problem with my AA
coucoumama
hi all
- i have a gsm gateway connected to my CME router , so i configure all incomming call from outside to 4 SIM on my gsm gateway forwarded to my Auto attend number also my FXO port .
so , the problem when a call join my AA customized from the gsm gateway  , the customer for example asked to press 1 to join the technical team but when she's type it nothing produced and  the prompt keep playing , but from FXO port it work . so i ask for a solution where i think is related to DTMF-relay i think ?
8 Replies 8
coucoumama
can anyone help or have an issue like this ?
Ben,
How is the GSM gateway connected to the CME router? Is it IP? TDM?
If it is IP then which signaling protocol? SIP? H323?
I assume that you are using BACD on your CME. If that is the case AND you are doing SIP or H323 between the CME and the GSM gateway then you will need to address a few things.
1. For BACD you should be using a voip dial-peer that may look something like:
dial-peer voice 81020 voip
service app-b-acd-aa
destination-pattern 4000    <<< this is your pilot DN for your AA app
session target ipv4:
incoming called-number 4000
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
2. You would need to allow IP-to-IP communication:
voice service voip
allow h323 to h323   <<< if GSM gw is H323
allow sip to h323   <<< if GSM gw is SIP  and also if you are using CUE (SIP integrated)
allow h323 to sip   <<< if I have s to h, I always add h to s
3. DTMF on your GSM voip dial-peer
You have to determine what is supported by the GSM gateway and then provision the voip dial-peer on your CME accordingly. You can provision support for multiple DTMF types as well.
Side note: I have not worked with GSM GW before, so I am speaking from CME PoV only.
HTH.
-Bill (@ucguerrilla)
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
mhassani
You are right? It is a DTMF issue, what type of connection do you have between you CME and the GSM gateway
the GSm gateway is a h323 with ip adress connected to Gb interface to the CME and the type of dtmf on the gsm gateway is alphanumeric , signal and SIP
the gsm gtateway is 2n officeroute
Ben,
OK then you will need a voip dial-peer that your GSM gw can hit and that specifies the correct DTMF-Relay settings.
dial-p v 81020 voip
incoming called
no vad
dtmf-r h245-a
codec
is not working when i put the 1 or 2 nothing produced the prompt still play, that's my config
dial-peer voice 102 voip
description Unity Express - VoiceMail
service app
destination-pattern 999
session protocol sipv2
session target ipv4:10.1.1.2
dtmf-relay rtp-nte
no dtmf-interworking
codec g711ulaw
no vad
coucoumama
that's a capture formy gsm gw config
