Problems CP7911G
John Gutierrez
Hi. I bought some CP7911G-Ch1, and two of them presents the following issue: When I connect the phone , inmediately the lights of the MWI, the hold button and the Applications menu turns on, and nothing it's display on the screen. The phone doesn't boot and I don't what Can I do. I have tried to make a factory restore but nothing happens. Have has someone the same problem? How can I fix it? Thanks
paolo bevilacqua
The factory restore needs to find FW files to reload them. So you need to be connected to a dhcp/tftp server with all s the files, beginning with term11.default.loads
You can do easily do thta with a PC running tftpd32.
Thanks for your interest. I have installed CME 4.2 with all the requiered firmware for CP7911. Others Cp7911G that I bought upgrade its firmaware without problems, but these two present the issue that I mentionated. It doesnt make nothing and doesnt try to download the files.
How do you know? Have you looked at "debug tftp events" ?
