01-15-2014 09:01 AM - edited 03-16-2019 09:16 PM
Al momento de ejecutar el comando csim start 90453221323934
GTW#csim start 90453221323934
csim: called number = 90453221323934, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(2753)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
Pero NO sale la llamada...es decir...mi celular (0453221323934) no recibe esta llamada....
Saludos.
01-15-2014 09:09 AM
Tienes un loop,
por eso la llamada NO sale.
Puedes subier el 'sh run' y sacar un 'debug ccapi inout' y re intentar la llamada para identificar y reglar el problema
Please Kudos/rate if this help!
01-15-2014 09:27 AM
GTW#sh running-config
Building configuration...
Current configuration : 7653 bytes
version 12.4
hostname GTW
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 3
network-clock-select 4 E1 0/3/0
dot11 syslog
ip cef
ip domain name pruebas.com.mx
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
modem passthrough nse codec g711ulaw
sip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g729r8
codec preference 3 g729br8
codec preference 4 g711ulaw
crypto pki trustpoint TP-self-signed-2390140610
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2390140610
revocation-check none
rsakeypair TP-self-signed-2390140610
archive
log config
hidekeys
controller E1 0/3/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country telmex
category 2
answer-signal group-b 1
caller-digits 4
groupa-callerid-end
description TELMEX2
controller E1 0/3/1
framing NO-CRC4
description Llamadas Axtel
ip forward-protocol nd
ip forward-protocol udp syslog
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/3/0:0
cptone MX
timeouts interdigit 5
sccp ccm group 1
associate profile 10 register Conferences
associate profile 11 register Transcode
dspfarm profile 11 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 9
associate application SCCP
shutdown
dspfarm profile 10 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
shutdown
dial-peer voice 20 pots
description CELULARES PRUEBA
destination-pattern 90453221323934
incoming called-number .
direct-inward-dial
port 0/3/0:0
forward-digits 13
line con 0
password
login
line aux 0
line vty 0 4
password
login
transport input all
scheduler allocate 20000 1000
end
Ahi te mando el sh run....por otro lado..cuando habilito el debug voice ccapi inout .....y corro de nuevo el comando csim start [numero], el debug no me muestra nada
GTW #debug voice ccapi inout
voip ccapi inout debugging is on
GTW#
GTW#
01-29-2014 12:15 PM
El dial-peer esta malo.
direct-inward-dial
port 0/3/0:15-------------> no 0
forward-digits 13
voice-port 0/3/0:15-----> no 0
cptone MX
