8999
param queue-manager-debugs 1
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
description *** Connected to PSTN
voice-port 0/0/0:15
cptone CL
timeouts interdigit 5
busyout monitor action graceful
busyout monitor GigabitEthernet0/0.423
dial-peer voice 10 pots
tone ringback alert-no-PI
destination-pattern 0T
port 0/0/0:15
dial-peer voice 35 voip
description Repasse de chamadas para o CUCM Publisher
preference 1
destination-pattern .T
progress_ind setup enable 3
session target ipv4:10.10.9.35
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 36 voip
description Repasse de chamadas para o CUCM Subscriber
preference 2
session target ipv4:10.10.9.36
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 8900 voip
service aa
destination-pattern 8900
session target ipv4:10.42.30.40
incoming called-number 8900
codec g711ulaw
no vad
dial-peer voice 5 pots
translation-profile incoming fromPSTN
incoming called-number 9..
direct-inward-dial
port 0/0/0:15
telephony-service
srst mode auto-provision none
srst ephone template 1
srst dn template 1
srst dn line-mode dual
max-ephones 100
max-dn 100
ip source-address 10.42.30.40 port 2000
system message [SRST] - En modo local
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 2784.... extension-length 4
max-conferences 8 gain -6
call-forward pattern ....
moh en_bacd_music_on_hold.au
multicast moh 239.10.16.4 port 2123
transfer-system full-consult
transfer-pattern ....
create cnf-files version-stamp 7960 May 27 2013 20:28:03
ephone-hunt 2 longest-idle
pilot 8999
ephone-hunt 3 longest-idle
pilot 8998
ephone-hunt 4 longest-idle
pilot 8997
ephone-hunt 10 longest-idle
pilot 8902
10-24-2014 09:38 AM
Hi, Did you resolve this issue?
Thanks.
