PSTN<->2801<->Ascotel ISDN PBX, ISDN Data Calls
c.hennrich
we will deploy a Cisco 2801 Gateway, that connects via E1 PRI to PSTN and 2 BRIs QSIG to an Ascotel ISDN PBX. Now we have some ISDN S0 devices, Faxes and Modems at the old Ascotel.
Has anyone done such a scenario? I'm afraid, that ISDN data calls will not go through. I will use H323, so that TDM switching without invoking DSP should be possible.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00804794c6.shtml
I think I need to remove the command isdn incoming-voice voice. Anything other I should take care of?
The QsiG Connection is already working.
Many thanks and with Best Regards
paolo bevilacqua
yes data calls will be switched. See:
Note, DSP will not be used during the call, but must be present for the voice-port to be enabled.
Please rate post if it helps!,/i>
