Provider for SP Trunk Lab Tests
csedlmeier
Dear colleagues.
Most of the time I was dealing with ISDN connections from provider to our company. But now we have an location in Sweden where we connect a SIP Trunk to Telia. My idea is now to setup a lab router to prepare myshelf for a SIP Trunk configuration.
Did some one already configure a SIP Trunk to Telia or did some one know a provider where I can connect with my test configuration ?
Any idea ?
Kind regards
Christian
Vivek Batra
SIP trunking configuration for most of the providers remain same except credentials you got from your provider. However please note that if you make SIP trunk work with one provider doesn't mean that it will work with other as well. You may need to take care of ANI, header customization etc depends on provider requirement.
Just google 'free SIP providers' and you will get plenty of free providers you can test SIP trunk with.
- Vivek
OK thnaks for answer. I found some free provider and I found the following example configuration:
https://supportforums.cisco.com/sites/default/files/legacy/9/9/4/43499-july-26-cube-randy-wu-presentation-regular-size-modified-randy.pdf
Did some one have some other examples of the configuration for SIP Trunk ?
Please check the following page where you will get many reference documents.
http://www.cisco.com/c/en/us/solutions/enterprise/interoperability-portal/networking_solutions_products_genericcontent0900aecd805bd13d.html
- Vivek
